SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Mon Dec 19, 2016 7:44 am Post subject: Re: The 65 Beetle |
Before top end tear down, compression was 125 on 1&2 cylinders. The cylinder head was nice and snug, though the push rod tubes were oozing oil. Now for the issues with compression, specifically on the 3&4 cylinders I believe is because the cylinder head was essentially finger tight, and the amount of oil coming from behind the cylinder and case was exponential.
Though compression on this side was 115 and 90. Also it smoked that a BBQ pit, so we decided to drop it out and button it up. I wanted to reuse the original pistons and jugs, but for a $150 with rings, where rings alone were going to cost $40, we bought in. _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
BotanyBandit Samba Member
Joined: February 13, 2013 Posts: 224 Location: Kansas City
Posted: Thu Jan 26, 2017 11:47 am Post subject: Re: The 65 Beetle |
Looking good! Tim rebuilt a 30 pict 1 for me and I still havent gotten to use it yet
It came back looking like a brand new carb though! Have heard nothing but the best about his work. |
creideahm Samba Member
Joined: March 30, 2014 Posts: 134 Location: Pittsburgh
Posted: Thu Jan 26, 2017 12:13 pm Post subject: Re: The 65 Beetle |
Tim rebuilt a 28-pict 1 for me and it's simply better than new. Awesome work |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Sat Jan 28, 2017 5:44 pm Post subject: Re: The 65 Beetle |
Pulley cover tin.
_________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Sun Jan 29, 2017 10:24 am Post subject: Re: The 65 Beetle |
SamboSamba22 wrote: |
Duh!
Thanks Sharp.
Today's stopping point. Dad's ordering an exhaust, and a oil breather tube boot and we'll be closing up the engine. Moving to fixing wiring issue from starter to generator, new firewall installed, and it's time to bring the motor back home to the bug.
I see you installed a degree wheel. on the reverse engine side does it have the reverse screw built into it? This reverse screw is what pulls outside air into the crankcase for proper crankcase ventilation of harmful vapors containing water and sulfuric acid and unburned fuel in the form of blowby gasses. This reverse screw is vital to longevity of the engine;
https://www.thesamba.com/vw/gallery/pix/1593336.jpg |
Posted: Thu Feb 02, 2017 9:43 pm Post subject: Re: The 65 Beetle |
Dansk exhaust came in today, along with the needed oil boot. Tomorrow afternoon will be able to mount exhaust, hook up heat exchangers, the rest of the engine tin, bolt down the intake, place on the carburetor and step back and smile.
I really hope that this motor stands tall for my pop, he's excited and I'm excited for him, every hard working man deserves an escape from the grind.
Pics to follow, happy cruising everyone. _________________ The Bus Barn Ltd. Co.
Jim Hunter Samba Member
Joined: February 14, 2014 Posts: 107 Location: MB, Slovenjia
Posted: Fri Feb 03, 2017 5:45 am Post subject: Re: The 65 Beetle |
Good luck Sam you have an awesome car here !
Jim |
Helfen Samba Member
Posted: Fri Feb 03, 2017 1:19 pm Post subject: Re: The 65 Beetle |
This you tube was removed |
Helfen Samba Member
Posted: Fri Feb 03, 2017 9:03 pm Post subject: Re: The 65 Beetle |
Might be confusing as that's the wiring diagram for a T2 isn't it.
This is for a beetle:
http://www.thesamba.com/vw/archives/info/wiring/bug_62.jpg _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Sahara74 Samba Member
Joined: December 12, 2013 Posts: 150 Location: Northern California
Posted: Sun Feb 05, 2017 12:17 pm Post subject: Re: The 65 Beetle |
Thought I should jump in here. With all the talk about loose tarboards in the engine compartment and the possibility of pieces suck into the fan, there's one thing you can do. On the firewall there are a number of pointy little metal tabs that were pushed through the tarboard and bent over at the factory. It's real easy when you replace the boards to just ignore the tabs but they actually hold the board securely to the metal. A little bit of a hassle to fuss them through but worth it. Just my 2 cents. Project is looking awesome !! |
