Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Thu Apr 21, 2016 4:28 am Post subject: Re: Adjustable beam & disc brake conversion |
sam_w wrote: |
Oh Dear, They arrived and will not fit. I have lifted spindles and they don't bolt on.
I guess I have to get an adjustable beam, to have discs and be lifted.
Is an adjustable beam available for a Thing, and is it different to a beetle one? |
If the stock drums bolted onto your lifted spindles, why won't the discs? Can you specify why they will not fit? |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Ratt Samba Member
Joined: April 15, 2003 Posts: 753 Location: Puyallup, Wa
Posted: Thu Apr 21, 2016 5:56 am Post subject: Re: disc brake conversion |
Here are my 3" lifted spindles next to the originals |
sam_w Samba Member
Joined: March 07, 2002 Posts: 1479 Location: Petaluma, CA
Posted: Thu Apr 21, 2016 6:51 am Post subject: Re: disc brake conversion |
Thanks for the replies, but my new question is, "Are thing beams different?". Can I use a beetle adjustable beam? _________________ 63 singlecab
73 thingster
74 Thing |
GI Joe Samba Member
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Thu Apr 21, 2016 9:34 am Post subject: Re: disc brake conversion |
As Joe said Beetle will work. Why not have adjusters installed in your Thing beam? This way you still have the extra braces. Why won't the brakes work? |
sam_w Samba Member
Posted: Thu Apr 21, 2016 9:57 am Post subject: Re: disc brake conversion |
I bought a new beam from the Thing shop and did not want to cut it. I stupidly sold/gave my old beam away. I now know to keep all Thing parts forever.
I did call JBugs and they will take the parts back, so I have to decide whether to stay with drums, or go to an adjustable beam with discs.
I will also look at making a bracket to put the discs on my Doug Fuller raised spindles. If that works I will let people know how to do it. _________________ 63 singlecab
73 thingster
74 Thing |
Ratt Samba Member
Posted: Thu Apr 21, 2016 10:26 am Post subject: Re: disc brake conversion |
Talk to Locky. He used AC industry discs. I'm in the same boat as you. Something has to work. |
Posted: Thu Apr 21, 2016 10:49 am Post subject: Re: disc brake conversion |
Kubelmann had adapter plates to mount the caliper. Vince made them years ago. Have you tried Mike Basso? Will one of the companies make a set of raised disc spindles? |
sam_w Samba Member
Posted: Thu Apr 21, 2016 10:54 am Post subject: Re: disc brake conversion |
thanks, will try _________________ 63 singlecab
73 thingster
74 Thing |
63ziggy Samba Member
Joined: June 19, 2005 Posts: 1100 Location: The Woodlands, Texas
Posted: Thu Apr 21, 2016 2:25 pm Post subject: Re: disc brake conversion |
did not digest all the posts here. just adding my experience
I have 2" raised spindles made by BCR. I am running AC Industries wide 5 disk brake conversion with no problem. I have been running for couple years.
with that said, she is a weekend driver and definitely have not put her through the paces Sam that you have with yours. |
ThingOw181 Samba Member
Posted: Thu Apr 21, 2016 5:13 pm Post subject: Re: disc brake conversion |
Hi Sam,
I wonder if a different style of disc brake would work for you.
CNC is one brand that came to mind. They use a bolt on type caliper rather than the sliding calipers on cast brackets like the EMPI kit.
http://www.cncbrakes.com/dbk.asp?grp=dbk&subgrp=f&series=654&subseries=
Something like that may give you the clearance you need as the brackets will be much smaller.
They're about double the price of the EMPI stuff unfortunately, but I believe they have a good racing reputation.
Hope that helps. |
74 Thing Samba Member
Posted: Fri Apr 22, 2016 6:36 am Post subject: Re: disc brake conversion |
I believe the CSP brakes would work as well, but they are much more expensive. Maybe look into those brackets that Vince used to make/sell. |
sam_w Samba Member
Posted: Wed Apr 27, 2016 10:46 am Post subject: Re: disc brake conversion |
Well, I just punted for now.
I got my local VW shop to change all the drum brakes and fix the pulling I had.
The main problem was that one of the rear flexible hoses was blocked, causing the Thingster to pull like crazy. The front shoes were cracked and everything else was OK.
Adam put it all together and also replaced the front shocks with new pistons and hoses.
The only problem is that the brake pedal is not really hard, but it stops fine. We think that the shoes and drums are not well matched in radius.
I am told the the shoe radiusing machine is illegal in California. It is an attachment to a drum sander that you arc the shoes until the radius matches the drum.
Anybody used one of these? _________________ 63 singlecab
73 thingster
74 Thing |
germanbilly Samba Member
Joined: October 18, 2013 Posts: 377 Location: Victorville
Posted: Wed Apr 27, 2016 11:00 am Post subject: Re: disc brake conversion |
Back in the early 80's I worked at a VW shop here in Victorville, CA and we radiused all our shoes on VW's. I still do not have lung cancer. Lucky I guess. Yes it makes a difference on how the shoes make contact.
GB |
lqqkatjon Samba Member
Joined: July 02, 2013 Posts: 36 Location: St. Cloud, MN
Posted: Wed Apr 27, 2016 12:03 pm Post subject: Re: disc brake conversion |
I suspect other brake adjustment issues.
but you can always buy your own:
http://www.ebay.com/itm/Ammco-Brake-Shoe-Grinder-8...mp;vxp=mtr
Yes, the government does not like those anymore.... but you can still find a few around if you start asking the right people. |
sam_w Samba Member
Posted: Wed Apr 27, 2016 12:12 pm Post subject: Re: disc brake conversion |
Thanks for the info, but $355 is a bit much for a one time use.
I was told, "drive 300 miles and readjust'
Maybe the shoes & drums will then match. _________________ 63 singlecab
73 thingster
74 Thing |
