modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Mon Jun 27, 2016 4:57 pm Post subject: Re: Best street head to hit the market in many years |
[email protected] wrote: |
I am also working on adding material and moving the stud hole locations for waterboxer case applications. All in due time sir, all in due time..... |
I heard that!
I don't think you can beat this head, performance per $, but if you make a WBX pattern head you can beat them all |
mark tucker Samba Member
Posted: Mon Jun 27, 2016 6:26 pm Post subject: Re: Best street head to hit the market in many years |
hmm , my heads will take wet box pattern..... and I had smothered burreatoes tonight..
I think this new cb head will be awesome on dd,street,bus&mild race. it should pack some punch to bus motors with the small ports. |
JasonBaker Samba Member
Joined: February 08, 2010 Posts: 1642 Location: Cleveland, TN
Posted: Tue Jun 28, 2016 12:05 pm Post subject: Re: Best street head to hit the market in many years |
Can someone explain why the heads are 12mm for the plug? Is it to prevent cracks? It's damn near impossible to get a thermocouple for the VDO CHT gauge. I assume someone is trying to tell me that the VDO is junk and I should buy something better? In years past I have seen a few guys bitch, grip, moan and complain about 12mm heads. I didn't understand what the problem was until a few years ago when I got mini-wedge ports. I love the power they make, but I hate the lack of product support for a 12mm thermocouple from manufacturers. |
AlteWagen Troll
theDrew Samba Member
Posted: Tue Jun 28, 2016 12:22 pm Post subject: Re: Best street head to hit the market in many years |
JasonBaker wrote: |
get some 12mm ring connectors and just recrimp the thermocouple wires. Bam! next problem? _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
smkn_vw Samba Member
Posted: Tue Jun 28, 2016 12:52 pm Post subject: Re: Best street head to hit the market in many years |
Yep thermalcouple material ring connectors and test before and after if readings wandered.
Hello head builders...we need heads with #3 spark plug hole slotted to hold the ring connector from spinning, always have to request this mod. _________________ "So didja?" -Bob Hoover |
AlteWagen Troll
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Tue Jun 28, 2016 2:00 pm Post subject: Re: Best street head to hit the market in many years |
I also feel the 12mm plugs are not necessary and the Pachino heads should have 14mm plugs. The Mexican 043 heads never had problems with 14mm plugs. There are far more choices for 14mm plugs and they last much longer with less fouling problems. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
AlteWagen Troll
modok Samba Member
Posted: Tue Jun 28, 2016 4:23 pm Post subject: Re: Best street head to hit the market in many years |
All of the "problems" mentioned so far can be fixed easily.
You can drill and tap spark plug holes bigger but it's real hard to tap it smaller |
Posted: Tue Jun 28, 2016 5:48 pm Post subject: Re: Best street head to hit the market in many years |
motorcycle,lawnmowder,japaneessee cars.plugs shouldent be that hard to find.I didnt have any issue. google?ebay? cb perf? hondashop? |
nsracing Samba Member
Posted: Tue Jun 28, 2016 5:56 pm Post subject: Re: Best street head to hit the market in many years |
Longer 12mm plugs is the way to go. This gives more meat away from the seats.
Now if Pat can just move away the exhaust seat a few thousandths, that will be golden. We can really 'open up' the heads for some really big valve combos.
How about it Pat? Is that a possibility in the future for the Type I application or Waterboxer? |
Posted: Tue Jun 28, 2016 6:02 pm Post subject: Re: Best street head to hit the market in many years |
ya move the intake toward the center and upward (higher in the bore)and the ex toward the center and downward (lower in the bore)...and cant then a tad.... I think what he has hear is a great new head. I dont see a twisted head in acvw's future for mass production....althought it should be |
vwinnovator Samba Member
Joined: July 11, 2005 Posts: 1555 Location: Still doing it in the back of your VW
Posted: Tue Jun 28, 2016 7:08 pm Post subject: Re: Best street head to hit the market in many years |
I wish someone would make a nice compact overhead cam set up, so we can swap cams at the track... |
modok Samba Member
Posted: Tue Jun 28, 2016 8:06 pm Post subject: Re: Best street head to hit the market in many years |
You mean a subaru? just kidding. (but they do have same bore spacing, so......you could) |
sled Samba Member
Posted: Sun Jul 03, 2016 9:07 am Post subject: Re: Best street head to hit the market in many years |
Pat, are you still watching this thread?
do you have any more builds to share with us where you have used this head?
how versatile is this head? many people run 40x35 on small engines like 1776's but most people believe they need 42x37 or even larger on 2200 and up. Can this head be used out of the box on a spirited 1776? with the conservative port volume and high intake velocity, it should work relatively well and not sacrifice too much low rpm performance? With that, you have also used these heads on large engines and made very impressive numbers. With the ever-evolving technology of head design, are we seeing that huge valves and big carbs are less needed for high performance STREET heads? obviously a 40mm intake valve has a limit to how much air can flow past it (unless of course you keep lifting it, but this is not practical) so for much higher rpm applications bigger valves are needed? In real world street driving, how often do people shift gears at or above 7000? _________________ drive your split. |
Pat D Samba Member
Posted: Tue Jul 05, 2016 11:56 am Post subject: Re: Best street head to hit the market in many years |
sled wrote: |
how versatile is this head? many people run 40x35 on small engines like 1776's but most people believe they need 42x37 or even larger on 2200 and up. Can this head be used out of the box on a spirited 1776? with the conservative port volume and high intake velocity, it should work relatively well and not sacrifice too much low rpm performance? With that, you have also used these heads on large engines and made very impressive numbers. With the ever-evolving technology of head design, are we seeing that huge valves and big carbs are less needed for high performance STREET heads? obviously a 40mm intake valve has a limit to how much air can flow past it (unless of course you keep lifting it, but this is not practical) so for much higher rpm applications bigger valves are needed? In real world street driving, how often do people shift gears at or above 7000? |
I like to use heads with small intake port volume like the Panchito on bigger engines with big cams. You will never see huge HP numbers at 7000 rpm and above like a large valve, big port head compared to a 40x35.5 valve Panchito. But, you will see impressive HP numbers starting allot lower in rpm and carry through 6000 rpm. This makes for a great running street engine and with the cooling efficiency of a stock head casting, heat shouldn't be an issue.
On smaller engines, the panchito runs great. I have built 1776cc engines, 1915cc engines and many 2005 and 2110cc engines with them. I can post some more dyno graphs on these engines when I get a little time here at CB _________________ Pat, Im too fast slow me downs! |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Tue Jul 05, 2016 1:31 pm Post subject: Re: Best street head to hit the market in many years |
Sales on these heads must've skyrocketed. Flow numbers and engine build combos to compare . Affordable off the shelf heads with great flow numbers as cast. Easily putting out near power numbers of what a 42 valved head would do. Next ground up engine that I get to do without a head choice, I'm going to give this one a whirl.
This is a perfect small cc performance build or bus engine build head in my eyes.
Keep the tech details coming. Need a samba member to build with it with their example and post what they can pull from it. Who's it gonna be ?! _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
Pizza Eater Samba Member
Joined: October 10, 2013 Posts: 81 Location: Chico, CA
Posted: Tue Jul 05, 2016 1:57 pm Post subject: Re: Best street head to hit the market in many years |
Hello Mr Downs,
Do you have dyno numbers for these heads on a 2110 with a 2288 (K8) cam?
How about a 2292 (FK-10) cam?
Thank you for your time.
-Jeff |
