bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Wed Oct 19, 2016 6:03 pm Post subject: Re: Best street head to hit the market in many years |
dmar836 wrote: |
Nice work! Sure sounds like an odd use of a VW but certainly attests to it's ability. These are the first aftermarket vw heads I've ordered. I feel the slight ridge at the rapid 90 degree exhaust turn. Wondering if anyone has smoothed that?
Dave |
Anybody who understands what's going on in a chamber would. I do it to every set of heads that I use. Lightly hit the corner with a 2" disc and then smooth it out with a 3M Scotch Brite disc or similar. Leave the valves in to avoid seat damage. |
dmar836 Samba Member
Joined: September 17, 2016 Posts: 50 Location: Midwest, USA
Posted: Wed Oct 19, 2016 7:58 pm Post subject: Re: Best street head to hit the market in many years |
Brian and Mark,
Thanks! Sage advice and less work for me!
Dave |
Posted: Wed Oct 19, 2016 8:01 pm Post subject: Re: Best street head to hit the market in many years |
Bugguy, Sorry, we must have been typing at the same time. Thanks for the advice.
Dave |
Pat D Samba Member
Posted: Thu Oct 20, 2016 3:20 pm Post subject: Re: Best street head to hit the market in many years |
I just finished what I call the ultimate daily driver engine. It's a 2332cc with 8.8-1 compression, CB #2246 cam/Engle 130 clone, stock ratio rockers, 48 IDF weber carbs, 1-5/8 A-1 sidewinder exhaust and off the shelf Panchito heads with CNC chambers. I used our new Panchito intake manifold with the as cast port, it matches nicely to the Panchito head. This engine made 178 HP at 5500 rpm and 182 lbs torque at 4400 rpm at the flywheel. Put in a freeway flyer gear box and man what a nice driving car you would have!
_________________ Pat, Im too fast slow me downs!
midtravelmidengine Samba Member
Joined: August 06, 2009 Posts: 861 Location: Riverside, Ca
Posted: Thu Oct 20, 2016 3:50 pm Post subject: Re: Best street head to hit the market in many years |
Pat D wrote: |
I just finished what I call the ultimate daily driver engine. It's a 2332cc with 8.8-1 compression, CB #2246 cam/Engle 130 clone, stock ratio rockers, 48 IDF weber carbs, 1-5/8 A-1 sidewinder exhaust and off the shelf Panchito heads with CNC chambers. I used our new Panchito intake manifold with the as cast port, it matches nicely to the Panchito head. This engine made 178 HP at 5500 rpm and 182 lbs torque at 4400 rpm at the flywheel. Put in a freeway flyer gear box and man what a nice driving car you would have! |
What would be the odds of getting you to make a head that is now geared toward the other half of all vw engines that will support +/- 130 HP from the 1600 (1585) to 1915 size.
something with say 37mm intake and 32mm exhaust ??? _________________
modok wrote: |
And I know you don't know because if you did you would know the reason for my knowing you didn't. |
youngnstudly wrote: |
I just wasn't sure if I should recommend the 1/3 race cam, the 1/2 race cam, or the 5/8 race cam instead...guess it depends on how much of the race he wants to lead???
mark tucker Samba Member
Posted: Thu Oct 20, 2016 4:17 pm Post subject: Re: Best street head to hit the market in many years |
I would think that head would be perfectly suited to that app. smaller valves making more power on smaller engines is longagointernetbscrapolawivestailsdipedinsquiblebymorons...... more in more out+more power as long as the port is not sized rong.and those heads have a small port volume. cb would be working backwards if they did that. why would you want to restrict the head flow at the valve??? thats stupid. just add a carb restrictor like nascar and let the heads breathe. Ill bet pat has already done some small motors with this head. |
Matthew Samba Member
Joined: January 29, 2004 Posts: 1760 Location: Eastern Tennessee
Posted: Thu Oct 20, 2016 5:11 pm Post subject: Re: Best street head to hit the market in many years |
It would be interesting to see what these heads would do on a well built 1776. _________________ 1965 Beetle sedan
Click to view image |
tobiism Samba Member
Joined: January 21, 2004 Posts: 502 Location: Chandler AZ
Posted: Thu Oct 20, 2016 7:20 pm Post subject: Re: Best street head to hit the market in many years |
Pat D wrote: |
Wow! What vents are you running in the 48's?
How would those heads run with an FK45 with the upgraded springs in the same engine? _________________ "There has never been a genius without a hint of madness."
-Albert Einstein |
Posted: Thu Oct 20, 2016 10:34 pm Post subject: Re: Best street head to hit the market in many years |
mark tucker wrote: |
I would think that head would be perfectly suited to that app |
Not trying to start an argument but are you really saying that a head that supports 180 hp on a 2332 is "PERFECTLY SUITED" to a 1776?? Really? It's 25% smaller...
Oh and I never said to restrict the head at the valve I was talking about casting a head with proportionately smaller ports and valves to further enhance velocity in the smaller motors of the size I stated. _________________
modok wrote: |
Posted: Fri Oct 21, 2016 10:08 am Post subject: Re: Best street head to hit the market in many years |
yup. |
Posted: Fri Oct 21, 2016 1:29 pm Post subject: Re: Best street head to hit the market in many years |
Oh come on Mark, tell me how you really feel! haha
I think thats the smallest reply ive ever seen you type.
Can you please elaborate your reasoning? im always interested in learning something ive not thought of before. _________________
modok wrote: |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Fri Oct 21, 2016 2:21 pm Post subject: Re: Best street head to hit the market in many years |
longagointernetbscrapolawivestailsdipedinsquiblebymorons...... |
long ago internet bs crapola wives tails dipedin squible by morons
I had to dig out the secret spy decoder ring out of the box of cereal to figure this one out. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Fri Oct 21, 2016 4:34 pm Post subject: Re: Best street head to hit the market in many years |
If on a 2332 hp peaks at 5500, then on a 1776 they will peak at 7200rpm.
That's just a simple comparison, and there a more factors to consider, but basically it's true. |
Posted: Fri Oct 21, 2016 4:44 pm Post subject: Re: Best street head to hit the market in many years |
Dave. thats "diped in squible " just another reason to stay away from old wives tails |
Posted: Fri Oct 21, 2016 4:54 pm Post subject: Re: Best street head to hit the market in many years |
modok wrote: |
So since the 2332 peaks at 5500, then isn't that W130 clone cam a bit to much for this combo? Maybe the peak would still be the same and have more low end grunt with a little less cam? _________________ 1965 Beetle sedan
modok Samba Member
Posted: Fri Oct 21, 2016 5:02 pm Post subject: Re: Best street head to hit the market in many years |
Yeah probably drop the cam down, but only a little, to a engle 125
Certainly could have 160+hp but you'd need a close ratio gearbox to make the most use of it. |
Posted: Sat Oct 22, 2016 9:37 am Post subject: Re: Best street head to hit the market in many years |
CC |
Brian Samba Moderator
Posted: Sat Oct 22, 2016 12:41 pm Post subject: Re: Best street head to hit the market in many years |
vwracerdave wrote: |
I had to dig out the secret spy decoder ring out of the box of cereal to figure this one out. |
I keep getting "Be sure to drink your ovaltine" _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Sat Oct 22, 2016 2:06 pm Post subject: Re: Best street head to hit the market in many years |
hmm that decoder ring should of told you to use effing head gaskets too must be defective. |
Posted: Mon Oct 24, 2016 11:54 am Post subject: Re: Best street head to hit the market in many years |
look at the intake runner cc size. 1 cc more than a stock vw head. thats a lot of torque and fast air speed. smaller valves will just effup up a great head. but a internet ex~spurt building things in their head could probably get 700 hp out of it in thier head just by putting tiney valves in it. |
