bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Tue Apr 26, 2016 8:50 am Post subject: Transmission quandary (manual) |
So, I finally was able to loosen my trans plugs and drain the oil. How much does used manual trans fluid smell like ATF? Seemed mighty red in color, and very loose in the drain pan even after sitting overnight on a 45F concrete floor in the drain pan. Anyway, its stinky. I want to wash out the interior, is that something people do? Perhaps a couple quarts of Marvels, or SeaFoam, or something?
Anyway, I am a bit concerned with the stuff on the magnetic drain plug. The biggest flake looks to be a shear off the edge of a gear. Here are a few pix. Should I be looking for a spare to get rebuilt? I have found 3 junked ones within about 200 miles thus far.
Thanks
Same flake here, just for perspective, and best I could do with focus.
_________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
insyncro Banned
Posted: Tue Apr 26, 2016 8:57 am Post subject: Re: Transmission quandary (manual) |
Pull the bell housing and take a look inside, inspect parts...
Doing so will give you the next info needed to make a decision on what to do.
Thus far, I would plan for a total rebuild. |
Posted: Tue Apr 26, 2016 9:05 am Post subject: Re: Transmission quandary (manual) |
Thanks InSyncro. I see some evidence of oil escaping from the bell housing from the outside. Maybe not 'bad' but is any leak good?
Ya, I'm looking at a bigger project, I guess. The EJ22 (automatic) is still waiting in the driveway. I have the $'s now to order a kit, but this transmission thing has me wondering about going to the transmission swap in addition. Sourcing that and getting the kit and the work lined up together with the engine swap... I'm wallowing.
I had been going toward Merc rims (have the set, and the hardware/spacers) to accommodate big brakes in front. Spendy kit there too. Funds evaporate into the vanagon mist.
So, wallowing. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Tue Apr 26, 2016 9:07 am Post subject: Re: Transmission quandary (manual) |
If time is short, put fresh oil in to spec, run for a week, then pull the plug again and inspect for particles. If you make up a cork bung, you can do this without draining too much trans fluid. If you don't have a lot of fur second time, drive with it usual caution after topping up the fluid. _________________ .ssS! |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
Posted: Tue Apr 26, 2016 9:10 am Post subject: Re: Transmission quandary (manual) |
If you do that EJ22 conversion you'll be likely pushing that trans harder than you did with the wbx, so I'd be going for a look inside and getting ready for a rebuild. (Nice time to add a Peloquin BTW, I like spending other folks money. )
I'd put the merc wheels and bigger brakes on hold for a while and use that money toward the tranny... _________________ Dave O
The Western Syncro build
Posted: Tue Apr 26, 2016 9:14 am Post subject: Re: Transmission quandary (manual) |
dobryan,
Good thinking there. I already wanted to do a transmission rebuild (well, ok, I'd have it done by some talent) and put in the taller stuff for lower RPMs at 65mph. That all told would be the cost of the conversion kit, if I'm calculating it close enough.
Maybe the EJ22 has to wait a little longer.
Thanks _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Tue Apr 26, 2016 9:28 am Post subject: Re: Transmission quandary (manual) |
I had a tranny with a 0.77 fourth gear and did not like the power loss going up hills, even with the EJ25 (slightly taller third too). When I had to get that trans rebuilt I went back to stock gearing and am very happy with the result. IMO too many folks try to reduce the rpm on the highway (I was one of them) when the EJ22/25 is happy to run at 4000 rpms all day long.... I think I am currently going 3800 rpm at 70 mph with 205/70/15 tires. YMMV. _________________ Dave O
chompy Samba Member
Joined: August 12, 2014 Posts: 400 Location: Cascade Locks
Posted: Tue Apr 26, 2016 9:46 am Post subject: Re: Transmission quandary (manual) |
bobbyblack wrote: |
dobryan,
Thanks |
The EJ22 has no problem running at 65 MPH with the stock gearing. I would stick to stock, or if you wanna spend some $$ go to the subarugears 5 speed setup. Then you don't even have to worry about rebuilding your transmission or purchasing the adapter kit. _________________ '81 Westfalia Subaru EJ22
Manual Transmission |
Posted: Tue Apr 26, 2016 11:29 am Post subject: Re: Transmission quandary (manual) |
Last I looked, the suabgeers was quite pricey. Not sure how to manage that.
I had to go take a look on the road. 14" rims with BFG AT KOs I think 195/75/14
Looks a lot like about 3600 @ 60 ish (speedo is off a bit)
Oh, and look at what the PO had sitting above the cluster:
Anyone notice? I drove it for a while with the 'wash-me-out' 90 weight oil over lunch, and she turned 275K (admittedly, I drove it more than just my allowed time for lunch, me bad )
The shifting was for crap. Very hard to push into 1st when standing. Can't downshift into 2nd, or 1st.
Redline MT90 comes tomorrow. Will drain it overnight again tonight. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9610 Location: Western WA
Posted: Tue Apr 26, 2016 11:35 am Post subject: Re: Transmission quandary (manual) |
bobbyblack wrote: |
and put in the taller stuff for lower RPMs at 65mph. |
If you plan to use larger wheels than stock I don't think you should change the gearing.
One thing to note, your drainplug was MAXXED. It cannot pickup any more funk. The rest of that funk was circulating in your trans, a helluvalot more. Sorry, and YIKES. I'd fill it with FLAPS oil, and run it again, see whats in there the 2nd time.
If you put a shopvac sucking on the filler hole, you can R&R the drainplug, not losing even a drop. Shopvac doesn't have to fit tightly on the filler hole, in fact will suck out all the oil bubble-spray, so be sure to make it suck thru a rag. It's a bit of trouble, but fun in a way.
Here's what I would do.....
I'd run the van with fresh FLAPS oil, then park it for as long as you can (a week?) then drain the bottom (dirtiest, settled) pint off into a clean white pan, and inspect it. It's EASY to drain off the bottom pint. Take the plug out, then put it back in, no problem. I'd clean the area around the bunghole first though, don't want any dingleberries falling into your white undies that you will be inspecting.
Or if you set a bright light (like a sunset?) where you can see thru the stream, remove the plug then stuff it back in as soon as the oil clears up (thus removing the dark oil). Then replace the settled, contaminated inspection oil, with clean fresh oil. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Tue Apr 26, 2016 11:45 am Post subject: Re: Transmission quandary (manual) |
Sodo,
Sounds a lot like I should not waste the MT90 that will be coming tomorrow. I did run a while with some standard 90wt man-trans oil (no FLAPS around here, just tractor place) I think I put on 50 miles over 'lunch'.
I was going to just drain that out again tonight. I also got 2 gallons of that 90wt, as I use the same stuff in my toro gang mowers. I could wash it out a couple times, really. I can also use the oil in my dual-fuel furnace (wood/fuel oil) so nothing truly lost, really. Maybe not 'green' in most eyes, but not as wasteful as some. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Sodo Samba Member
Posted: Tue Apr 26, 2016 11:58 am Post subject: Re: Transmission quandary (manual) |
I'm pretty sure you can only drain 2/3 of the oil in there, 1/3 remains captured. There are two issues WRT this.
1) You won't have fresh MT90, you will have 2/3 fresh MT90 mixed with 1/3 highly contaminated oil.
2) I you flush once you will have 2/3 MT-90 mixed with flush oil that's "2/3 cleaner than the dirty oil" which is not all that comforting.
3) If you flush twice you will have 1/6 dirty oil and 5/6 MT-90
It goes on and on getting cleaner and cleaner. Theres something to be said for flushing it twice, or more than 3x, with lighter oils such as ATF or even used motor oil if you happened to KNOW it was drained a sanitary manner. Or go ahead and drain your engine (carefully) and use that. Oil that was in an engine is much better than the metal-contaminated oil that's in your trans. Don't drive with light oil in there, do it wheels spinning on jackstands not driving. Not sure expensive oil is your friend here. Clean FLAPS often is probably better (IMHO).
No doubt your trans needs to come apart, but clean oil at least slow the decline. _________________
Posted: Tue Apr 26, 2016 12:07 pm Post subject: Re: Transmission quandary (manual) |
Not totally sure on the fully drained vs partial. I read about a dozen threads on that topic, came to the understanding that raising the front up was the method to get a full drain. I have my shop setup with a set of "docks" and then ramps down to the floor, the effect was "raised front" as I backed it down the ramps about half way. The docks allow me to have a couple feet of clearance below my vehicles to do stuff like oil changes, etc. Not a true oil pit, but something sort of close, I guess.
Anyway, I am sure that more oil came out with it on a slant than flat. Not sure of how much more, but at least some more. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Syncro Jael Samba Member
Posted: Tue Apr 26, 2016 12:48 pm Post subject: Re: Transmission quandary (manual) |
If you have access to or want to purchase a video scope you can inspect some of the internals without removing the tranny. You can take a good look at the R&P for sure.
If I was planning to spend the coin on an engine conversion, I'd also add a rebuilt transaxle. Then you should be worry free for many miles. _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
Posted: Tue Apr 26, 2016 1:00 pm Post subject: Re: Transmission quandary (manual) |
ugh.. ya, I am getting a sinking feeling. Big brakes, canvas for pop-top, window seals, door seals all now on chopping block to accommodate transmission project.
Damn this budget crap!!
So, I guess, I better find out if there are any decent rebuilders in the midwest, (Im nearest to Minneapolis) or if a Rancho on a Grayhound ticket is within reach.. Core or shipping mine out needs clarity. Grrr, downtime!!! _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Tue Apr 26, 2016 1:24 pm Post subject: Re: Transmission quandary (manual) |
Found a used one from a '90 with 5 year warranty, free shipping. just under $900.
Here in 3 days...
Good deal? _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Sodo Samba Member
Posted: Tue Apr 26, 2016 1:51 pm Post subject: Re: Transmission quandary (manual) |
Sounds too good to be true. R&R is worth $400-$600, that won't be covered if you find its a worn out unit.
Wonder what their warranty is. For example if the drainplug magnet has a wild afro what will they do? What if someone already looked at it, did they wipe it off? Wouldn't anybody who had it out? Will they give your money back if you remove the bellhousing and LOOK, and find funk in there?
This tranny thing has a lot of pitfalls, pretty much have to take your chances. could be less risk applying the money towards a rebuild by a good shop. But it could be a LOT depending what they find in your trans. _________________
hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Tue Apr 26, 2016 1:54 pm Post subject: Re: Transmission quandary (manual) |
That depends on who did the rebuild...
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
Posted: Tue Apr 26, 2016 2:04 pm Post subject: Re: Transmission quandary (manual) |
What year did the 3/4 slider go from a square hole to an oval one? Seems like around 86 or 87?
The $900 one is used, not rebuilt. Hence, a 'take your chances' kind of deal.
I agree, who wouldn't take a look at the plug, and get the hair off it...
I am starting to get a nervous sweat. I don't like having to backtrack on my budget. I guess I better find my 'cool-zone' again, and just do what feels right. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Sodo Samba Member
Posted: Tue Apr 26, 2016 2:09 pm Post subject: Re: Transmission quandary (manual) |
I think it was 1989 1/2?
Unlikely a '90 trans has never been rebuilt. And depending in who's been in there, maybe several times. _________________
