JohnnyRingo Samba Member
Joined: October 22, 2011 Posts: 415 Location: United States
Posted: Wed Apr 20, 2016 10:42 am Post subject: Fiber washer fuel tap |
Anybody have a source for the fiber washer that goes between fuel tap and fuel sock.......other than WW? Like a local parts/fastner store? |
Posted: Wed Apr 20, 2016 6:27 pm Post subject: Re: Fiber washer fuel tap |
Does anybody know the size? |
Posted: Sat Apr 23, 2016 4:19 am Post subject: Re: Fiber washer fuel tap |
http://www.thesamba.com/vw/forum/viewtopic.php?t=4............. 5x9mm. With enough research and numerous thread post you can find exact information. Just wished people would state facts and not guess.......just to post something. AND........just use ONE red fiber sealing washer over screen sock.......do not use any washer inside nut. |
Stocknazi Samba Member
Posted: Sat Apr 23, 2016 7:11 am Post subject: Re: Fiber washer fuel tap |
JohnnyRingo wrote: |
FWIW I used 2 washers; one between sock and nut and one between sock and tank and it seals just fine.
I believe the parts list only shows 1 washer used, while Bently shows 2. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Sat Apr 23, 2016 3:41 pm Post subject: Re: Fiber washer fuel tap |
StockNazi wrote: |
I believe the parts list only shows 1 washer used, while Bently shows 2. |
Yeah I Iknow.......always have used one. Thought you and Tim would be here at everybus campout? |
Posted: Mon Apr 25, 2016 5:41 am Post subject: Re: Fiber washer fuel tap |
WW......shows only one in exploded view. |
Posted: Thu Apr 28, 2016 2:47 pm Post subject: Re: Fiber washer fuel tap |
. It's not a 5x9mm as shown in parts book........three times to small? Called WW for size.....they said I would have to measure one. So guess I will order some and measure them. Sorry folks.....will report back with correct size. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69807 Location: Phoenix Metro
Posted: Thu Apr 28, 2016 5:04 pm Post subject: Re: Fiber washer fuel tap |
I don't see 5x9 in that thread.
I checked out that thread and the parts book photos in there and 5x9 are the washers for the 5 screws holding the fuel tank sender in place.
The fuel sock washer size is not mentioned in the parts book
The ones I have from WW are:
12mm - inner diameter
16mm - outer diameter _________________ How to Post Photos
Posted: Thu Apr 28, 2016 6:35 pm Post subject: Re: Fiber washer fuel tap |
EverettB wrote: |
16mm - outer diameter |
thanks for clarifying the part and size.....was trying to find some local so I could make a campout untill I ordered some from WW. |
