richard1263 Samba Member
Joined: April 25, 2016 Posts: 11 Location: Northamptonshre UK
Posted: Mon Apr 25, 2016 7:21 am Post subject: Admitting defeat - 71 twin port misfire |
.After rebuilding a 71 twin port to stock spec I just cant get to the bottom of a misfire. the car idles fine and does not misfire when revered but as soon as I pull away the car splutters and back fires. I normally find any answers by reading previous posts on the samba but this has got me mystified. I have listed the items checked to save time but would really appreciate any help from you guys.
1) Fuel in. changed filter and checked pump.
2) Check mixture, idle, and jets and used two pict 31/30 carbs, one of which is new.
3) Checked sparks at plugs, fitted two new sets.
4) Checked leads, three sets one new and one of a working engine.
5) Changed rota cap x3 one from a working engine.
6) Changed condenser and points.
7) Swapped vacuum distributer for a 009.
Used wd40/easy start and propane to check for air leeks, no increase in speed.
9) Set timing with lamp and strobe. 7.5 BTDC. Printed pulley.
10) CHECKED THE LEADS GO FROM THE DISTRIBUTER TO THE RIGHT CYLINDERS, 1,4,3,2
11) Checked the valve gaps.
12) Replaced fuel tank and blown through the line.
13) Checked oil pressure 20 PSI.
14) Checked compression on cylinders 1, 128, 2, 128, 3,121, 4, 128 PSI
15) removed large dent from the rear panel, not related just got hacked of one day
Cheers. |
mark tucker Samba Member
Posted: Mon Apr 25, 2016 7:48 am Post subject: Re: Admitting defeate |
needs new set of eyes to look at it.I would first put a set of bosche platinum plugs in it. |
enjoyther1de Samba Member
Joined: December 19, 2010 Posts: 1279 Location: chino,ca
Posted: Mon Apr 25, 2016 8:19 am Post subject: Re: Admitting defeate |
I'd say this is your problem. Oh and you said two 30/31s? dual carb? _________________ HBB took me to BBV. |
Posted: Mon Apr 25, 2016 8:31 am Post subject: Re: Admitting defeate |
swapped to 009 just to see if this made a difference as this worked fine on my other engine.
single carbs, first came with the engine that I rebuilt and the second is a new one. |
Posted: Mon Apr 25, 2016 8:48 am Post subject: Re: Admitting defeate |
Stumbles coming off idle under load? _________________ HBB took me to BBV. |
Jon Schmid Samba Member
Joined: May 29, 2012 Posts: 2033 Location: Southern California
Posted: Mon Apr 25, 2016 8:50 am Post subject: Re: Admitting defeate |
Hi,
Just curious, you gave us your idle advance; what is it reading at 2000 RPM? Also, any exhaust leaks? I assume it's backfiring through the exhaust and not the intake?
Thanks-- |
Posted: Mon Apr 25, 2016 9:05 am Post subject: Re: Admitting defeate |
Haven't checked at 2000 RPM but have revered hard and watched the pulley marks to 31 degrees. not sure were the back fires coming from as it only does it under load., had a very small blow from the muffler but that is it.
The noise is more of a pop than a ping..... now that's tec talk for you... going to put her back on the ramp this evening to check the exhaust for leaks though. |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Mon Apr 25, 2016 10:14 am Post subject: Re: Admitting defeate |
Are these new carbs or old ones? Are you sure the jet paths, particularly the idle jet path is not partially blocked? What about the accelerator pump nozzle? Is it flowing plenty of fuel? Stick you head over the top of it without the air cleaner on and pull the throttle. Does the stream go straight down to the butterfly or hit the wall? If it hits the wall then use a screw driver to move it over.
Lastly the main jet may be too small especially if they are new carbs. Buy these: http://www.amazon.com/SE-Drill-Mini-Sizes-82616MD/...detailpage
and this: http://www.amazon.com/General-Tools-93-Adjustable-...detailpage
Use the drill bits to drill to the next larger drill bit size. Slip the one in the main jet that fits and use the next larger size. It's possible the idle jet might need drilled up too. This depends on a number of factors including new or used carb, compression and some other stuff. I hope this helps. _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
Posted: Mon Apr 25, 2016 11:01 am Post subject: Re: Admitting defeate |
One new carb repro suitable for 71 1300cc and one old. Both show identcle symptoms when pulling away. Pump moving fuel ok when tube is removed from carb, haven't checked inside the carb just swapped it over.dismised the main jet for the same reason unlikely to be two wrong size jets. But will check both anyway. I've noticed after removing the new carb that is is very black inside, not to get to distracted ive assumed this is from running it to rich while attempting to solve the problem??? Could this be a clue? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9663 Location: Oregon
Posted: Mon Apr 25, 2016 6:32 pm Post subject: Re: Admitting defeate |
Richard1263
Repost this in the performance forum. There are alot of very smart guys there that can and will help you. Make sure to listen to what they have to say and do things in the order that they tell you. They will have you on the road in no time.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
Posted: Mon Apr 25, 2016 11:29 pm Post subject: Re: Admitting defeat - 71 twin port misfire |
Thanks for reposting and correcting the spelling. |
modok Samba Member
Joined: October 30, 2009 Posts: 26740 Location: Colorado Springs
Posted: Tue Apr 26, 2016 1:18 am Post subject: Re: Admitting defeat - 71 twin port misfire |
Need more clues.
How old is the gas in the gas tank?
Is it worse hot or cold? rich/lean
worse with choke on/off/dissconnected/propped open?
Is the airfitler odd? Tried drving with it off?
is the muffler suspect?
Is there any clues it is carburetor related at all?
Have you tried alternate ignition timing? does it do better advanced or retarded? Tried swapping coils? Could it be a wiring problem? Loose battery connection, ground straps, wobbly connectors, worn out ignition switch? |
madmike Samba Member
Joined: July 11, 2005 Posts: 5291 Location: Atlanta,Michigan
Posted: Tue Apr 26, 2016 4:33 am Post subject: Re: Admitting defeat - 71 twin port misfire |
are them 'leads'/spark plug wires the cool colored ones?
I found them to cause the same issues you are having _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
wcfvw69 Samba Purist
Posted: Tue Apr 26, 2016 6:27 am Post subject: Re: Admitting defeat - 71 twin port misfire |
Are you sure 100% that you have you spark plug wires on the cap in the correct orientation?
Find TDC on the compression stroke. Find out where the rotor is pointing at on the distributor. Put #1 cylinder wire on the cap under where the rotor is pointing. Pay no attention to the notch on the distributor at this point unless the rotor is pointing at it on TDC compression stroke.
the firing order is 1-4-3-2 with the rotor moving clockwise inside the distributor cap. _________________ Contact me at [email protected]
The Samba member since 2004.
74 Thing Samba Member
Posted: Tue Apr 26, 2016 6:32 am Post subject: Re: Admitting defeat - 71 twin port misfire |
Did you open up the carb and take out the jets and blow them out with carb cleaner/air-it's only like a 20 min job.
Maybe post a photo of your engine as well-visuals sometimes help. |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Tue Apr 26, 2016 7:46 am Post subject: Re: Admitting defeat - 71 twin port misfire |
Wow more questions than answers here guys.
have tried nearly all the things you all asked, coil, leads, jets ect.
But can you elaborate more with regards to.
Earthing, connections, in particular the areas I should investigate first.
Muffler x% ???.
Haven't tried running with pancake filter off but will do in the next few days.
I new the question of lead order would crop up again, I guess this is the most common mistake, but they are defo in the right order. |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1163 Location: San Angelo, Texas
Posted: Tue Apr 26, 2016 7:49 am Post subject: Re: Admitting defeat - 71 twin port misfire |
I think what your saying is you have used 2 different 30mm carbs at different times and still have what you call a misfire that is probably more like the vehicle falls on its face at take off. If I were you, I would find a good 34 pict 3 carb and drill the idle jet to .65mm they came with the idle jet at .55mm if I recall correctly....if not someone correct me. Also, the 34 adjusts idle speed differently than a 30. The butterfly on the 34 should be completely closed at idle as adjusted by the screw on the arm. the idle speed (large screw, left side) and the small screw, adjust the idle speed and mixture, respectively.
The ideal setup would be the 34 carb with a dual vacuum advance distributor.
I have had cars that would hesitate and fall on their faces just as you describe with the same specs as your motor. The repair was to put a dual vac distributor on the car. The vacuum lines, of course, need to be installed correctly. Here is what I think happens using the dual advance distributor. The larger green vacuum line goes to the rear vac chamber of the distributor and has vacuum when the throttle is closed (idling) At the hit of the throttle, vacuum drops and the distributor immediately advances the timing. Using a 009, the timing advance doesn't come in till much later, and by then it to late.....if you can't find a good dual advance distributor (check both sides of the can) use the 009 and drill the idle jet. You will need a pin vise and jet drills for that operation. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
Posted: Tue Apr 26, 2016 8:16 am Post subject: Re: Admitting defeat - 71 twin port misfire |
ok I get most of this post.
think I have spare .65 jets could I just install into the pict 30/31 carb?
don't have a dual vacuum distributer and not seen any sold in the uk.
I have tried 009 and single advance,. which is new.
getting some good feed back from you all ,plenty to check over the coming days, cant help thinking I need to draw up a plan of action so as not cause more problems along the way.
still intrigued about the comments regarding the exhaust/ muffler and earthing. |
