samander Samba Member
Joined: October 01, 2013 Posts: 166 Location: Victoria, BC
Posted: Thu May 12, 2016 12:23 pm Post subject: 91 Vanagon 2.1 Ticking and Loss of Power |
Hello! I have just recently purchased a 1991 Westfalia with a 2.1 litre engine and am in need of your assistance! I went out to start the beast today and there was a fairly loud ticking sound at idle and when I accelerate. I figured it was lifters so took it out for a spin. I was out and realized I have severe power loss and ended up bogging right down at the VW dealership. It fired up again, still with ticking noise and loss of power. This engine, according to the mech history, was rebuilt 25,000 km ago and I just recently did an oil change, water pump replacement, and coolant flush. I was wondering if anyone has any ideas or input they are willing to share! Really hoping this is something simple. I was out yesterday with absolutely no issues. Thanks in advance!
EDIT: here is a video I took this morning to give you a better idea. It sounds like the classic lifter tick we read about here but the loss of power is definitely concerning.
NoNameNeeded Samba Member
Joined: July 31, 2014 Posts: 150 Location: Seattle, WA
Posted: Thu May 12, 2016 1:51 pm Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
What oil did you use? I learned quickly that my 2.1 didn't like 10-40 but loves 20-50......until the temperature drops below freezing. _________________ No matter how I struggle and strive
I'll never get out of this world alive.
Hank Williams |
Posted: Thu May 12, 2016 1:56 pm Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
Interesting, I was told at store to use 10w-30... could this have caused it? |
Posted: Thu May 12, 2016 2:02 pm Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
samander wrote: |
Yes. I had the same issues with thin oil, my lifters wouldn't pump up and were ticking and I had a loss of power. I use 20-50 Castrol and a Napa filter. _________________ No matter how I struggle and strive
Hank Williams |
Posted: Thu May 12, 2016 2:25 pm Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
Thanks I will look into this! The oil was changed last week, however and only today did the problem arise...I feel like something must have changed for this to happen? |
bluebus86 Banned
Posted: Thu May 12, 2016 4:09 pm Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
I got a mechanic to hopefully make a diagnosis and apparently after it entered the shop they haven't been able to manipulate it and find out what it is.. |
Thom and the Flat Rats Samba Member
Joined: January 25, 2014 Posts: 24 Location: Vancouver, BC
Posted: Thu May 12, 2016 9:46 pm Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
The light oil can definitely cause the problem. I've always used 20-50 but when I took a trip across Canada I had the oil changed and the idiot substituted with their stock oil (10-30). I noticed a loss of power on the freeway about a half an hour later.
I had to floor the van going up small inclines on the freeway and couldn't get it to go over 60 MPH. I pulled off the freeway and ended up gearing down to 2nd on a small hill and couldn't get the van above 20KMH.
Had a garage dump the oil and replace it with 20-50 and it took about 50KM before the power came back to normal. I was fortunate that I didn't fry the motor and it still doesn't burn a litre between oil changes. |
Terry Kay Banned
Posted: Thu May 12, 2016 10:09 pm Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
Get the correct oil in it and the problem will resolve itself.
The oil is way too light for that engine.
You may have to drive it awhile, but the lifter click will go away.
Read your owner's manual or the Bentley shop manual.
It's written in both of these manuals--what weight oil to use.
I'm assuming you are not driving the van in Siberia--where 10/30 would be appropriate. _________________ T.K. |
Posted: Thu May 12, 2016 10:41 pm Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
Thanks for the feedback guys. I will be changing that oil out very soon. Bummer because I ordered the proper Mann filter and everything. Think it can still be reused being that oil and filter was changed last week? The mechanic found a bad ground near the distributor which could have been associated with the random loss of power as well.
here is a video of the idle without the ticking. Sound more "normal"? Sure is driving much nicer!
Posted: Thu May 12, 2016 10:45 pm Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
samander wrote: |
It sounds better now that the lifter is pumped back up. You should be able to use the same filter just take it off and drain it. _________________ No matter how I struggle and strive
Hank Williams |
Posted: Thu May 12, 2016 10:48 pm Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
I wouldn't bother changing the filter just the oil |
Posted: Fri May 13, 2016 8:06 am Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
Ok will do, thanks guys! What is your take on synthetic? Ive read that it can lower the engine temperature a bit? |
Terry Kay Banned
Posted: Fri May 13, 2016 8:27 am Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
I think you should leave the Dino oil in the engine--
Don't complicate the issue mid stream.
If the engine started with dino for who knows how many miles, leave well enough alone.
Want to add something to the oil?
Drain 1 quart of oil outa the engine, add 1 quart of Marvel Mystery Oil.
It's clean up the inside of the engine, and keep the lifters squeaky clean--
Pour a pint in the gas--it'll clean out the injectors, and lube the valve stems.
This is the best you can do for that engine. _________________ T.K. |
Posted: Sun May 15, 2016 11:57 am Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
I have tracked down some mystery oil and added it to oil and fuel. We will see!
I am having a strange issue still however. After about 5 minutes of driving, engine bogs down and stalls. I am able to restart it right after and after 2-3 times it runs normally again. No lights come on during this process. When I try and accelerate to save it, it just bogs! This only happens after a certain amount of driving then goes away after engine warms up a bit. Engine starts cold normally and idles around 900 without stalling. Only after I hit the road. Anyone? Thanks in advance! |
Posted: Sun May 15, 2016 12:57 pm Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
samander wrote: |
Next time let it warm up completely before you drive it and see if it still dies. _________________ No matter how I struggle and strive
Hank Williams |
Posted: Sun May 15, 2016 2:13 pm Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
Took her out for a spin today and it didn't stall, but definitely a little hesitant to start. Especially after stopping at a light then accelerating. I noticed One of the large hoses (back right corner) connecting to air filter wasn't clamped tight. Also checked timing which was good. |
Posted: Mon May 16, 2016 8:51 am Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
Just an update: I have found that the stalling on acceleration occurs only after about 1-2 km of driving. I throw it in neutral or park depending on if stopped or moving and usually regain power again. After that it's perfect! Any ideas?? It seems more electrical related no? |
bluebus86 Banned
Posted: Mon May 16, 2016 9:23 am Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
you mkght want to look in to the hall sendor, mine had an intermittant problem simular to you, cutting out once and a while, then magically recovering. had the dizzie put on a scope and sure enough it got funky every now and then. bought a whole new unit from van cafe and not a single problem since. so have the ignition system completely tested. some times intermittant problems can avoid detection, they work when being tested. so if all else fails, you might just swap it out for new and see what hahappe.
I found it hard to belive your oil change had anything to do with this. I have run different weights of oil in my van and experinced no power loss problems, once had to use a 5w20 in a pinch for a short time and experince no issues other than boarderline low pressure when hot. i got rid of that oil at first chance.
anyway sound like it might be an ignition issue as you suggest (electrical) so give that a go. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Mon May 16, 2016 10:10 am Post subject: Re: 91 Vanagon 2.1 Ticking and Loss of Power |
Thanks for the info! The distributor was moved around ( and put back in place) for water pump replacement. So could be. I'm also thinking it could be temperature related because it's only when it's cold? Wouldn't hall sender be intermittent in all engine temp conditions?
UPDATE: I noticed that the main intake boot wasn't completely tightened. I have tightened it up and will update if there is a difference. Perhaps too much air was getting in? |
