dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Apr 26, 2016 4:51 pm Post subject: Re: Transmission quandary (manual) |
From GoWesty, FWIW:
Quote: |
It is unknown when the updated [3-4 syncro hub] was introduced into vehicle production, but it is thought to be sometime in late 1989 (first used in 1990 year-models).
Over the years we have documented the date code on the side of each transaxle we have disassembled in an effort to try and determine when the change took place. So far, the earliest transaxle we have disassembled with the updated part already fitted is trans # ACW 09030 (read: ninth day of March, 1990).
So, if your Vanagon was manufactured in 1988 or earlier, you’re in trouble. Get it replaced before it breaks. If it was manufactured in 1989, you might be OK... |
_________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Wed Apr 27, 2016 6:25 am Post subject: Re: Transmission quandary (manual) |
Thanks dhavvers, with info from GoWesty. Much appreciated.
It was a bad night of sleep.
Yesterday, I took the rig home, and couldn't help wondering just what the heck to do. I sold my '67 doublecab to fund this little adventure, and it didn't bring as much as I asked, but I had to get going on this. Now my budget is getting skewed. I will look for a used 90 or 91 and consider the serial number info relevant. I would guess getting mine shipped out, rebuilt, and shipped back would be a lengthy ordeal, and the 'season' is fast approaching!!!
Yet another issue that just started to pop up the evening that I was 'warming up' the original-to-me trans oil: a slight clutch shudder. As I drove home last night it occurred to me that there is probably some kind of oil starting to leak into the clutch area. I had this happen in a Bay in 1988 on the way up to AK. It was the transmission main seal. Not a hard part to deal with if the engine weren't in the way. Ended up with a burned flywheel.
So, it looks much like this at this point:
Get the used '90+ transmission.
Get the swap kit.
Sell the 2.1 WBX to my friend, so he can go camp with his family (wife and 2 kids) and maybe use those $'s for the brake kit.
See whats left in budget for canvas, door seals and new window seals, so I can get the whole thing sprayed after I get the dings out.
Ugh! Why did I want yet another VW!!!!
(ok, its called Love) _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Posted: Wed Apr 27, 2016 7:11 am Post subject: Re: Transmission quandary (manual) |
dobryan,
Regarding the big brakes; I drive this full Westy with a heavy load. Camping gear, bikes, and my 3 kids. They are all adult size people. Not quite adult years, but gaining at an alarming rate. Sometimes I let my kids drive the rig. They are used to modern cars. We mostly drive Toyota Highlanders. Huge engines, and huge brakes. I like them for the stuff they are good for. I mainly like them for passing the slow-pokes going less than 60, on two lane roads. Get-r-up, get-r-back-down, speed wise. Going back and forth from rig to rig can cause some slight differences in how brakes bite to be the difference in inches or microseconds that makes or brakes the deal when in an unexpected situation. I'd like the added microseconds, if I can get them for a reasonable price.
Also, it seems like a package deal, going to the EJ22, put in the upgraded brakes to match.
I know its not a true necessity, and therefore it got put later in the plans now that I have to consider the transmission issue.
I am also pretty positive about the 2.1 WBX, as I did the reseal myself, finished on December 23rd '15. I could just go with the WBX for a while and hope the 2.1 rod bolts hold. I don't really mind the 0-60 times near a minute.... Oh wait. Yes, I do. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Wed Apr 27, 2016 7:57 am Post subject: Re: Transmission quandary (manual) |
Well... the right oil is here. I guess. I don't believe it should be put in what I have now. Way to spend $57 for something I won't use for a while.
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Wed Apr 27, 2016 11:09 am Post subject: Re: Transmission quandary (manual) |
bobbyblack wrote: |
Not totally sure on the fully drained vs partial. I read about a dozen threads on that topic, came to the understanding that raising the front up was the method to get a full drain. I have my shop setup with a set of "docks" and then ramps down to the floor, the effect was "raised front" as I backed it down the ramps about half way. The docks allow me to have a couple feet of clearance below my vehicles to do stuff like oil changes, etc. Not a true oil pit, but something sort of close, I guess.
Anyway, I am sure that more oil came out with it on a slant than flat. Not sure of how much more, but at least some more. |
You could be right..... I added a front drain hole to my transaxle a few days ago. Today drained oil with front wheels 9" high, and nothing (only 5 drops) came out of my (new) front drain. I did not measure fluid volumes so I don't know what to conclude. Other than 9" high seems to drain pretty good. _________________
....KTMs, GasGas, SPOT mtb
Posted: Wed Apr 27, 2016 11:44 am Post subject: Re: Transmission quandary (manual) |
From a cross post, found while waiting for the next available agent...
crazyvwvanman:
DK - 80-83 aircooled
DU - 83-84 WBX
ABD - 85-86 WBX
ACW - 86-91 WBX
DX - 83 diesel
Mark _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Wed Apr 27, 2016 8:26 pm Post subject: Re: Transmission quandary (manual) |
I drove about 100 miles and I again drained the MT oil. I didn't see any chunks in the oil tonight, but I did see a froth. However, there was indeed a bit more metal on the oil plug. Way less, just saying 'some'. The stuff that had been left in the case at first change I guess. More fir.
On my roughly 100 mile run, the second half I was able to catch 2nd in downshifting remarkably better, and even the 2nd to 1st was more slick on 8 of my 10 tries. Pulled downshifting from 2nd to 1st significantly better!?!?!?
I got to wondering if I was imagining things. Perhaps the shudder I feel on clutch release may not be what I was remembering from '88 in a Bay - a transmission main seal leak. Could it be something in the hydraulic clutch causing the shudder, or perhaps a failed clutch component causing imbalance? Cracked spring?
Still scratching my head here.
btw: nobody ever picked up the call I repeatedly placed to the 877 number for the used transmission I've been courting. Rang and rang and rang, then the automated attendant said to hold on, and i would be helped in the order I had called. Seemed like I was getting gamed. First guess I had was that they listed a 1992 Vanagon.
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Wed Apr 27, 2016 9:53 pm Post subject: Re: Transmission quandary (manual) |
"MTL, MT-85 & MT-90 are not for use in differentials with hypoid gears"
http://www.redlineoil.com/Products.aspx?pcid=7
Quote: |
Well... the right oil is here. I guess. |
_________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Thu Apr 28, 2016 4:49 am Post subject: Re: Transmission quandary (manual) |
gears, TP,
You both have points, well taken into consideration. Many posts on just your references. Im no expert here. Just going off dozens of other posts, and information that seems relevant to the topic.
It is true that the hypoid language does accompany the product. However, the degree of the hypoid nature in the 091 is supposedly low enough to put that portion of concern into a lower category. This is not my science here, it is from what I have gathered through reading.
Anyway, my present concern is more to do with the developing shudder as I take my foot off the clutch pedal. I did have fair success with dowshifting into 2nd and 1st yesterday. Its more that the whole system is getting too tired.
Looking more and more likely that the WBX will be coming out. I swore a promise to myself that when that engine came out, it was getting a conversion. The WBX is fine if it just stays, but now that it seems to need to come out, I am trying to stay on track with my promises.
Im just trying to line up a different transmission now. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
insyncro Banned
Posted: Thu Apr 28, 2016 4:55 am Post subject: Re: Transmission quandary (manual) |
Swepco 201 |
Posted: Thu Apr 28, 2016 7:42 am Post subject: Re: Transmission quandary (manual) |
from another thread:
John Sullivan wrote: |
Air in the system can cause a similar problem. Especially not able to get to reverse as you described. Then later first gear, as the air increases in the system. The hydraulics will not disengage the clutch. I would suspect the slave cylinder but could be the master. As the others have stated. Bleed the system and if it starts working again, determine which end is failing. Also look for brake fluid leaking (in the clutch system). That will tell the tail. Hopefully it is not the actually the clutch but something on the outside. |
Wildthings wrote: |
If you have normal clutch pedal action then the problem is most likely not in the hydraulics or even in the clutch proper unless the disc is falling apart. My guess would be a bad pilot bearing as they are want to fail suddenly and make for hard shifting when the engine is running, particularly at idle. If you have driven many miles at all since the problem first started then expect the input shaft to have been damaged pretty badly. The clutch release shaft and the little arm on the end of it need to be examined carefully as well.
Since you are paying someone else to do the work, go ahead and have a clutch kit put in and if you can locate one a new tranny input shaft. If I were doing this job for myself I would do the rear main seal (Sabo from Go Westy) and the tranny input shaft as well. If it is a pilot bearing failure then the slinger behind the tranny input shaft seal needs to be checked for a tight fit as well. |
I better check twice on all this before I get too hot on buying a used 091 _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Abscate Samba Member
Posted: Thu Apr 28, 2016 7:45 am Post subject: Re: Transmission quandary (manual) |
Im seeing residual fir from the delayed first change. If you did one more change I bet you would have almost none. I wouldn't even change it again, though, just clean off the tiny bit and run happy.
Monitor that clutch to see if its getting worse. Dont sweat the transmission. _________________ .ssS! |
Sodo Samba Member
Posted: Thu Apr 28, 2016 8:39 am Post subject: Re: Transmission quandary (manual) |
Just wanna note that if you used $15 FLAPS 90 GL5 for first flush, you could do the 2nd flush/change at the drop of a hat..... (only $15 'loss'). To prolong usage of a worn out trans I'd be inclined to use a thicker, wickeder oil than MT-90. After a thorough flushing you can observe the magnet and discern between new afro or old afro. Or assume.
This is some hardcore shadetree, not sure if you're wired for that but you do have a type1 on your avatar.
If you're inclined to "reclaim" that fancy MT90,,, note that the metal in it will drop to the bottom, and if you decant the clear fluid off the top you can (elect to) re-use probably 95% of it. I don't know how long this takes, (a week? a month?) but you can notice a significant stratification and clarity just overnight. It's also reasonable to drop a magnet into the container and shift it slowly, carefully around daily. Last position should be where it won't shift while decanting.
Maybe attach a wire to the magnet. On a plastic bottle you can use a 2nd magnet on the bottom, to hold, or to move the magnet inside. Collect a load of hard drive (rare-earth) magnets, and "tile" a "settling pad" for your plastic jug purification station. Just an idea.
Note that a rare-earth magnet out of a hard drive has a large surface area, perhaps 10x the capacity to capture and hold steel, as the drain magnet. Now if you had 20 of them you could capture some steel. _________________
Posted: Thu Apr 28, 2016 9:22 am Post subject: Re: Transmission quandary (manual) |
Yes, I do have type 1, but the one in my avatar had a bad lower ball, and my dad had it crushed while I was in FL one summer since he hadn't seen it driven in a while. I have a Ghia now to cover my type 1 slot. In the Type 2 category, I have a '65 Deluxe as well as the '87. My dad crushed 2 of my type 2 T2's as well, one was a tintop full camper and even a driver... I have a '63 Type 3 Notchback too.
My dad was just trying to clean up the yard. Perhaps he has gotten a better idea now that I have sold a few of my other Type 2 splits recently. I didn't mention the ones he crushed, I just let him do some thinking on that.
One friend of mine told me he had bought 37 cars to drive in his life, and I was the only person who he knew that had bought more cars that drove. I didn't mention to him that I had about as many that I got for a few dollars that didn't run. Most of those were 1$, just to have a paper trail, those people just wanted them gone. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Sat Apr 30, 2016 2:02 pm Post subject: Re: Transmission quandary (manual) |
Today I finished the clutch bleed. Well, I should say, I ran a quart of brake fluid through the system, used the whole thing. It did finally run clear. Then I went for a spin. I noticed that the clutch was a lot easier to get into gear with the new transmission oil. Hardly any shudder or chatter or whatever that is called. However, It became clear very quickly that there is something else wrong. The clutch is not holding well at all. I have to think a while on this.
Seems that either my idea that there is a leak inside the bell housing, oil of some sort getting on the clutch disk, or somehow, the bleeding process has made the clutch not fully engage. Can air in the system make it not fully engage? I thought it was the other way around. I noticed in the parts cache that the PO left, there is a spare, probably the previous one. Maybe I better take a look at that, to see if it gives up any clues.
I have to wonder now, do people take out transmissions without taking out the engine? Just trying to get around my promise to myself regarding the next time that the WBX comes out, it gets replaced. There doesn't seem to be anything specifically wrong with the engine. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Sat Apr 30, 2016 2:18 pm Post subject: Re: Transmission quandary (manual) |
Yes. Way easier to remove trans w/o removing engine. Still a bit of a pita but not horrible. Syncro trans are more time consuming |
gears Samba Member
Posted: Sat Apr 30, 2016 9:07 pm Post subject: Re: Transmission quandary (manual) |
The two versions of updated OEM hub are shown in this photo. The one at 3 o'clock isn't much better than the square slot one at the top. The nitrided one on the bottom is way more reliable, and the Weddle one at the left is the most reliable.
'87 Syncro GL 2.5
Posted: Thu May 05, 2016 8:09 am Post subject: Re: Transmission quandary (manual) |
Good webpage on transmission removal, engine left in.
http://volksweb.relitech.com/clutch.htm _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
