antihero11 Samba Member
Joined: March 22, 2015 Posts: 15 Location: inland empire
Posted: Tue Jun 28, 2016 5:46 pm Post subject: 1966 vw bug generator/ fan belt help |
hey!
i just recently purchased my new baby, 66 bug
i recently had to replace the generator but when i installed it, i noticed when i spin the generator it makes a scratching noise from what i suppose is rubbing the fan shrout, also i replaced the fan belt with the belt size it originally had but fits to big so i got a half inch smaller but it fits too tight :/
any tips or tricks out there to get through this funk would be appreciated,
thanks! |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
Posted: Tue Jun 28, 2016 6:08 pm Post subject: Re: 1966 vw bug generator/ fan belt help |
Hi there, welcome to the Samba.
When you replaced the generator I'm assuming you swapped the fan and backing plate from one to the other, right?
You should remember some thin shims between the fan and the backing plate. Well, you need to determine whether the fan is rubbing the shroud or the backing plate. If it's hitting the fan shroud then move a shim or two from between the fan and backing plate to under the nut holding the fan on. If it's the fan hitting the backing plate move the shims from under the nut to in between fan and backing plate.
Same idea for the belt. Shims get moved from under the nut and cup to between the pulleys to loosen the belt and moved out from between the pulley to tighten the belt. _________________ My father's 1970 Beetle-
http://www.thesamba.com/vw/forum/viewtopic.php?t=603879
The 1964...Diamond in the rough
http://www.thesamba.com/vw/forum/viewtopic.php?t=612776
My 1958 Morocco Bug-
http://www.thesamba.com/vw/forum/viewtopic.php?t=611483 |
samstheman Samba Member
Joined: August 18, 2015 Posts: 239 Location: whittier
Posted: Tue Jun 28, 2016 6:57 pm Post subject: Re: 1966 vw bug generator/ fan belt help |
When I put mine back together after powder coating tins same thing happen. Fan was hitting shroud I just loosened hold down strap smacked backwards towards the fan shroud lightly on pulley face and tightened strap down again untill no noise then put on belt and turned over with wrench to make sure all was happy. It was the relationship between fansroud and generator was getting forced at a very slight angle when all was tightend just loosen generator and make sure it's not getting pulled to far forward or backwards. Helped for me. |
Posted: Wed Jun 29, 2016 12:20 pm Post subject: Re: 1966 vw bug generator/ fan belt help |
awesome!
will put this to the test,
thank you! |
