ALANSD Samba Member
Joined: April 16, 2015 Posts: 341 Location: Woodstock, GA
Posted: Wed Jun 08, 2016 2:14 pm Post subject: Remove Pulley |
What is the best way to remove the crank pulley? I need to reinstall the breast plate tin under it.
...Do I need to get or borrow a pulley "puller"? |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
ALANSD Samba Member
Posted: Wed Jun 08, 2016 5:47 pm Post subject: Re: Remove Pulley |
you still have to get the large nut off I assume, before using the tool |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Wed Jun 08, 2016 7:03 pm Post subject: Re: Remove Pulley |
I use 2 large screwdrivers and CAREFULLY wiggle it off. _________________ Glenn
Member #1009
#BlueSquare |
Yarkle Samba Member
Joined: August 03, 2009 Posts: 1218 Location: the Hills of Western Maine
Posted: Thu Jun 09, 2016 7:39 am Post subject: Re: Remove Pulley |
if theres a NAPA around you, you can "rent" a 3 arm puller (i think thats what tis called--check my bay bus build thread its in there) for like 70 bucks, then you can return it and they refund the rental fee.
I tried the two screwdriver thing and bent the crap out of the pulley-any wiggling i did didnt move the pulley, just bent it..but sometimes i swear im part orangutan , but the puller had it out in udner a minute IIRC _________________ Tilda the Mustard Tigress 1973 Squareback (o'''^'''o)
https://www.thesamba.com/vw/forum/viewtopic.php?t=771024&highlight= |
Rev. Scott Samba Member
Joined: June 04, 2006 Posts: 770 Location: Philo, Ca.
Posted: Thu Jun 09, 2016 6:14 pm Post subject: Re: Remove Pulley |
Yes. you have to remove the nut. I, ashamedly admit, use a large crescent hammer to do this with a few good cracks from a ball-peen. use the butt end of two crescent hammers between the case and pulley and with some patience, it will gingerly wiggle off. _________________ "I haven't seen one of those since I was shootin' at 'em!" |
ALANSD Samba Member
Posted: Fri Jun 10, 2016 1:50 pm Post subject: Re: Remove Pulley |
Thanks for the ideas...will be working on it soon, gotta a small project on my 911 I gotta get done first. |
ALANSD Samba Member
Posted: Sun Aug 28, 2016 10:21 am Post subject: Re: Remove Pulley |
another question- I see 30mm and 32mm listed for this which is it? Or I might get both to be safe. |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Sun Aug 28, 2016 12:50 pm Post subject: Re: Remove Pulley |
Mine's a 30.
A few years ago, I made a hole in the rearmost tin aligned with the pulley bolt.
I sized the hole to fit a Type 3 timing hole plug I had lying around
but any rubber plug from a hardware store would do.
With the hole there, it's easy on the knuckles to use a 30mm socket with an extension to remove the bolt from behind the bumper (through the hand crank opening).
ALANSD Samba Member
Posted: Sun Aug 28, 2016 1:31 pm Post subject: Re: Remove Pulley |
mondshine wrote: |
Mine's a 30. |
thanks |
ALANSD Samba Member
Posted: Sun Oct 02, 2016 6:52 am Post subject: Re: Remove Pulley |
I have used one of those bolts in the past. It does provide a small convenience in that a 3/8" drive ratchet can be used to remove the bolt. I am no longer using that bolt, though I can't remember why. I don't remove the pulley very often, so it makes little difference. For rolling the engine over to adjust the valves, the alternator pulley nut works fine for me.
If the pulley is to be removed, the rear tin must come out anyway in order to use the puller. My puller looks like this:
Good luck, Mondshine |
ALANSD Samba Member
Posted: Sun Oct 02, 2016 10:01 am Post subject: Re: Remove Pulley |
thanks. I was actually adjusting the valves today and turning the pulley. Had no problems using my crescent wrench to do it. |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Tue Oct 04, 2016 5:11 pm Post subject: Re: Remove Pulley |
here is the pulley puller I use it fits in the 2 holes near the center so it does not warp the pulley
Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 679 Location: SE Oklahoma
Posted: Tue Oct 04, 2016 7:31 pm Post subject: Re: Remove Pulley |
citroen wrote: |
Nice tool...where did you get it? _________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
Posted: Wed Oct 05, 2016 6:03 am Post subject: Re: Remove Pulley |
I had it for years. That is what happens when you are old you keep your tools for the next generation |
Posted: Wed Oct 05, 2016 7:04 am Post subject: Re: Remove Pulley |
I have to go visit more swap meets, garage sales and flea markets! _________________ 1963 Beetle
1966 Beetle 1300
1971 Super Beetle
1974 Thing
ALANSD Samba Member
Posted: Thu Oct 06, 2016 7:42 am Post subject: Re: Remove Pulley |
I have the craftsman tools I bought in the late 60's. Also inherited some form my dad who had a service station. Lucky for me my son's work on their cars too so they can get the tools when I am not using em anymore
Had to buy a new compression tester though, mine was so old it quit working..Hope I don't need it soon |
