etrain Samba Member
Posted: Sat Apr 23, 2016 4:22 pm Post subject: Fuel Filter? |
While trying to install new heater hose, I noticed this inline fuel filter on my 67. Does not look like OEM to me, but I though I would ask for help. Does the 67 even need a fuel filter?
Cali_Army_Guy Samba Member
Joined: March 19, 2015 Posts: 2094 Location: Stockton, CA
Posted: Sat Apr 23, 2016 4:24 pm Post subject: Re: Fuel Filter? |
etrain wrote: |
Looks like someone did the smart thing and relocated the filter from the engine bay to its current location. _________________ 2015 VW Passat Wolfsburg Edition
1966 VW Beetle - Sold |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Sat Apr 23, 2016 6:30 pm Post subject: Re: Fuel Filter? |
Depends on how dirty the fuel tank and metal body line are. If that filter does not show a lot of crud in it after another 3,000 miles, take it out of the system.
Axle boot seam should be at 3 or 9 O'Clock, not straight up. _________________ In Stereo, Where Available! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Sat Apr 23, 2016 6:38 pm Post subject: Re: Fuel Filter? |
Cali_Army_Guy wrote: |
etrain wrote: |
Looks like someone did the smart thing and relocated the filter from the engine bay to its current location. |
No clamps and is the dark section wet? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Apr 23, 2016 6:57 pm Post subject: Re: Fuel Filter? |
With German fuel flex fuel lines clamps only needed between carb and fuel pump where there is fuel pressure. _________________ In Stereo, Where Available! |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sat Apr 23, 2016 8:38 pm Post subject: Re: Fuel Filter? |
Only beetles that run on fuel need a fuel filter.
What you have there is filter number three. The best one is the sock in the tank pickup tube, the other is the screen in your fuel pump. _________________
EverettB wrote: |
FU#5 |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
A fuel filter is sometimes a pain in the ass to install above the transmission, but a cheap insurance policy in my opinion. Better to have one and not need it, than to eventually have a few flakes of rust or dirt clot up a jet later on.
The photo's angle may be presenting an illusion, but that fuel filter appears to be quite close to the axel boot, as well as the heat-exchanger linkage. I use a zip-tie to keep it away from moving items that might cause issues.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
hitest Samba Member
Posted: Sat Apr 23, 2016 8:41 pm Post subject: Re: Fuel Filter? |
Eric&Barb wrote: |
With German fuel flex fuel lines clamps only needed between carb and fuel pump where there is fuel pressure. |
I usually agree- but with a section of the line hanging and swinging like that- with the added weight of the full filter- I'd clamp it to be safe under there. But yes, in stock arrangements, the low pressure requires no clamping. _________________
EverettB wrote: |
FU#5 |
Posted: Sat Apr 23, 2016 9:15 pm Post subject: Re: Fuel Filter? |
That little bit of weight will not matter on the metal pipes. Remember that the German fuel line just tightens up the more you tug on it. Which is why one should either slit the end open to get the hose off or use a flat tip screwdriver to push the flex fuel line off the pipe. Have yet known anyone personally who had a filter in the same place and have any problem there. _________________ In Stereo, Where Available! |
Harris Samba Member
Posted: Sun Apr 24, 2016 1:27 am Post subject: Re: Fuel Filter? |
hitest wrote: |
Eric&Barb wrote: |
I usually agree- but with a section of the line hanging and swinging like that- with the added weight of the full filter- I'd clamp it to be safe under there. But yes, in stock arrangements, the low pressure requires no clamping. |
I agree with Hitest you take measures to limit the line to NO movement.
Mine now has a Hastings metal filter. No movement
Glenn Mr. 010
Posted: Sun Apr 24, 2016 3:11 am Post subject: Re: Fuel Filter? |
Eric&Barb wrote: |
Clamps are cheap insurance. _________________ Glenn
Member #1009
#BlueSquare |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sun Apr 24, 2016 4:28 am Post subject: Re: Fuel Filter? |
Nice clamp - I like that. Couple comments
1. Am I seeing that correctly in that your axle boot splits are at 12 O'Clock? That is wrong. The joint is the thickest, least flexible part of the boot. Bentley manual says have then at 3 or 9 o'clock. I like 10 or 2 oclock myself. Lots of folks do that though. Just sayin.....
2. As far as I know VW never installed a filter except for in the tank and screen in the fuel pump.
3. Clamps - no clamps on hoses - Filters with a barbed end help, but I always use clamps. And yeah - looks like the one end of your line is leaking. And if you have stock carb use a safety wire through the clamp to a carb top screw.
4. Supporting filter - Gonna steal that supports idea in the future - very nice, BUT Glenn pointed out several years ago that having the weigt of a filter flopping around is not a good thing. What I have been doing for years is make the hoses long enough so I can zip tie the filters to the heat exchanger/body hoses. _________________ D-Dubya Manx clone - 63 Short pan,1914.
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Sun Apr 24, 2016 9:14 am Post subject: Re: Fuel Filter? |
Eric&Barb wrote: |
Remember that the German fuel line just tightens up the more you tug on it. |
True but the problem these days is that the gas eats away the fuel lines so the ends crack and can pull right off with almost no effort.
I have personally done that and also seen the ends get wet.
It shouldn't a problem on the feed side with no pressure though, unless there is something that is causing a pull on the line, like a fuel filter flapping around. _________________ How to Post Photos
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
Posted: Sun Apr 24, 2016 9:53 am Post subject: Re: Fuel Filter? |
EverettB wrote: |
Gasoline has always eaten up rubber fuel lines. One of the first jobs I did by myself on a Beetle was replacing leaky fuel lines. This was on a 4 or 5-year-old Beetle with factory hose, and before we got ethanol in our gas.
We would cut about a half inch off of the fuel lines every few months when the ends started cracking. When the lines became too short I had to replace them. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Sun Apr 24, 2016 11:50 am Post subject: Re: Fuel Filter? |
Q-Dog wrote: |
EverettB wrote: |
We would cut about a half inch off of the fuel lines every few months when the ends started cracking. When the lines became too short I had to replace them. |
Like hell you replaced them - You just cut the car and made a buggy so you had another 14" of hose to trim....Don't go telling me stories.... _________________ D-Dubya Manx clone - 63 Short pan,1914.
bluebus86 Banned
Posted: Sun Apr 24, 2016 4:48 pm Post subject: Re: Fuel Filter? |
Harris wrote: |
hitest wrote: |
Eric&Barb wrote: |
fuel preheater. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
bluebus86 Banned
Posted: Sun Apr 24, 2016 5:56 pm Post subject: Re: Fuel Filter? |
EverettB wrote: |
Eric&Barb wrote: |
True but the problem these days is that the gas eats away the fuel lines so the ends crack and can pull right off with almost no effort. |
EverettB how often do you have to replace the fuel lines with whatever additive that is causing the cracking problem?
If the ends crack just replace the whole flex fuel lines. Just cutting them shorter is just asking for a VW BBQ.
For us up here we replace flex fuel lines every two years even before signs of cracking and with all the ethanol used up here with no problem.
Certainly if we lived somewhere that the local fuel seemed to attack the German flex fuel line far sooner would either replace all that much more often or switch to a new flex fuel line that can handle stuff. _________________ In Stereo, Where Available! |
Q-Dog Samba Member
Posted: Sun Apr 24, 2016 6:17 pm Post subject: Re: Fuel Filter? |
andk5591 wrote: |
Q-Dog wrote: |
EverettB wrote: |
Like hell you replaced them - You just cut the car and made a buggy so you had another 14" of hose to trim....Don't go telling me stories.... |
Ha! I wish I had cut the chassis on my buggy. Whoever did it cut right through the steel fuel line. I have a metal fuel line running right next to the brake line inside the passenger compartment. Good times!
The buggy got new rubber lines last year to replace the 4-year-old lines that I installed when I bought the car. One was cracking on the end. _________________ Brian
'69 Dune Buggy
'70 Beetle |
Posted: Sun Apr 24, 2016 10:54 pm Post subject: Re: Fuel Filter? |
Eric&Barb wrote: |
EverettB wrote: |
Eric&Barb wrote: |
Certainly if we lived somewhere that the local fuel seemed to attack the German flex fuel line far sooner would either replace all that much more often or switch to a new flex fuel line that can handle stuff. |
Best guess is 6-18 months, it seemed to be random on when they looked bad.
I don't personally cut them shorter.
No need because I have a huge roll of line I got years ago I'm using up.
In my "daily driver" '63 I switched to modern fuel lines, they still look perfect and it's been at least 3 years. I should buy more. _________________ How to Post Photos
