ArtistGollaher Samba Member
Posted: Fri Apr 29, 2016 4:22 pm Post subject: O-ring flywheel fit on a 1300 non o-ring crank? |
Quick question. I looked at other posts and got mixed answers. I have a 1300. It has a 6v 180mm non o-ring flywheel on it and I need to put a 12 volt 200mm o-ring flywheel on it. Will it fit? _________________ '63 Beetle 1300 Black
'67 Beetle 1500 Zenith Blue
'67 Beetle 1600 Olive Green |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Fri Apr 29, 2016 5:52 pm Post subject: Re: O-ring flywheel fit on a 1300 non o-ring crank? |
Short answer: No.
Long answer, you can have the flywheel machined to remove the O-ring portion, and use the metal gasket. _________________ Andy T.
I do not know how to fix this. All I can say is it all works fine for me with what I use, Firefox.
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Fri Apr 29, 2016 6:30 pm Post subject: Re: O-ring flywheel fit on a 1300 non o-ring crank? |
Yep, that's the answer...on the flip side, a non-o-ring flywheel can work on an o-ring crank.
Why do you need the 12V flywheel? You could keep the 6V starter and flywheel and still run 12V's...Use a 12V solenoid on a 6V starter and it will last a long time...starts the engine much faster as well |
Posted: Fri Apr 29, 2016 9:12 pm Post subject: Re: O-ring flywheel fit on a 1300 non o-ring crank? |
Thanks guys! I have a 67 bug 12volt. And my 1300 is 6v that I will be putting in. So looks like I'm going to put a 6v gear into my 12v starter. Thanks again for the help! _________________ '63 Beetle 1300 Black
txoval Samba Member
Posted: Sat Apr 30, 2016 3:44 am Post subject: Re: O-ring flywheel fit on a 1300 non o-ring crank? |
You actually have the opposite of what I described.
I thought you had a 6V car...pre-67
A 12V starter will not work with a 6V flywheel. You need to modify your o-ring flywheel as suggested above by glutamodo |
splitjunkie Samba Member
Posted: Sat Apr 30, 2016 8:41 am Post subject: Re: O-ring flywheel fit on a 1300 non o-ring crank? |
txoval wrote: |
His car is a '67. _________________ Chris
