Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Mon Jun 27, 2016 6:59 am Post subject: Wiper Shaft Grommet replacement |
When I first got my 64 last year, I loaded up on a bunch of different grommets/seals and such. Been replacing them as I go and at the point where I need to replace the wiper shaft grommet. Is there anything I need to watch for when doing this? I'm assuming its somewhat of a PITA, as nearly every Bug I've seen has had the shaft grommets painted over vs taking them out and replacing them much like the door scrapers and vent rubbers.
Any secrets or "hacks" as the cool kids say these days?
In looking at the exploded diagram on WW, why are there two grommets shown in the assembly? Are there two used per side? One inner and one outer?
http://www.wolfsburgwest.com/wolfsburg_new/electrical/bug_electrical_misc/wipe_assem.cfm
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Jun 27, 2016 7:03 am Post subject: Re: Wiper Shaft Grommet replacment |
Just need to pull out the wiper assembly and replace the grommets. Most get painted over as they don't want to remove the wiper assembly. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Mon Jun 27, 2016 7:05 am Post subject: Re: Wiper Shaft Grommet replacment |
60ragtop wrote: |
Just need to pull out the wiper assembly and replace the grommets. Most get painted over as they don't want to remove the wiper assembly. |
Is the wiper assembly that much or a bear to get in and out? |
Posted: Mon Jun 27, 2016 7:09 am Post subject: Re: Wiper Shaft Grommet replacment |
not really, just some finagling around to get it out. More so if you have a radio. _________________ Rick
tasb wrote: |
sb001 wrote: |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Mon Jun 27, 2016 7:52 am Post subject: Re: Wiper Shaft Grommet replacment |
Be sure you disconnect the battery ground terminal first! |
Posted: Mon Jun 27, 2016 7:53 am Post subject: Re: Wiper Shaft Grommet replacment |
KTPhil wrote: |
Ok.
Any input on why the diagram shows two grommets on the shaft? |
Posted: Mon Jun 27, 2016 8:06 am Post subject: Re: Wiper Shaft Grommet replacment |
generic pic? some models had two split grommets on each shaft while some had a one piece with a center groove that sandwiches the sheet metal. _________________ Rick
tasb wrote: |
sb001 wrote: |
Posted: Mon Jun 27, 2016 8:08 am Post subject: Re: Wiper Shaft Grommet replacment |
60ragtop wrote: |
generic pic? some models had two split grommets on each shaft while some had a one piece with a center groove that sandwiches the sheet metal. |
Ok. Good enough. Just wanted to make sure I didn't need another set before I start tearing crap apart and then have to wait a week for the new ones to come in. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5600 Location: 37.5N 77.1W
Posted: Tue Jun 28, 2016 5:38 am Post subject: Re: Wiper Shaft Grommet replacment |
I needed some grommets for the wiper shafts, like 'right now'. Went to Harbor Freight and bought the assortment of grommets. It had several in the size needed. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Posted: Tue Jun 28, 2016 5:41 am Post subject: Re: Wiper Shaft Grommet replacment |
runamoc wrote: |
I needed some grommets for the wiper shafts, like 'right now'. Went to Harbor Freight and bought the assortment of grommets. It had several in the size needed. |
Cool, good info to have. |
grandpa pete Samba Member
Posted: Tue Jun 28, 2016 7:38 am Post subject: Re: Wiper Shaft Grommet replacement |
grandpa pete wrote: |
HI Sharp64 Please post a couple of photos as you go ;
Wiper motor install is on my short list and any help or suggestions is appreciated ... |
Should I have one of my daughters video me throwing wrenches across the garage as well when it starts pissing me off? |
gt1953 Samba Member
Posted: Tue Jun 28, 2016 2:39 pm Post subject: Re: Wiper Shaft Grommet replacement |
Do consider also part 14 and 15 they do ware out.
Um do you have a manual?? The removal is not that difficult take you time and do not force anything. Take photos along the way. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Tue Jun 28, 2016 2:42 pm Post subject: Re: Wiper Shaft Grommet replacement |
gt1953 wrote: |
Um do you have a manual?? The removal is not that difficult take you time and do not force anything. Take photos along the way. |
I have not purchased the Bentley manual yet. Having a tough time coming off of $100 for it. So far I've done ok with getting diagrams and such for the projects I've needed to do. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26310 Location: Douglas, WY
Posted: Tue Jun 28, 2016 3:56 pm Post subject: Re: Wiper Shaft Grommet replacement |
Some years ago, I remember on one or maybe both of my bugs, having trouble with a purchased "correct" single grommet - it was just too tight for the wiper shaft, so I cut it into two halves like the Service Manuals showed (why they call it a "bearing seal" I don't know. Maybe because it "bears" on the body there? I added the notation about where the body of the vehicle goes)
_________________ Andy T.
Posted: Tue Jun 28, 2016 4:13 pm Post subject: Re: Wiper Shaft Grommet replacement |
gt1953 wrote: |
14 and 15 are the wiper shafts? Considering the amount of years I know this car sat either in storage or on an import dealers lot, I sincerely doubt they are worn out. |
pwmcguire Samba Member
Joined: January 30, 2011 Posts: 1108 Location: Kennesaw GA
Posted: Tue Jun 28, 2016 6:09 pm Post subject: Re: Wiper Shaft Grommet replacement |
Sharp64 wrote: |
gt1953 wrote: |
If you go this far, there are plastic bushings at the pivot points, that are worn. You can get them from WW. |
Posted: Tue Jun 28, 2016 6:11 pm Post subject: Re: Wiper Shaft Grommet replacement |
Sharp64 wrote: |
gt1953 wrote: |
If you go this far, there are plastic bushings as well, that are worn. You can get them from WW. |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
