ceburn2 Samba Member
Joined: March 28, 2016 Posts: 15 Location: Killen, Al.
Posted: Tue Apr 26, 2016 5:28 am Post subject: mounting a aluminum floor |
I have a sheet of checker board Aluminum that I want to put in a sand rail. I've found weld on tabs, but some of the really nice builds have the fasteners hidden from view. I want it to look professional, and be strong, and safe. Does anyone have any experience that they could share with me. |
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Tue Apr 26, 2016 6:18 am Post subject: Re: mounting a aluminum floor |
I used stainless steel buttonhead bolts and nutted from the bottom.
I think it is clean looking |
Posted: Wed Apr 27, 2016 5:31 am Post subject: Re: mounting a aluminum floor |
Weld on clips would need to be under the floor board. The ones that I have look at seem that they have one piece, so the clips should be seen from the top unless they run screws directly into the frame. |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2616 Location: West Coast (Michigan's)
Posted: Fri Apr 29, 2016 9:59 am Post subject: Re: mounting a aluminum floor |
I think worrying about seeing floor fasteners on a rail is kinda silly. I've never heard anyone say, boy that would be a really nice rail if it wasn't for the sightly floor fasteners. The aesthetic value of thought out fabrication is one thing, but I don't understand why a person would worry about seeing the inner working of a tube frame vehicle. That's kinda the point. There are ways you could box in over the tab so that the bolt is hidden. Keeping the tabs in the corners is another way to make them less obvious. If you have some thicker aluminum diamond plate like I do you can use flat head bolts and countersink the holes so the heads don't show. Tap the tabs themselves to run bolts thru and skip the nuts, but have fun getting all that to line up just right. _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5389 Location: Holland, MI
PhillipM Samba Member
Posted: Sat Apr 30, 2016 2:05 am Post subject: Re: mounting a aluminum floor |
If your floor is thin using SS bolts/nuts will eat it around where the fastener sits from the galvanic corrosion after a while. |
