Longboardluv Samba Member
Joined: September 23, 2014 Posts: 934 Location: Austin TX
Posted: Sat Oct 08, 2016 7:03 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Pinetops wrote: |
Wow, you made a lot of progress! Looks good.
Do you think you'll do any white faux-tina on the "V"? |
Yes I will be faux tina-ing the top either Monday or Tuesday after the red is dry enough to tape! |
Pinetops Samba Member
Posted: Sat Oct 08, 2016 7:15 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Cool, I bet it will turn out great. That color looks like a pretty good match.
FWIW When I blended new paint on my bus, I found that fine scotch brite pads did the best job of convincingly "aging" the new paint. _________________ "A rolling bus gathers no rust." |
Posted: Sun Oct 09, 2016 5:06 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Pinetops wrote: |
why yes i will see below! |
Posted: Sun Oct 09, 2016 5:09 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
the door I bought off Facebook came in!
while putting it on i noticed the Wolfsburg Crest on the hinge, pretty neat!
i'm happy and now I can sell the blue one for what I paid for the SWR one
then i hit the V with some grey scotch brite and taped it off
and painted!
I'll give it a couple of days to dry and then wet sand it with 2000 grit! It should take a bunch of the shine off and get it a little more milky red. So still more work to do! |
Posted: Tue Oct 11, 2016 5:36 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
sanding with 2000 grit and grey scotch brite
primer on a towel seemed to make a good "thru to the primer" look
as shown here
i'm not going to matte clear coat it for a while. i need the red to bleach a little more and i have a few ideas on how to do it! |
Posted: Wed Oct 12, 2016 5:32 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
got the lights and emblem back on! The top clip of the emblem is tricky. Had to get my wife to get her little hand in there behind the tray to put it on! Hopefully the bumpers will be coming soon!
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Wed Oct 12, 2016 5:54 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Damn!! That looks really, really good. Congrats. |
67Cabrio Samba Member
Joined: March 30, 2014 Posts: 31 Location: Everett, Wa
Posted: Thu Oct 13, 2016 11:15 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Looks fantastic! Thanks for all the details on how you did it; hope to be doing the same thing to our bus next summer. (Same colors, too) |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
Posted: Sat Oct 22, 2016 7:15 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
I went ahead and took a little time to paint the side as well.
Unfortunately, the pictures make it look darker than it is, but I should be able to get it to be a closer match.
I also started work on cleaning up this repair job. it had gobs of bondo that i'm sanding down and fixing in order to paint along with the rocker on this side. |
Posted: Thu Oct 27, 2016 6:19 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
I got the body work almost done and ready for paint. I had to have another can of red made at Gemstone Auto. This spot will need one more light sanding then i'll paint it.
I also finally removed this WW tag from the rocker under the cargo doors. I'll be painting this section too, but I kind of liked having that tag down there.. |
conrad1468 Samba Member
Joined: December 20, 2003 Posts: 1019 Location: Jeannette, PA 15644
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Thu Oct 27, 2016 10:41 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
What a great build thread. Thanks for posting the voltage drop from Amazon. I need one for my bus and this just reminded me to buy one. _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
Posted: Thu Oct 27, 2016 12:14 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Thanks everyone!
here's a little preview of something that is coming along!...
Posted: Thu Oct 27, 2016 5:01 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
after a quick sand and a little more taping..
I was able to get three coats!
It's pretty close! I'll have to do some blending/fading along where the two colors meet but it is way better than it was! |
Posted: Sat Oct 29, 2016 5:31 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
got the bumpers back from paint!
the front went together pretty easy, installing it took a few tries. Had to put it in and make adjustments. Took about two hours for the front
bam!
so my rear bumper is a euro style with no holes for uprights or towel bars. I ended up drilling the wrong hole. You can see here that it actually uses the outside hole on both sides to hold both the bracket and upright
so now I have a hole and some chips where i tried the first time. I think i can repair the chips pretty easy, and i have a vintage stop light that i was planning on installing anyways, so i'll just use this hole for the wire and mount it there. no worries #movingon
also found out that i had to drill out the threads for each of those so the 70mm bolt would fit through it. thanks to the samba for this info.
towel bar fitment
trace and drill for mounting hardware
rear all together! I'll try to install it along with the mudflaps tomorrow! |
Posted: Sun Oct 30, 2016 6:19 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
so now i'm running into the issue of the bumper hitting the exhaust. So i need to figure out if I need to change something, cut the bumper or figure out if I'm just doing this wrong.
zozo Samba Member
Posted: Sun Oct 30, 2016 6:57 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
I'd say modify the exhaust, rather than cut the bumper. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
silkvw Samba Member
Posted: Sun Oct 30, 2016 7:26 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Those bumpers look great, Matt!
I know I would not want to cut them either. _________________ '64 single cab Big Bend Bus Bash 2015 '16
'59 camper BBBB 2017 '18 '19 '20 '22 New Mexico
'70 Ghia........Bonneville,........TX Mile,........142 mph......(sold)
https://www.thesamba.com/vw/forum/viewtopic.php?t=641871&highlight= |
