nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed Apr 13, 2016 1:27 pm Post subject: Meet Schultz the 1963 Double Cab |
We picked up this 1963 Double Cab 18 months ago from a guy in WI that had it since the late 70's. He had bought it from a local marina and drove it for a while before parking it to do a full restoration.
Move ahead 25 years later and there it sat in his barn taking up space and still no time or money to restore it. He advertised it on the local Craig's list and I went over to see it, and struck a deal to buy.
We knew it likely had a bunch of previous repairs and the sculpted bondo was thick so we planned for the usual 8" all the way around the bottom to need replacement. Sitting inside a dry storage all those years saved the majority of the truck from further decay, but the mice did have a wonderful home for some time.
Pictures as found and when we got it home. From 20 feet away and with the doors closed, it didn't look too bad. But I knew better once I saw missing vertical panel seams, drain holes in doglegs and gates, etc. I knew "the bondo was thick with this one"
First order of business was to pressure wash it inside and out to rid it of the mouse nests, acorns, seeds and droppings. Next was to peel off the bondo and see what was hiding under it. I used a propane torch to soften the bondo and a putty knife to peel it off. Some of the thinner areas I used a stripper wheel on a angle grinder. Below is a look at the carnage.
We also removed what was left of the cargo floor
Posted: Wed Apr 13, 2016 1:30 pm Post subject: Re: Meet Schultz the 1963 Double Cab |
We did the initial outer body sheet metal repairs using a combination of sheet metal from the usual vendors. We've found that no one vendor makes all the best pieces so we get what we believe to be the best pieces for a particular area from who ever makes them.
The original decklid had issues along the bottom and one hinge mount was broken so it came apart to fix.
Same with the gates, they were awful and full of bondo on the entire bottom rib and a few of the vertical and end ribs. We used the KF replacement pieces to make them solid again.
Had to add holes and other small details to the KF pieces.
We'll use a rust encapsulator and internal chassis sealer product from Eastwood to try and halt the rust we know is inside the other ribs. There is just no way to get that removed unless the gates are completely taken apart.
All three doors had rust at the bottom. Only the cargo door needed inner and outer pieces replaced. Front doors were in good enough shape to mostly patch. The bottom inner structure of one needed to be replaced.
The process was similar to the decklid and gates; peel back the lip, release the spot welds, cut out the rust and fit and weld the new piece. Finally, hammer and dolly the lop back over.
Once the bulk of the body panels were replaced, we sent the whole truck, doors and gates off to get stripped of all paint. We supplied them with the tipping arms so they can flip the truck on either side and get the entire bottom and chassis too. The company we use does a lot of cars and has a very gentle touch. We've never had a panel come back warped.
Once it arrived back to the workshop, the remaining metalwork and rust repair was completed. This included the usual base of the windshield, bottom of the nose, inner and outer valence, front floor halves and other miscellaneous pin holes and cheesey areas that were not revealed.
The cargo floor was welded in. This was very tough since it was such a cramped space under the rear where the fuel tank sits. The fuel tank bases and the piece for the base of the block off doors was added.
The heater system pieces were repaired and reinstalled. We know of only one place that even reproduces these pieces but have no idea of the quality so we repaired the pieces we had,
The insulation for a Double cab has a hole for the paper tube
Amazingly the load bed was in wonderful condition with just some minor dents and pitting. The m-code plate indicates it was delivered with a tilt and bows so maybe this helped some.
We used a series of metal bucks formed to the corrugations, to hammer and dolly those out. We also removed the remaining wood slat rivets and welded up the holes. We'll drill new holes when we trial fit the wood slats before heading to final body work.
Once the nose was buttoned up, it was time to final trial fit the front doors and ensure they will fit with good gaps. We did the same for the cargo door, decklid and gates.
Finally, the bumpers were trial fit and adjusted as needed so as to avoid any serious tweaking when we're dealing with freshly painted parts.
With all the underside parts cleaned, straightened and repaired, we are finally ready for some paint on the chassis. We opted for actual paint rather than the primer put on from the factory, but we stayed with the primer gray color. Hopefully this will protect our hard work for years to come.
And finally off to the body shop.
Hubby and I do this restoration work together. He does the metal repairs and I do the mechanical/electrical/interior and reassembly. While all this metal work has been going on, I've rebuilt the front axle, transmission and rear axle, 1500cc engine. I'm a fan of stock everything so this will stay 6V. My only concession was to put in 1600cc P/C. and I'm going with a 50A generator/regulator for a little extra juice for possibly adding some fog lights since we do drive our cars.
I've also gone through and restored or repaired all the electrical systems and lights (http://www.thesamba.com/vw/forum/viewtopic.php?t=646495)
We have a few more details to complete while it's at the paint shop, like painting the bumpers and wheels, finishing the upholstery, and cleaning up remaining nuts, bolts, etc. Ideally when it returns from the paint shop, it will be an reasonably fast reassembly since all the pieces that can bolt on should be ready to go. Fingers crossed!
I'll update things when Schultz returns from the paint shop. |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2541 Location: Ocean Beach in Beautiful BLUE California
Pinetops Samba Member
Posted: Wed Apr 13, 2016 1:59 pm Post subject: Re: Meet Schultz the 1963 Double Cab |
Beautiful work so far on this truck! I love the last pic of the mechanicals on the rack. _________________ "A rolling bus gathers no rust." |
srfndoc Samba Member
Posted: Wed Apr 13, 2016 2:38 pm Post subject: Re: Meet Schultz the 1963 Double Cab |
Really nice work. How many hours do you think you have in it at this point (metal work/body/paint)? _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Stocknazi Samba Member
Posted: Wed Apr 13, 2016 5:49 pm Post subject: Re: Meet Schultz the 1963 Double Cab |
Nice front axle/trans/motor storage rack. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Wed Apr 13, 2016 6:02 pm Post subject: Re: Meet Schultz the 1963 Double Cab |
Pinetops wrote: |
I love the last pic of the mechanicals on the rack. |
Yea ^^^^^^^^ x2 !!
Any chance you have a pic of that Rack w/out the Trans & front end on it ?
Great pics & info, love the spliting of the Deck lid. I wish someone had filled in ALL the holes for the wood slats on my Single and just drilled ONE set of holes .... _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Wed Apr 13, 2016 6:04 pm Post subject: Re: Meet Schultz the 1963 Double Cab |
good work on Schultz, glad Schultze did not get the blues. (obscure movie reference, IMDB it. love the movie)
this is a pretty perfect example of what double cabs look like underneath. Always more places to fix than expected _________________ regards
Uli
Posted: Wed Apr 13, 2016 8:22 pm Post subject: Re: Meet Schultz the 1963 Double Cab |
srfndoc wrote: |
Really nice work. How many hours do you think you have in it at this point (metal work/body/paint)? |
Wild guess... 1000 to 1100 hours. Load bed rough out, press out major dents and hammer and dolly work is 60 - 70 hours alone. Currently at the body shop and with two to three techs on it full time they just passed two weeks, but all doors and window frames and bolt on's are in final prime and body should be in primer by end of the week. Maybe painted and home by end of April. Then the reassembly rush will be on. May make the local show on the 5th of June. Maybe??? |
wcfvw69 Samba Purist
Posted: Wed Apr 13, 2016 9:25 pm Post subject: Re: Meet Schultz the 1963 Double Cab |
I love these threads where people fix these well deserving VW's the correct way. I figured it was going to be media blasted when I started at the top of the thread. I "cringed" a bit thinking about what happened to my convertible bug body at the blasters. They managed to warp about every panel on the bug. I was NOT happy. I'm glad you found a good blaster.
What's the plan on it? Are you keeping it or? _________________ Contact me at [email protected]
The Samba member since 2004.
dietermkII Samba Member
Posted: Thu Apr 14, 2016 3:35 am Post subject: Re: Meet Schultz the 1963 Double Cab |
Great work on the dc Nancy!
Will be as new when you get it ready!
Grts Dieter |
Posted: Thu Apr 14, 2016 4:49 am Post subject: Re: Meet Schultz the 1963 Double Cab |
dietermkII wrote: |
Grts Dieter |
Hey there Dieter! How is your bus doing? We were just talking about HO 2017.
Thanks for your compliment.
Cheers/ |
Posted: Thu Apr 14, 2016 4:53 am Post subject: Re: Meet Schultz the 1963 Double Cab |
wcfvw69 wrote: |
What's the plan on it? Are you keeping it or? |
The plan is to enjoy for some undetermined time and eventually sell. |
scottvw Samba Member
Joined: November 17, 2004 Posts: 2821 Location: Centennial, CO
Posted: Thu Apr 14, 2016 7:53 am Post subject: Re: Meet Schultz the 1963 Double Cab |
Nice job...looking forward to seeing it on all 4 wheels again. |
Posted: Thu Apr 14, 2016 12:55 pm Post subject: Re: Meet Schultz the 1963 Double Cab |
We will defenitly be there in 2017!!!
The bus is doing great, we did an offroad trip about a month ago.
KombiMadness Samba Member
Joined: December 09, 2011 Posts: 388 Location: Sunshine Coast, Australia
Posted: Thu Apr 14, 2016 7:56 pm Post subject: Re: Meet Schultz the 1963 Double Cab |
Wow! Impressive work and a husband and wife team, no less.....
Your '63 DC, Schultz was asked by Colonel Klink - " Schultz, tell me about the bondo"
Schultz - "Bondo, Herr Kommandant? I know nothing.... nothing"
I love it when people get stuck right in to a resto. You have both done amazing work! _________________ My brother & I on the roof of Dad's Splitty circa 1967 - I'm the half pint with the skinny legs! |
Posted: Thu Apr 14, 2016 8:21 pm Post subject: Re: Meet Schultz the 1963 Double Cab |
KombiMadness wrote: |
I love it when people get stuck right in to a resto. You have both done amazing work! |
LOL
Indeed, his name comes from the TV show. A big old german guy with white hair.
"SCHULTZ!!!!!"
"Colonel Hogan, I see nothing...." (no headlights when we got him)
Posted: Wed May 11, 2016 9:43 am Post subject: Re: Meet Schultz the 1963 Double Cab |
More progress on the DC. We're hoping to have it back in a couple of weeks to begin assembly and hopefully finish for the local Twin Cities VW show on the 5th. We're supposed to have the window pieces and doors first so we can hopefully get them assembled before the body arrives.
Paint shop has all of it in final primer. There are so many bits and pieces that get paint! I have to source 15 more large phillips head screws for the door and gate hinges to finish all the painted parts.
I know WW and others sell ones that will work, but the head profile and diameter is just a bit off so I'd like to find originals if possible.
Anyone with extras please PM me.
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Wed May 11, 2016 12:30 pm Post subject: Re: Meet Schultz the 1963 Double Cab |
Golly that's some awesome stuff, just rad. _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
Posted: Wed May 11, 2016 4:58 pm Post subject: Re: Meet Schultz the 1963 Double Cab |
nlorntson wrote: |
I have to source 15 more large phillips head screws for the door and gate hinges to finish all the painted parts. |
I didn't go check but are the gate hinge screws the same as the door screws?
I have some door screws but probably not 15. _________________ How to Post Photos
