dave1 Samba Member
Joined: September 12, 2003 Posts: 478 Location: United Kingdom, London
Posted: Sat Jul 02, 2016 3:51 pm Post subject: 52 oval or split beetle |
Trying to get some help on this split beetle its a 1952, split dash with oval rear window the owner has said that the rear window has been replaced although he is unable to find any welds as it has old head lining still fitted & doesn't want to remve it. I asked if it was a zwitter & person has said it is not. The birth certificate details are listed below. Is it possible to get clarification with the info to say wheather it is a split beetle as I've seen several that have been updated to look like ovals
thanks for your assistance
Dave
unable to upload Birth certificate details.Listed as follows
Vehicle ID 1-0 323 708
Model 11C VW Limousine export model
Motor 25PS 1.1 ltr
colour nicht registriert
built on 5th Feb 1952
left factory 7th Feb 1952
Country Kopenhagen
Extras M007 M035 |
Joshua B Samba Member
Joined: January 03, 2004 Posts: 273 Location: Colorado
Posted: Sat Jul 02, 2016 4:03 pm Post subject: Re: 52 oval or split beetle |
All '52s were splits. So it seems it would be a rear window modification if the VIN is for a 52. Looks like the pan number or engine number you gave is for a January '51. Have him give you the body number as well. (below the vin plate).
Yes a January or February '52 would be a split dash split. If the rear post was just cut out, you can tell by the "oval" will be pointer than a graphed oval from a later car. |
dave1 Samba Member
Posted: Sat Jul 02, 2016 4:15 pm Post subject: Re: 52 oval or split beetle |
Hi Joshua,
thanks for your reply. The person said it was definitely an oval window as he said they are a different shape to the split window with the centre post removed. The person has said that he obtained measurements which indicate it's an oval window
cheers Dave |
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Sun Jul 03, 2016 8:10 am Post subject: Re: 52 oval or split beetle |
It was not uncommon to just cut the split bar.
The result is an oval looking window with little differend shape to the original later oval window.
If the car now has an oval window with original shape, then the whole split window section must have been replaced by an later oval window section.
That was done also sometimes.
For sure an early 1952 did not came with an oval window. Just not.
No matter what the owner tells. _________________ Master of my domain! |
allsidius Samba Member
Joined: February 02, 2010 Posts: 1475 Location: Norway
