Bloku Expert Noob
Joined: April 09, 2013 Posts: 559 Location: Tulsa/Jenks Oklahoma
Posted: Tue May 17, 2016 9:23 pm Post subject: Sway bars |
Howdy again samba peeps! A quick question for yall; I want to put some pretty hefty sway bars on my ghia to have it handle. I hear that T1 VW's really need bigger sway bars up front than in the rear and I was looking for a 7/8" bar for the front and a 3/4" rear. I can find the 3/4" rear but the larger, front, sway bars seem to have fallen off the face of the internet . I am going for a setup similar to Glenn's beetle (http://www.glenn-ring.com/Beetle.html) and he has 1" swaybars! Where did man go about finding these large sway bars? If anyone knows it would be a great help. Thanks as always! _________________ 1971 Karmann Ghia
1975 Porsche 914
1975 BMW 2002
1976 BMW 2002 (Bored and Stroked w/ 5-Speed)
1981 BMW E21
1986 Toyota 4Runner (Dead engine and trans)
1989 Toyota 4x4 PU
1994 BMW E36 (Daily) |
SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Wed May 18, 2016 3:38 am Post subject: Re: Sway bars |
I don't know about 1" but are you looking for these?
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13%2D9594 _________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Wed May 18, 2016 4:35 am Post subject: Re: Sway bars |
Be aware that while that sway bar comes with bushings, it doesn't have the clamps to attach the sway bar to the car.
Also you'll find it easier to just cut the clamps holding the stock sway bar in place, rather then messing with bolts that been there for almost 50 years. I used a grinder with a cut off wheel. _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
Bloku Expert Noob
Posted: Wed May 18, 2016 5:06 am Post subject: Re: Sway bars |
CiderGuy wrote: |
Also you'll find it easier to just cut the clamps holding the stock sway bar in place, rather then messing with bolts that been there for almost 50 years. I used a grinder with a cut off wheel. |
Thank socaljes but I need a bigger front than rear. 3/4 is good for the rear but the front needs a mighty big one.
Thanks for the info ciderguy. I am known to be the one who gets pissed by old rust welded parts. I'll just cut it off
Still, does anyone know where to get front sway bars (for t1s) that is bigger than 3/4" (7/8" or 1").
Thanks! _________________ 1971 Karmann Ghia
1975 Porsche 914
1975 BMW 2002
1981 BMW E21
1989 Toyota 4x4 PU
scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1000 Location: gigharbor W.A
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Wed May 18, 2016 9:22 am Post subject: Re: Sway bars |
Bloku wrote: |
Still, does anyone know where to get front sway bars (for t1s) that is bigger than 3/4" (7/8" or 1"). |
Whiteline makes a 22 mm FSB, but it's spendy:
http://vwparts.aircooled.net/Whiteline-Front-Swaybar-22mm-RACE-Adjustable-OTT-p/bwf8xz.htm
That's just shy of 7/8" in diameter.
On my prior '69 (IRS) ghia, I ran 3/4" FSB and RSB. It was fun, but you could get the rear to step out a bit. Running a larger diameter FSB will temper that somewhat. _________________ 1966 Karmann-Ghia convertible |
Posted: Wed May 18, 2016 12:31 pm Post subject: Re: Sway bars |
Bloku, did you ever lower your suspension? I think I remember you mentioning it. The lower your center of gravity the less side sway effects your suspension.
I really doubt you need anything bigger than the 3/4" for street driving if you're adding front and rear sway bars. my $ 0.02 _________________ Jesse
71 Ghia
Bloku Expert Noob
Posted: Wed May 18, 2016 2:50 pm Post subject: Re: Sway bars |
sactojesse wrote: |
Bloku wrote: |
On my prior '69 (IRS) ghia, I ran 3/4" FSB and RSB. It was fun, but you could get the rear to step out a bit. Running a larger diameter FSB will temper that somewhat. |
Yea, that is way more than I would ever want to spend on a sway bar. I just saw in a few post that you want a bigger sway bar up front than in in rear (for balanced driving) but this is rear engined, Ill let the end slid out so the 3/4 FSB and RSB sound like a winner to me!
How did the car feel in comparison to before sway bars, and how "flatly" dose it handle? I like it to feel like I can take a corner at near any speed
SoCalJes wrote: |
I really doubt you need anything bigger than the 3/4" for street driving if you're adding front and rear sway bars. my $ 0.02 |
I wound up leaving the car as is (low profile tires and drop spindles with caster shims). The rear was also lowered a bit so any lower would be silly for oklahoma roads. Like sactojesse said, front and rear sound OK. _________________ 1971 Karmann Ghia
1975 Porsche 914
1975 BMW 2002
1981 BMW E21
1989 Toyota 4x4 PU
Posted: Wed May 18, 2016 4:36 pm Post subject: Re: Sway bars |
Bloku wrote: |
sactojesse wrote: |
Bloku wrote: |
How did the car feel in comparison to before sway bars, and how "flatly" dose it handle? I like it to feel like I can take a corner at near any speed |
I did my modifications in stages. Replacing the stock 3/8" FSB with a 3/4" FSB (but no RSB) made it much more stable at speed and in crosswinds, but with a tendency towards benign understeer. Adding the 3/4" RSB added a bit more balance to things, but with the ability to rotate the rear end if I wanted to get "frisky." _________________ 1966 Karmann-Ghia convertible |
Bloku Expert Noob
Posted: Thu May 19, 2016 8:23 pm Post subject: Re: Sway bars |
sactojesse wrote: |
Bloku wrote: |
sactojesse wrote: |
Bloku wrote: |
I did my modifications in stages. Replacing the stock 3/8" FSB with a 3/4" FSB (but no RSB) made it much more stable at speed and in crosswinds, but with a tendency towards benign understeer. Adding the 3/4" RSB added a bit more balance to things, but with the ability to rotate the rear end if I wanted to get "frisky." |
Winner! That is exactly what I am looking for, sactojesse! Thank you for telling me that. My ghia is also mildly unhappy with meager crosswinds. This looks to be the fix! Peace _________________ 1971 Karmann Ghia
1975 Porsche 914
1975 BMW 2002
1981 BMW E21
1989 Toyota 4x4 PU
helowrench Samba Member
Joined: August 27, 2003 Posts: 567 Location: dallas texas
Posted: Fri May 20, 2016 9:42 pm Post subject: Re: Sway bars |
My Ghia runs the 3/4" Front, and no rear. Understeers when pushed hard into a corner.
My Bug however, has the 3/4" front (19mm) and a 14mm rear (from Porsche 924/944.
It rotates on command with the gas pedal. very neutral in a corner.
Now, one thing you need to understand is just how much tire pressures affect this. It took me quite a while to get the pressures to work with the bars. _________________ Current VWs:
70 bug vert for wifey
73Thing bucket o rust
73 914 1.7
12 Passat 2.5 Highway cruiser |
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Thu Jul 14, 2016 11:01 am Post subject: Re: Sway bars |
I remembered this thread and it made me think about getting a rear sway bar as well. I already had the 3/4 front bar and the under steer was pretty noticeable. Just got the rear 3/4 kit installed and definitely a huge improvement.The rear just glides the perfect amount into corners now . Highly recommend, even for being Empi |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Wed Jan 18, 2017 5:50 am Post subject: Re: Sway bars |
helowrench wrote: |
...My Bug however, has the 3/4" front (19mm) and a 14mm rear (from Porsche 924/944.
It rotates on command with the gas pedal. very neutral in a corner. |
What extra measures did you need to take to make the rear 924/944 SB fit into the Type 1 IRS? _________________
It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted
slalombuggy Samba Member
Posted: Wed Jan 18, 2017 11:43 am Post subject: Re: Sway bars |
All my cars have 3/4" SBs front and rear. Even autocrossing with 21x7"F and 22x9"R slicks the cars are pretty neutral and turn in good. On the street and racing at Bonneville they are both on rails even at speeds over 110mph in slight crosswinds. And neither are as heavy or aerodynamic as a Ghia.
brad |
