r19rcv20 Samba Member
Posted: Sat Jun 04, 2016 12:10 am Post subject: 1966 bug front shimmy/shake |
Hey everyone!
So another problem. At around 40-45 mph the front starts to shimmy and i feel it in my legs and in the steering wheel. But after 50 it goes away. And in some occasions depending on the road it wont do it all. I have looked at other posts and i hear either the steering dampner or tie rods. Now my steering gear box is brand new. Any other suggestions?? |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sat Jun 04, 2016 4:07 am Post subject: Re: 1966 bug front shimmy/shake |
Basics.. To eliminate shimmy.
Steering parts (steering box, tie rods and ball joints) must be in good condition
Steering Damper must be in good condition.
TIRES must be balanced and in good condition.
Alignment must be correct both front and rear.
Never ever rule out tire problems and balance. AFTER checking and repairing the steering and alignment.
http://www.thesamba.com/vw/forum/viewtopic.php?t=503595
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
KTPhil Samba Member
Posted: Sat Jun 04, 2016 1:41 pm Post subject: Re: 1966 bug front shimmy/shake |
Yup, you should not have any shimmy even with NO steering damper.
The damper is to cushion road shocks, not to control shimmy. If it shimmies without the damper, you will just wear out the new damper. If you don't first eliminate the cause of the shimmy.
With a speed-related effect, suspect tires first. They could be out of balance, or maybe balanced but out of round. Then look for any looseness anywhere. |
Posted: Fri Aug 26, 2016 9:27 am Post subject: Re: 1966 bug front shimmy/shake |
So it has gotten significantly worse to the point at 30 mph i hit a small small bump i start to shake so i am pretty sure it is my rims. Last time i checked underneath i just did a quick look to see if anything is loose and nothing is. |
KTPhil Samba Member
Posted: Fri Aug 26, 2016 10:01 am Post subject: Re: 1966 bug front shimmy/shake |
Tedious, but try swapping each tire for your spare, and note when it changes... that is the worst wheel. Could be more than one! |
Posted: Fri Aug 26, 2016 10:49 am Post subject: Re: 1966 bug front shimmy/shake |
If its fine until you hit a bump.. its generally not tires or wheel..
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Fri Aug 26, 2016 12:08 pm Post subject: Re: 1966 bug front shimmy/shake |
[quote="r19rcv20"]So it has gotten significantly worse to the point at 30 mph i hit a small small bump i start to shake so i am pretty sure it is my rims. Last time i checked underneath i just did a quick look to see if anything is loose and nothing is.[/quote]
You have to check the condition of all of the steering components. Something is worn out.
Jack the front of the car up. Put jack stands under the lower beam for stability. With the tires on grab them at the 12-6 o'clock position and rock them. Next 9-3 o'clock and do the same. Next 10-4 o'clock. Listen for and metallic sounds. Feel for movement that should not take place when everything is in good working order.
I have been guilty of just replacing the steering damper to cure(mask) these worn parts issue I didn't know better at the time. I even posted this in another thread. I got slayed for suggesting it.
FWIW, I have a steering component that is failing. I can hear it just haven't located it yet.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Fri Aug 26, 2016 12:43 pm Post subject: Re: 1966 bug front shimmy/shake |
so I should reword what I said earlier. so pretty much when i a driving at a speed around 30 it will start to shake. and that is when it is usually the worst. when i pick up speed it will start to shake but not as bad. the only time is does not shake is when i am driving on the highway. and when i do brake it will stop |
KTPhil Samba Member
Posted: Fri Aug 26, 2016 12:49 pm Post subject: Re: 1966 bug front shimmy/shake |
r19rcv20 wrote: |
Are your wheel bearings in good shape, and adjusted properly? |
pwmcguire Samba Member
Joined: January 30, 2011 Posts: 1108 Location: Kennesaw GA
Posted: Fri Aug 26, 2016 8:04 pm Post subject: Re: 1966 bug front shimmy/shake |
Tie rod ends are worn. Check all of your steering parts. If it is bad as you say you will see movement in your steering components |
Blue66 Samba Member
Joined: December 22, 2008 Posts: 199 Location: Central. NY
Posted: Sat Aug 27, 2016 5:08 am Post subject: Re: 1966 bug front shimmy/shake |
I had the same exact thing on my 66 (45-50 mph shimmy).It was my tie rod. Once replaced the problem went away. Raise the front end and give the wheel a shake, if it wobbles then this may be your issue. Make sure you support the car on stands. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sat Aug 27, 2016 5:16 am Post subject: Re: 1966 bug front shimmy/shake |
Since its getting worse stop driving until you fix it. Would suck to have a catastrophic failure like a tie rod or ball joint some apart at 60 MPH. But I have heard the you can pop the big dent out of the roof pretty easily when you roll the car over. I am freaking serious though. Park it until you fix it. _________________ D-Dubya Manx clone - 63 Short pan,1914.
