dcarlson12 Samba Member
Joined: May 04, 2014 Posts: 71 Location: Surrey, BC, Canada
Posted: Wed Jun 22, 2016 3:43 pm Post subject: Oil level mystery |
Just finished rebuilding the Bug engine in my wife's 66. Converted to 1600 from 1300.
Yesterday I poured in 2 litres of oil and then waited and measured the level on the dipstick and it was mid way between the two 'indicator' lines.
I then added 0.5 litres which I thought would have brought the level up to the highest line.
Today, I preparation to starting the engine, I left the plugs out and the distributor disconnected and turned the engine over for maybe 20 to 30 seconds with the starter to try to prime the oil pump and get the oil light to extinguish. It did not go out so maybe the engine has to actually run for a short time to get the pump to prime and bring up the pressure.
In any case, about a half hour later I again checked the oil level and it now reads mid way between the two lines again.
I didn't actually check the level after putting in the full 2.5 litres yesterday.
I don't understand why it is not reading a the highest line.
I can't believe that there is 0.5 litres of oil sitting in the oil passages in the engine or am I wrong? _________________ The 'caretaker' of my wife's 66 bug; her dream car. |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Wed Jun 22, 2016 4:21 pm Post subject: Re: Oil level mystery |
One thing you did while cranking the engine: you filled the oil cooler. _________________
EverettB wrote: |
FU#5 |
KTPhil Samba Member
Posted: Wed Jun 22, 2016 4:54 pm Post subject: Re: Oil level mystery |
hitest wrote: |
One thing you did while cranking the engine: you filled the oil cooler. |
I wondered about that, too, upon initial fill and crank. But won't most of it drain back in a few minutes? |
Posted: Wed Jun 22, 2016 4:58 pm Post subject: Re: Oil level mystery |
Actually a few minutes after making the initial posting, I checked the level again and it had crept higher.
I will see what it is like in the morning after sitting overnight.
The oil is 20w50 so it is what I would call on the 'thick' side and because it was/is at ambient temperature, it takes longer to drain back down. _________________ The 'caretaker' of my wife's 66 bug; her dream car. |
KTPhil Samba Member
Posted: Wed Jun 22, 2016 5:10 pm Post subject: Re: Oil level mystery |
20W-50 isn't all that thick. Cold it's like a 20wt, but hot stays thicker hot more like a 50wt would.
Today they use 5wt oil but engines are made to far closer tolerances than our old beasts. |
Posted: Thu Jun 23, 2016 11:41 am Post subject: Re: Oil level mystery |
Well this morning the level is about 1/8" below top line. Thus my post was kind of a waste of time and space.
Should I delete it? _________________ The 'caretaker' of my wife's 66 bug; her dream car. |
bluebus86 Banned
Posted: Thu Jun 23, 2016 12:09 pm Post subject: Re: Oil level mystery |
dcarlson12 wrote: |
Should I delete it? |
no, maybe not, still a useful post me thinks.
there are no dumb questions!!!!! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Thu Jun 23, 2016 12:10 pm Post subject: Re: Oil level mystery |
NAW.....a lesson for the newbees. Book says 2.5 but I always put in a full three qts.
(VW mechanic retired) |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Thu Jun 23, 2016 2:52 pm Post subject: Re: Oil level mystery |
HRVW wrote: |
But that is most likely due to the VW of Mexico stock oil filter/pump. Filter will take about 1/2 quart of oil to fill it. _________________ In Stereo, Where Available! |
cyclehobby Samba Member
Joined: August 29, 2013 Posts: 156 Location: North Jersey
Posted: Fri Jun 24, 2016 10:18 am Post subject: Re: Oil level mystery |
I would just recommend being cautious about possibly over filling. That can be bad. Consider also that your dipstick may not be correct for your year and therefore may be reading wrong.
Though I've rarely seen an aircooled VW that did not drip oil, I know that when I filled mine to the high mark on the dipstick, it took 3 quarts plus a little. When I changed the oil and put in the required 2.5, the oil level was smack dab in the center of the two dipstick lines.
I left it that way, now considering that as full and besides not using as much oil, I notice I'm leaking less as well. Bug runs great in all weather temps as well.
BTW, I use 20/50 weight in warm weather. _________________ 1967 Beetle
Northern NJ |
Posted: Fri Jun 24, 2016 10:54 am Post subject: Re: Oil level mystery |
cyclehobby wrote: |
BTW, I use 20/50 weight in warm weather. |
Suggest against that high of weight of oil. You need the oil to thin down enough to let the oil pressure relief valve to close up to send most of the oil to the oil cooler when engine is up to operating temp. Not going to do that when oil acts like 50 weight when hot and bypass the oil cooler. _________________ In Stereo, Where Available! |
Zundfolge1432 Samba Member
Posted: Sat Jun 25, 2016 9:43 am Post subject: Re: Oil level mystery |
Attention the W in the SAE classification stands for winter. Dont take my word for it, look it up. It has nothing to do with weight. As the earlier post suggested new engines will take 3 full qt of oil to fill, if using a filter pump even more. Why ? You are filling the cooler, oil galleys, pushrods even the rockers and the valve covers will have a coating or pooling of oil. Some of it will pool behind the main seal as well. It all adds up. |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Sat Jun 25, 2016 6:48 pm Post subject: Re: Oil level mystery |
Something that everybody has missed here--------the o.p. increased his engine from 1300 to 1600. That is about a 23% increase.
So -------2.5x 1.23=3.075
Hope this helps. |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
KTPhil Samba Member
Posted: Sat Jun 25, 2016 9:29 pm Post subject: Re: Oil level mystery |
iowegian wrote: |
Hope this helps. |
Displacement and oil capacity are not related. |
Posted: Sun Jun 26, 2016 2:22 pm Post subject: Re: Oil level mystery |
KTPhil wrote: |
iowegian wrote: |
Hope this helps. |
I guess that was a bad joke, huh? |
KTPhil Samba Member
Posted: Sun Jun 26, 2016 2:37 pm Post subject: Re: Oil level mystery |
iowegian wrote: |
KTPhil wrote: |
iowegian wrote: |
Hope this helps. |
I was'nt sure... so I gave straight line.
As a joke it was damn funny, though! |
Posted: Sun Jun 26, 2016 4:27 pm Post subject: Re: Oil level mystery |
KTPhil wrote: |
iowegian wrote: |
KTPhil wrote: |
iowegian wrote: |
Hope this helps. |
I'm glad you clarified that Iowegian...I was a little worried for a second. I could just see all the newb's blowing out their front seals _________________ My father's 1970 Beetle-
http://www.thesamba.com/vw/forum/viewtopic.php?t=603879
The 1964...Diamond in the rough
http://www.thesamba.com/vw/forum/viewtopic.php?t=612776
My 1958 Morocco Bug-
http://www.thesamba.com/vw/forum/viewtopic.php?t=611483 |
