OrangeMango Samba Member
Joined: April 12, 2015 Posts: 114 Location: Sacramento, California
Posted: Mon Jun 27, 2016 1:53 pm Post subject: Engine runs too hot, need external cooler advice |
Last year summer time my dad was driving my 72 super and it over heated, killed the engine. I bought a 72 parts car and took the engine and rebuild it and put it in mine. Now just last Saturday on the highway it over heated. I live in Sacramento California and it was 100'F on Saturday. I'm dropping my engine, taking my heads off and checking my pistons and tightening my heads back on if everything is good (I'm getting 0 compression that's why I'm gonna look at the pistons) I feel like I need a external oil cooler but not sure the best rout to go.
Should I install it and where? I know if I install it I'm also putting a tac for the oil temp in.
But then I saw this video where the guy completely replaced the oil cooler and I don't know what's better?
https://m.youtube.com/watch?v=z8Ixkusrq70
Please give me some advice. |
Mos6502 Samba Member
Posted: Mon Jun 27, 2016 2:14 pm Post subject: Re: Engine runs too hot, need external cooler advice |
Is the engine stock? Have you tried a simple solution like stand-offs for the deck lid already? |
Brian Samba Moderator
Posted: Mon Jun 27, 2016 2:20 pm Post subject: Re: Engine runs too hot, need external cooler advice |
A stock engine shouldn't overheat in 100f weather. There are other issues going on. Get the motor drilled for full flow and use a filter but get the overheating sorted. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
FeelthySanchez Samba Member
Joined: February 03, 2011 Posts: 1349 Location: Now is that a real poncho, or a Sears poncho?
Posted: Mon Jun 27, 2016 2:27 pm Post subject: Re: Engine runs too hot, need external cooler advice |
Zero compression means that at least a top end job is in order.
It's also a good opportunity to upgrade to FFF.
Assuming it's still in place, using the native/OEM doghouse oil cooler is some sound advice. _________________
modok wrote: |
I would like if you had enough clue to communicate what you are doing. |
Ryan Tucker wrote: |
Enough clue..Whats that mean? |
OldIronSpine wrote: |
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Mon Jun 27, 2016 2:49 pm Post subject: Re: Engine runs too hot, need external cooler advice |
If you have cooked the heads and cylinders, a bigger oil cooler won't really help you very much as they are air cooled. You need to know why the engine is overheating.
Are you running the stock thermostat? What carb and distributor? Original 1972 shroud and fan? All cooling tin in place? Original deck lid with slots? Rubber engine compartment seal in place? _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Mon Jun 27, 2016 4:31 pm Post subject: Re: Engine runs too hot, need external cooler advice |
Yes everything is stock, yes it has the tin wear, I don't believe anything is missing.
I called up my local vw place and they said overheating in 100f weather is gonna happen cuz all its getting is hot air, now idk if they're right or not but it's only happens on the highway, to and from work it's fine (about 5 miles to work) but that's not an extended drive. |
busdaddy Samba Member
Posted: Mon Jun 27, 2016 4:40 pm Post subject: Re: Engine runs too hot, need external cooler advice |
OrangeMango wrote: |
I called up my local vw place and they said overheating in 100f weather is gonna happen cuz all its getting is hot air |
Only if something's terribly wrong, I'd drive anywhere in 100* weather, VW sold these cars in markets that got a whole lot warmer than that regularly without any issues.
Tell us about how you have that 009 timed, and what you found when you dismantled that new carb I see on your engine, any crap in the jets?, and exactly what jets were installed in there? Also describe how your last valve adjustment went. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Jun 27, 2016 4:44 pm Post subject: Re: Engine runs too hot, need external cooler advice |
B.S. They work driving them in Arizona desert, 115F here !!!
it only happens on the highway |
Yes, these do run hotter at extended highway operation in hot weather. But I've made countless round-trips in mid-summer across I-10 to California and back to Arizona, and in 1835cc engine to boot !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
gt1953 Samba Member
Posted: Mon Jun 27, 2016 5:38 pm Post subject: Re: Engine runs too hot, need external cooler advice |
OrangeMango Said Yes everything is stock, yes it has the tin wear, I don't believe anything is missing.
Something is obviously wrong. New professional build should be next. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Q-Dog Samba Member
Posted: Mon Jun 27, 2016 5:42 pm Post subject: Re: Engine runs too hot, need external cooler advice |
The only recommendation VW made for hot weather driving was to use thicker oil ...
'69 Dune Buggy
'70 Beetle |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Mon Jun 27, 2016 5:50 pm Post subject: Re: Engine runs too hot, need external cooler advice |
You should NEVER need an external oil cooler for a stock engine. I live in CA also, and right now it's 104. However, I am still driving my 2010cc Baja down the freeways at 70 mph with 4:86 gearing (3,750 RPM). What am I using for cooling? A Type 4 cooler in the stock doghouse location, that's it. Yes its a little bigger then stock, but so is my engine. You are either having problems with your flaps, are too lean, or have too much timing. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Posted: Mon Jun 27, 2016 6:04 pm Post subject: Re: Engine runs too hot, need external cooler advice |
Your sparkplugs should tell you if you're running too lean. What do they look like? |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Mon Jun 27, 2016 6:34 pm Post subject: Re: Engine runs too hot, need external cooler advice |
I lived in Modesto and drove a 71 super daily for two summers, even after an hour of freeway driving at 70MPH with a 1600DP engine, 21mm oil pump, 10/30 oil, I still had 15PSI idle hot pressure and 195° maximum oil temperature, with an outside temperature of 110° so something is missing or wrong with your engine. A properly built and lubricated engine should not need an external cooler, even up around 2L engine displacement. The engine is aircooled, not oil cooled, cooling the oil more will not being down head temps. _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Mon Jun 27, 2016 6:46 pm Post subject: Re: Engine runs too hot, need external cooler advice |
Been hotter than hell,times like these a fella needs to roll off the throttle,let it cruise..the boys at bugformance been doing this shit a long time.. |
goober Samba Member
Posted: Mon Jun 27, 2016 6:58 pm Post subject: Re: Engine runs too hot, need external cooler advice |
Cooking the engine and ending with zero compression is not good. Sounds like you've got major problems that an external cooler won't cure. We don't have the thermal mass of a water cooled engine. If the cooling system fails engine/head temps will build quickly to damaging levels. A cylinder head temp gauge should be standard equipment.
Do what others have recommended here. If you pull the heads replace all the exhaust valves. Check your cylinder head studs to determine if they're pulling out especially if they're the older 10mm studs mounted directly into the case.
As for coolers, this is what I'm running but it's not for everyone. I've never run the doghouse cooling system but everyone says it's the best way to go. I have a non-doghouse housing with the stock oil cooler removed and an adpter in it's place. There are winter advantages to putting the coolers after the pressure relief/control valves and out of the cooling air stream. The flap link on the non-doghouse is easily modified to go over the hoses. I've had no cooling problems in over 100 degF temps. Pushing hard down the highway, heads will stay under 340 degF.
Posted: Tue Jun 28, 2016 12:50 am Post subject: Re: Engine runs too hot, need external cooler advice |
The spark plugs look fine, not burnt or anything. Running 10-40 oil on the trip. This engine I put new piston rings on, adjusted the valves the best I could myself, engine ran fine for an entire month (only has been in for little over a month) I had the cab rebuilt by a local shop my family trusts, has rebuilt all of our carbs for our cars. Studs are original and most of the nuts as well, might sound stupid to run original nuts but the damn ones from orilies always strip on me so I don't trust them anymore. |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Tue Jun 28, 2016 4:18 am Post subject: Re: Engine runs too hot, need external cooler advice |
goober wrote: |
Wow, just wow. The advantage of this over just running the stock setup is??? |
Posted: Tue Jun 28, 2016 4:53 am Post subject: Re: Engine runs too hot, need external cooler advice |
Many factors can result in a heat related engine failure..since you've basically re ringed a used engine its hard to tell what caused it..proper ring fit and ring groove cleaning is critical for cylinder life for instance...tear it down and show the failure, its how to begin an analysis. |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Tue Jun 28, 2016 5:26 am Post subject: Re: Engine runs too hot, need external cooler advice |
You may need advice, but not about bling coolers....Check your engine bay tar board is not loose, and sucking into - and blocking - the fan
Some of us run double/treble the factory power in daily drivers at 100+F with standard everything |
