kriskussee Samba Member
Joined: November 27, 2007 Posts: 5 Location: Kaysville, Utah
Posted: Mon Jun 20, 2016 10:35 am Post subject: Type 3 - Dellorto FRD Carburetors |
Is there only one manifold for FRD Carburetors, or did they make different ones for type 1 and type 3? - Everyone I have asked say, ahhhhh I think so but I am not sure... |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Tue Jun 21, 2016 7:39 am Post subject: Re: Type 3 - Dellorto FRD Carburetors |
Yes Batman, there is a different FRD manifold for a Type 1 and a Type 3 |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Tue Jun 21, 2016 12:55 pm Post subject: Re: Type 3 - Dellorto FRD Carburetors |
Looks like just a different version/manufacturer used by Dellorto. FRD's will fit on VW,Weber & EMPI manifolds too. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Sun Jun 26, 2016 1:09 am Post subject: Re: Type 3 - Dellorto FRD Carburetors |
Quote: |
FRD's will fit on VW,Weber & EMPI manifolds too. |
I disagree; at least they are not a straight bolt-on. FRDs have a different stud spacing (68mm) than VW's Type 3 PDSITs (60mm). Look here- http://www.thesamba.com/vw/forum/album_page.php?pic_id=881338
Last year I bought a pair of ICT dual-port manifolds. Those have a 62mm carb stud spacing.
kriskussee- thanks for your photo of the different FRD manifolds. A good friend just bought a good used set of FRDs at the Litchfield CT VW meet a week ago based on my inspection. Seller said the set was off a T3; your photo now shows the height difference so that my friend will need to make some spacers to use them on a Type 1. Spacers will raise up the carb base enough so that the CB crossbar linkage will clear the top of the generator. |
