Captain Moustache Samba Member
Posted: Sun Jun 12, 2016 10:19 pm Post subject: Overheating damages: Broken engine ? |
Hello,
I was driving on the highway when my engine noise changed, I stopped asap and heard a breaking noise. There was a light smoke coming from the fan.
There was broken metal pieces in the engine compartment which seem to come from here:
Here are the pieces:
The engine cranks but won't start and accelerating seems to have no effect.
I can also hear some kind of clicking noise every 3 crank which moves the bus a little bit.
Thanks.
Edit: 1970, 1600cc.
Last edited by Captain Moustache on Sun Jun 12, 2016 10:49 pm; edited 1 time in total |
Danwvw Samba Member
Posted: Sun Jun 12, 2016 10:27 pm Post subject: Re: Overheating damages: Broken engine ? |
It has thrown one of your rods. Don't try to crank it you will only damage the crank and rods or other parts that may still be good. Your Case is shot! _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Sun Jun 12, 2016 10:29 pm Post subject: Re: Overheating damages: Broken engine ? |
So how do I go from here ?
Is it even fixable ?
Also, what was the most probable cause ? Overheating ?
Last edited by Captain Moustache on Sun Jun 12, 2016 10:31 pm; edited 1 time in total |
Danwvw Samba Member
Posted: Sun Jun 12, 2016 10:31 pm Post subject: Re: Overheating damages: Broken engine ? |
It will need to be taken out of the car and taken apart and rebuilt with new parts. Or find another good engine for your car. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
richparker Samba Member
Joined: November 24, 2011 Posts: 6983 Location: Durango, CO
Posted: Sun Jun 12, 2016 10:33 pm Post subject: Re: Overheating damages: Broken engine ? |
Not fixable. It's time for a new build. That usually happens when you run it out of oil...have you been checking the oil at every gas stop?
Good news is you have a lot of parts that are reusable with your new build. All the tins and most of the bolt on parts can be carried over the the new engine. It's time to find a builder. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Sun Jun 12, 2016 10:34 pm Post subject: Re: Overheating damages: Broken engine ? |
Okay, thank you.
I guess it's time to put it to sleep for a few years then .
It's my fault I overlooked checking the oil lately. I'm a dumbass. |
Danwvw Samba Member
Posted: Sun Jun 12, 2016 10:40 pm Post subject: Re: Overheating damages: Broken engine ? |
Rich often when they throw a rod it just breaks the cam in two and the case and of course that piston will be destroyed it could wreck the head may-be not and the crank is likely bad but may not be it may just need to be re-ground. It happened to my 66 Bug years ago but yeah, its a good idea to find another motor but many of the parts will still be good. Everything needs to be checked by a machinist to see if it's still good though. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Danwvw Samba Member
Posted: Sun Jun 12, 2016 10:45 pm Post subject: Re: Overheating damages: Broken engine ? |
Captain Moustache wrote: |
Okay, thank you.
Was your oil light coming on sometimes in the week or days before this happened? _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Sun Jun 12, 2016 10:47 pm Post subject: Re: Overheating damages: Broken engine ? |
No but to be fair it might not even be working. I've never seen it on.
When I checked the oil (after it broke) it was under the minimum stripe. |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Sun Jun 12, 2016 10:51 pm Post subject: Re: Overheating damages: Broken engine ? |
Yes' it a shame your engine has died but, i.t does not mean you are at fault
It is a failure that is most common. _________________ V.W.owner since 1967 |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Mon Jun 13, 2016 2:27 am Post subject: Re: Overheating damages: Broken engine ? |
The oil warning light?
No but to be fair it might not even be working. I've never seen it on. |
I would like to take this time to apologize to you, and make you an example for everyone else as to why it is important to have a functioning oil pressure "idiot" warning light.
www.airschooled.com |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Mon Jun 13, 2016 6:43 am Post subject: Re: Overheating damages: Broken engine ? |
Time to go back and read John Muir's idiot manual (no offense). The idiot lights are the only thing that keeps you in the know about what your engine is doing while driving. They are essential.
You're not going to want to reuse a single component inside that engine. Metal shavings no doubt made their way through the oil long before the rod ever broke, and that rod has to get really really hot to break like that which means your crank got really really hot too and is probably purple from the heat which means it's junk. Also where the rod seized up it will have ruined the crank journal beyond repair (except for welding in new material and regrinding, but it's cheaper to get a different one). _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
Danwvw Samba Member
Posted: Mon Jun 13, 2016 10:44 am Post subject: Re: Overheating damages: Broken engine ? |
It's not all that worse than other things that happen to them just more dramatic! The flywheel that I use now came off an engine that broke the crankshaft. And then there was my stock engine Building a Stock ish Type 1 engine for the 1971 VW Bus? which was running fine when I took it out of my bus. Bus upon tearing it down I discovered that pretty much everything was bad. The heads were cracked, the crank had metal eaten out of it by corrosion, the case was hammered out beyond machining, the flywheel which looked perfect turned out to be (out of round) and had been causing the premature deaf (hammering out the case) of every engine it had ever been run on. Rod's and engine tin etc are the only parts I could use. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Mon Jun 13, 2016 5:36 pm Post subject: Re: Overheating damages: Broken engine ? |
I have posted this many times before, "sufficient oil is more important than the type of the oil one uses" and "an oil pressure warning light is way more important than a gauge".
I know that few believe I am going right, but I have run a quart over the "FULL" mark on both my Type 1 and Type 4 engines for nearly 40 years now and like the assurance it gives me that I will not ever run dangerously low on oil. |
timvw7476 Samba Member
Posted: Mon Jun 13, 2016 7:02 pm Post subject: Re: Overheating damages: Broken engine ? |
I'm all for gauge-less, as-delivered VWs.
But run a functioning idiot light & check oil once every fortnight. FFS |
Posted: Mon Jun 13, 2016 8:41 pm Post subject: Re: Overheating damages: Broken engine ? |
timvw7476 wrote: |
I appreciate the linguistics, but I feel like even a weekly oil inspection is almost lacking in diligence. I'm worried more about gas in the oil from a faulty pump gasket than I am of an engine spontaneously "losing" its oil. _________________ Learn how your vintage VW works. And why it doesn't!
Tcash Samba Member
Posted: Mon Jun 13, 2016 9:00 pm Post subject: Re: Overheating damages: Broken engine ? |
asiab3 wrote: |
timvw7476 wrote: |
I appreciate the linguistics, but I feel like even a weekly oil inspection is almost lacking in diligence. I'm worried more about gas in the oil from a faulty pump gasket than I am of an engine spontaneously "losing" its oil. |
I second this one. I check it before the first start up of the day and when I stop to get gas and that Oil & Gen light better come on every time I turn the key to the #1 run position.
Sorry for your loss
Tcash |
Brian Samba Moderator
Posted: Mon Jun 13, 2016 9:05 pm Post subject: Re: Overheating damages: Broken engine ? |
Few years? Nah, get back on your feet man bummer it happened though. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
qwerksc Samba Member
Posted: Mon Jun 13, 2016 10:33 pm Post subject: Re: Overheating damages: Broken engine ? |
I had the same thing happen to me. 65 bug, flying in commuter traffic, then Bang! blew the rod, the thing shot a silver dollar sized chunk outta the case.
figured that was the engine rebuild light going off. |
