Turmoil Samba Member
Posted: Fri Apr 29, 2016 6:15 pm Post subject: 1960's Spatz Buggy Build with 1972 Super Beetle Chassis. |
I picked up a 1972 Super Beetle a few years ago with the intentions of fixing it up. Well that plan never really got going and when talk of a dune buggy build started with my boy, the search for a body was on. We live on an island so getting it home was as big of a challenge as finding one. We located one luckily on Craigslist on Cape Cod and headed off in my truck to bring it home.
Before we could get started, we had to finish the garage. Buggy had to sit outside for a little longer.
With the garage finished, the project will soon get started!
[/size]
weasel_ugs Samba Member
Joined: March 16, 2012 Posts: 721 Location: Prescott Valley,Az.
Posted: Fri Apr 29, 2016 7:45 pm Post subject: Re: 1960's Spatz Buggy Build with my 14 year old boy! |
If your planning on using the super beetle as a donor you cant use the pan unless you change the pan head.
Very nice garage. |
andygere Samba Member
Joined: January 31, 2014 Posts: 600 Location: Central Coast, CA
Posted: Sat Apr 30, 2016 6:35 am Post subject: Re: 1960's Spatz Buggy Build with my 14 year old boy! |
Nice looking shop, are you on the Vineyard? The first dune buggy I ever saw was heading out on the Provinceland dunes in the early '70s. I wonder if yours ever prowled the sand up there? |
Posted: Sat Apr 30, 2016 6:07 pm Post subject: Re: 1960's Spatz Buggy Build with my 14 year old boy! |
Thanks for the shop comments, really excited to finally have it finished! We live on Nantucket.
We had great fun taking the body off. Saving a few things and not saving a lot of things.
Chassis cleaned up and ready to be stripped. Frame head ordered and now time to try and find a ball joint front end. I want to stick with the 4 lug look.
Posted: Sun May 01, 2016 5:47 pm Post subject: Re: 1960's Spatz Buggy Build with my 14 year old boy! |
Not to much progress but did manage to get all the super beetle front suspension removed or cut off. Will tackle the napoleon hat soon.
I have this ordered and on its way
Posted: Sun May 01, 2016 10:33 pm Post subject: Re: 1960's Spatz Buggy Build with my 14 year old boy! |
Looks like god progress to me. Keep up the good work. |
Posted: Tue May 03, 2016 5:05 pm Post subject: Re: 1960's Spatz Buggy Build with my 14 year old boy! |
Well removing the napoleon hat bracket and remaining front super beetle frame head was NOT fun! I spent the time to drill out the spot welds but the places it was welded did not come apart easy. I made a mess of the hat.
I was looking at another post and noticed a frame head with the napoleon hat attached. I was wondering if anyone had a thought on who sells them, I have not had any luck locating one. The frame head I have ordered does not have the hat attached.
Thanks |
Posted: Thu May 05, 2016 5:35 pm Post subject: Re: 1960's Spatz Buggy Build with 1972 Super Beetle Chassis. |
Not much happening outside of a stripped chassis and a a lot of parts cleaning.
Posted: Sun Feb 05, 2017 4:21 am Post subject: Re: 1960's Spatz Buggy Build with 1972 Super Beetle Chassis. |
I haven't updated in awhile but we have made good progress.
Frame marked and cut. Took our time and made straight cuts.
Fitted the pieces back together and experimented with temperature setting on new welder.
Back together with new frame head for ball-joint front end. |
David17HMR Samba Member
Joined: November 29, 2016 Posts: 1 Location: NW corner of Iowa
Posted: Sun Feb 05, 2017 9:07 am Post subject: Re: 1960's Spatz Buggy Build with 1972 Super Beetle Chassis. |
Looking good _________________ 64 pan Spatz body |
rubenski Samba Member
Joined: December 03, 2014 Posts: 100 Location: belgium
Posted: Sun Feb 05, 2017 7:32 pm Post subject: Re: 1960's Spatz Buggy Build with 1972 Super Beetle Chassis. |
x2 |
EVfun Samba Member
Posted: Sun Feb 05, 2017 10:53 pm Post subject: Re: 1960's Spatz Buggy Build with 1972 Super Beetle Chassis. |
Clean work. I have one bit of advice. The frame tunnel has been known to crack starting with the slots for the heater controls. I would recommend taking some of the metal from the section you cut out and using it to weld up and remove those slots in the frame. _________________
Wildthings wrote: |
hillmotorsports Samba Member
Joined: December 27, 2014 Posts: 432 Location: Morrisburg, Ontario, Canada
Posted: Mon Feb 06, 2017 4:39 am Post subject: Re: 1960's Spatz Buggy Build with 1972 Super Beetle Chassis. |
If you can pry them out of Brad's hands Turnkey Manx make a gorgeous reinforcement for that part of the frame, as well as another for the pedal area. _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
(With way more projects than spare time!) |
Posted: Sat Feb 11, 2017 5:04 pm Post subject: Re: 1960's Spatz Buggy Build with 1972 Super Beetle Chassis. |
Thanks! Good call on the heater control cuts, they will be welded up soon.
Started on the 3" body lift. 1 1/2" x 3" tube stock.
Used a plasma cutter to narrow for correct fit.
Rear piece ended up lower but will deal with that later.
Finished the rough fit.
All welded up. |
Posted: Thu Feb 16, 2017 5:05 am Post subject: Re: 1960's Spatz Buggy Build with 1972 Super Beetle Chassis. |
Fitted the body before welding 3" frame to chassis.
Finishing the end caps and stitch welding everything solid.
Double checking seats track correctly.
Posted: Thu Feb 16, 2017 6:37 am Post subject: Re: 1960's Spatz Buggy Build with 1972 Super Beetle Chassis. |
You might consider drain/vent holes in the lower part of all your 3" tunes, at least to allow condensate to drain. Otherwise I would be concerned about internal corrosion. _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
Posted: Sun Feb 19, 2017 4:27 am Post subject: Re: 1960's Spatz Buggy Build with 1972 Super Beetle Chassis. |
Chassis painted with etching primer.
3M Seam sealer next.
Lastly, U-Pol Raptor bed liner. MAKE SURE YOU WEAR GOOD RESPIRATOR, THIS STUFF IS BRUTAL!
cudabear Samba Member
Joined: January 27, 2012 Posts: 65 Location: Lk Mary FL
Posted: Sun Feb 19, 2017 6:21 am Post subject: Re: 1960's Spatz Buggy Build with 1972 Super Beetle Chassis. |
Very nice quality work. |
joescoolcustoms Samba Member
Posted: Sun Feb 19, 2017 9:19 am Post subject: Re: 1960's Spatz Buggy Build with 1972 Super Beetle Chassis. |
Very nice high level quality work. That will make a very nice solid chassis. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Sun Feb 19, 2017 10:20 am Post subject: Re: 1960's Spatz Buggy Build with 1972 Super Beetle Chassis. |
Thank you, we appreciate your words! |
