Air Kraft Samba Member
Posted: Thu Aug 11, 2016 9:20 am Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration |
The panel ready for action...
Checking fit - perfect!
Yep!
Spot welding the panel in...
_________________ www.air-kraft.com |
Posted: Thu Aug 11, 2016 9:22 am Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration |
Busting out the oxyacetylene to replicate the factory welds...
Posted: Thu Aug 11, 2016 9:27 am Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration |
Wheeling out the imperfections on the original top edge closing panel...
The finished item (apart from the seat brackets...)
Hope you guys like it!!!
fazeka Samba Member
Posted: Thu Aug 11, 2016 10:12 am Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration |
Brilliant! Absolute insanity! Love it! |
ingenbremser Samba Member
Joined: September 11, 2008 Posts: 197 Location: Gjøvik, Norway
Posted: Thu Aug 11, 2016 10:49 am Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration |
_________________ 52 split |
Fredrik.S Samba Member
Joined: February 12, 2010 Posts: 102 Location: Sweden
Posted: Thu Aug 11, 2016 4:34 pm Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration |
This is porn, love it |
Scotty Samba Member
Joined: July 02, 2003 Posts: 1525 Location: Northampton - Uk
Posted: Fri Aug 12, 2016 5:19 am Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration |
Good work Matt! _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
wcfvw69 Samba Purist
Posted: Fri Aug 12, 2016 7:28 pm Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration |
Um.. WOW.. simply wow.. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sun Aug 14, 2016 11:41 am Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration |
Sam busting out the fabbed mini E-wheel and CP planisher to get the green panels to fit...
Posted: Fri Aug 19, 2016 11:56 pm Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration |
Barndoor Samba update: Reshaping the front doglegs and setting door gaps. At Airkraft we aim for perfect door gaps as a keen(e) eye is immediately drawn to an uneven gap! Here we are part way through setting, cutting, welding and adjusting to achieve our target. A resto is made or broken on how well the panels line up. It's a labourious, often tedious task, but the end result is always worth the effort
alex1916v Samba Member
Posted: Sat Aug 20, 2016 3:14 pm Post subject: Re: Barndoor Samba - Back To Stock Restoration |
RockStock wrote: |
Scotty wrote: |
good detail
why are they there?
is it bracing/strengthening for the receptive threads of the beam bolts? |
Yes, they are exactly that. On our bus the arc welds were extremely rusty and porous. They needed to be completely repaired and redone. The reason they aren't finished yet is I'm having to borrow an arc welder to replicate the authenticity with 100% accuracy. Not many shops use arc any more including us, so tricky to find! |
Your thermal dynamic TIG welder will have a setting for stick welding dude, you just need the torch and some carbon/mild steel 2.5mm rods
Cheers |
