MegantheVanagonOwner Samba Member
Joined: April 29, 2016 Posts: 4 Location: Portland, OR
Posted: Fri Apr 29, 2016 8:26 am Post subject: Air-cooled: Major oil leak |
Hi all! I'm new to this forum as well as new to being a Vanagon owner! Just trying to do some troubleshooting. My van has an oil leak. It will leak before it even gets to running. Overnight, it can leak about a half quart of oil (if I put that much in). It's not leaking down in one spot, but rather dripping down in three to four spots off of that panini press looking piece (please don't judge me! Hah).
Anyone have any guesses or places to start looking? |
Terry Kay Banned
Posted: Fri Apr 29, 2016 8:35 am Post subject: Re: MAJOR oil leak |
This leak identification operation will take some investigating--
Crawl under the back end of the van, look up, and take a good look to locate where it may be coming from. _________________ T.K. |
newfisher Samba Member
Joined: January 05, 2012 Posts: 1764 Location: The wet spot--Oregon
Posted: Fri Apr 29, 2016 8:56 am Post subject: Re: MAJOR oil leak |
Welcome.
If its an air cooled, you may have to pull the lower shrouding down to see further up. Don't rule out items above r on top that may be letting oil run down. This isn't as likely as you say it leaks when not running and the oil is in the bottom portion of the engine. Push rod tube seals? Best guess without pics.
Clean the areas with Simple Green or Purple Power and a rag or compressed air to dry. this will give you a better idea of the path from the oil
Make sure you inspect furl lines wile you are looking around |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Fri Apr 29, 2016 9:09 am Post subject: Re: MAJOR oil leak |
welcome
please tell us what year your van is.
the pannini press looking thing is the bottom of the crankcase.
if it's leaking without even running i would have to suspect the drain plug or its severely over filled.
could be other options depending on year.
hope you're ready for a crash course in mechanics. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Fri Apr 29, 2016 11:37 am Post subject: Re: MAJOR oil leak |
Thanks for the replies so far!
It's a 1980 air cooled, and yes, I've been well prepped for my upcoming crash course in mechanics |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Fri Apr 29, 2016 11:44 am Post subject: Re: MAJOR oil leak |
Easiest thing to check is the valve cover gaskets. They can easily leak as you've described.
Are the air cooled vanagon valve covers the same as the busses? They're just held on with a spring wire. _________________ 89 Westy 2.1 Auto |
nacradriver Samba Member
Joined: January 15, 2009 Posts: 760 Location: Ventura, CA
Posted: Fri Apr 29, 2016 11:56 am Post subject: Re: MAJOR oil leak |
MegantheVanagonOwner wrote: |
Water cooled? Check the oil cooler that is between the filter and the engine My van sat for a few years prior to my getting it and the seal dried up and was causing some scary leaks...
Hope this helps. _________________ Güdrun -1989 Westfalia - 2013 - 2018
Petra - 1985 Vanagon - 1985 to 1991
Zisa - 1974 VW Van "Bus" - 1974 to 1985 |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Fri Apr 29, 2016 1:48 pm Post subject: Re: MAJOR oil leak |
What's a "panini press" and will it make my Van go faster?
Seriously, though, a few pictures of the leak area are worth a few thousand words. _________________ '86 Syncro Westy SVX |
Posted: Fri Apr 29, 2016 1:54 pm Post subject: Re: MAJOR oil leak |
Posted: Fri Apr 29, 2016 6:57 pm Post subject: Re: MAJOR oil leak |
on an air cooled, T4 engine the "taco plate" (rear, right) and strainer plate (middle) would be prime suspects.
if it's leaking while not running from anywhere other than the drain plug or these two places, it is overfilled with oil, possibly oil/gas mixed.
use caution on the strainer plate nut. it is only torqued to 7ft/lb!
if it's already broken, then you are in pretty deep dookie.
good luck! _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
