xfactor6 Samba Member
Posted: Wed Jun 15, 2016 8:54 am Post subject: Driver Quarter |
well I'm in my discovery phase of body work on my 66 beetle project and my driver quarter had like 2 inches thick of bondo on it, I guess the car was hit there a long time ago. my question is, can I use part of a quarter panel from a 68 and up? I only need the part of the part highlighted. or is it totally different curve?
fla2smoker Samba Member
Joined: December 31, 2011 Posts: 574 Location: Parrish, Florida
Posted: Thu Jun 16, 2016 6:56 am Post subject: Re: Driver Quarter |
Technically you can use the 68- up quarter section you highlighted. The holes for the chrome body molding clips will be larger than the original 66. _________________ View my 66 build thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=507996 |
Posted: Thu Jun 16, 2016 12:54 pm Post subject: Re: Driver Quarter |
fla2smoker wrote: |
Technically you can use the 68- up quarter section you highlighted. The holes for the chrome body molding clips will be larger than the original 66. |
Don't need anything with the holes part just the part below those holes so I guess this is an option then. Thanks |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Thu Jun 16, 2016 6:32 pm Post subject: Re: Driver Quarter |
fla2smoker wrote: |
Technically you can use the 68- up quarter section you highlighted. The holes for the chrome body molding clips will be smaller than the original 66. |
Fixed it for ya!
Some 68 and later front quarter panels come with the brake res. support in the area that you have highlighted. That would have to be removed if you care about being bone stock on a 66. Also some front quarters do not have any holes drilled in them for the moldings when re-popped.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
