craigolio1 Samba Member
Posted: Mon May 23, 2016 5:53 am Post subject: Bearing race install, no press, using heat and cold. |
This actually came about while I was researching how to do the bearings on my trailer but I feel like its relevant here.
In the you tube video I watched...
...the fellow heats the drum in his oven, at the same time freezing the bearing (his car has a one piece bearing assembly without a separate race) in his freezer. After a period of time he takes the race out and it drops right into his drum. Once the temperatures come back to normal it's all set.
I don't have a press or a race/seal driver kit (although I'm not afraid to buy tools when needed) but I'm a big fan of working smarter, not harder. I'm interested to hear peoples' thoughts on using this method to seat the race in my Ghias front disc. Obviously brake parts can handle heat, and it gets way colder here in the winter than it is in my freezer so cold temps are not an issue either.
What do you think?
Craig. _________________ I'm the new guy. Thanks for your patience.
1970 Ghia Convertable - Restoration in progress.
Link to my build thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=637602
Located in the Toronto area. |
SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Mon May 23, 2016 6:11 am Post subject: Re: Bearing race install, no press, using heat and cold. |
Back in the day that is how we used to pin out pistons and rods. _________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
Posted: Mon May 23, 2016 7:07 am Post subject: Re: Bearing race install, no press, using heat and cold. |
That's how they put the tires on steam locomotives back in the day. I don't see a problem with it since there are no rubber bits involved or other things that could be damaged.
Craig _________________ I'm the new guy. Thanks for your patience.
Derek Cobb Annoying
Posted: Mon May 23, 2016 7:08 am Post subject: Re: Bearing race install, no press, using heat and cold. |
it works. |
Posted: Mon May 23, 2016 8:08 am Post subject: Re: Bearing race install, no press, using heat and cold. |
Awesome! _________________ I'm the new guy. Thanks for your patience.
