pablovent Samba Member
Posted: Tue Jun 07, 2016 9:30 am Post subject: Permatex form a gasket sealant question? |
Hi;
In my local store sale two Permatex form a gasket sealant alternatives.......What is recommended for seal the case?
1.- Fast-drying, hard-setting sealant
2.- Slow-drying, non-hardening sealant
Thanks |
mark tucker Samba Member
Posted: Tue Jun 07, 2016 9:41 am Post subject: Re: Permatex form a gasket sealant question? |
neither but if you just have to use that crap... the non hardning.well either will do for a little while..... curlyt or 518 gellseal or halomar or...... something a little more modern that has bee updated and works and last. |
theDrew Samba Member
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51121 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Jun 07, 2016 9:53 am Post subject: Re: Permatex form a gasket sealant question? |
ok, In my last engine rebuilts used Yamabond, but no longer sold in my city, I think anyway use Permatex 2 are better to RTV silicone? |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5407 Location: Holland, MI
Posted: Tue Jun 07, 2016 3:43 pm Post subject: Re: Permatex form a gasket sealant question? |
Depends how it is applied. If you follow the directions on the tube, it won't work worth a hoot. Even putting a bead down and torquing the case isn't great. That said, I did use Permatex ultra copper on my case halves, but I had a different method of applying it that raygreenwood taught me. If you really want to know what that was all about I can put up some pictures if you want.
If you can get Permatex products, see if you can get their motoseal. It is made for motorcycles, etc, where precision metal to metal contact is present. It is very similar to the Yamabond you were using. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Posted: Tue Jun 07, 2016 4:06 pm Post subject: Re: Permatex form a gasket sealant question? |
gell seal. = locktight 518. or OMC ( outboard motor corpration) case sealent. yamaha has thise own yamaha bond, I think we used #4 but not sure. it too can get messy and starts skining over as soon as it's out of the tube.
the locktight says messy untill it has no air as in between two peices and torqued down. so you can apply it and torque the case then wipe off the exsess withen the next year or so...., just dont do a partial torque then come back the next day to do the rest as it will of setup and your bearing clearances will be off!! and loose in the case and possiable case warpage! so make sure you want to finaly seal it up and do it.
silocone is good for exhaust and cylinder base&cylinder base shims. thats about all it should be used for on a vw.. never over apply any sealent as it will just squish out and in and then clog your oil pickup and kill your motor. Ive pulled motors appart that had the crank gallys packed with silycone , no way for oil to get to the bearings. so whatever sealer you choose to use use it sparingly. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21510 Location: Oklahoma City
Posted: Tue Jun 07, 2016 4:10 pm Post subject: Re: Permatex form a gasket sealant question? |
Vanapplebomb wrote: |
If you can get Permatex products, see if you can get their motoseal. It is made for motorcycles, etc, where precision metal to metal contact is present. It is very similar to the Yamabond you were using. |
Yes....whether the formulation is old or new......how you use it is 90% of the game....and it can be different for each product by a little or a lot.
Also.....Permatex for startes......has much more "modern" and sophisticated formulations than the old forma-gasket 1 and 2....both adhesion, temperature and oil and solvent resistance.
Also look carefully in the tech data sheets for many of these products....and you will find notes for hardness or durometer of the cured product which makes a big difference in how an where it should be used. |
modok Samba Member
Joined: October 30, 2009 Posts: 26777 Location: Colorado Springs
Posted: Tue Jun 07, 2016 4:20 pm Post subject: Re: Permatex form a gasket sealant question? |
Permatex #2, #3, 300, and "aviation sealant"
are all the same thing, but slightly thicker or thinner.
To seal the case split, use permatex 300 or permatex aviation, or hylomar blue. |
Posted: Tue Jun 07, 2016 5:19 pm Post subject: Re: Permatex form a gasket sealant question? |
really apreciated!! |
Posted: Fri Jun 17, 2016 2:11 pm Post subject: Re: Permatex form a gasket sealant question? |
Permatex rtv black ultra oil resistance? |
Posted: Fri Jun 17, 2016 2:21 pm Post subject: Re: Permatex form a gasket sealant question? |
pablovent wrote: |
Just about the best I have seen among any RTV products.
Among the "Ultra" series....black is the most oil resistant, The gray is very oil resistant but has a higher durometer (harder for high torque areas). The copper is about the same as black in hardness, almost as oil resistant...but has about 100* higher temp range.
Continuous usage emps:
Black: -65 to 500F
Gray: -65 to 500F
Copper: -65 to 600F
Ray |
Posted: Fri Jun 17, 2016 2:29 pm Post subject: Re: Permatex form a gasket sealant question? |
but still not so recommended to seal the case?or not? |
Posted: Fri Jun 17, 2016 2:44 pm Post subject: Re: Permatex form a gasket sealant question? |
RTV is the wrong product to use to seal case halfs. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Fri Jun 17, 2016 2:51 pm Post subject: Re: Permatex form a gasket sealant question? |
Totally depends on how it is used. The way 98% use it.....gooping it on with a brush or their finger.....you are correct. ...its the wrong product to use.
By tuat same token.......just because an adhesive based product is thinner, spreads easier snd shrinks as it dries....so those 98% who use a finger or a brush can't goop themselves into destruction.....does nkt mean its the BEST material to use.
Ray |
Posted: Fri Jun 17, 2016 3:02 pm Post subject: Re: Permatex form a gasket sealant question? |
Yamabond/Hondabond etc.... are RTV's too aren't they? As Ray says RTV will work but it has to go on in a thin even coat, and don't let it harden fully before closing up the halves or it'll keep them from fully mating up.
One way I apply it to some things is with a squeegee with small notches filed in it (like a miniature linoleum adhesive spreader), that way it's a consistant thickness and has room to squish between the rows. A bit of coarse tooth hackswaw blade would work too if you weren't afraid of scratching things. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Howard 111 Samba Member
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Fri Jun 17, 2016 3:44 pm Post subject: Re: Permatex form a gasket sealant question? |
What about the silk thread trick, does any body do it on their VW's? _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Fri Jun 17, 2016 3:48 pm Post subject: Re: Permatex form a gasket sealant question? |
Howard 111 wrote: |
I like Gasgacinch for the case halves, for a leak proof seal. |
I have used Gasgacinch for years, never a leak _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
MConstable Samba Member
Joined: May 04, 2004 Posts: 1822 Location: Saint Charles IL
Posted: Fri Jun 17, 2016 4:03 pm Post subject: Re: Permatex form a gasket sealant question? |
I'd love pics if you would |
