zoobyshoe Samba Member
Joined: June 26, 2014 Posts: 461 Location: San Diego, Ca.
Posted: Tue Jul 05, 2016 4:30 am Post subject: Death of a Condenser (with Autopsy) |
So, a few days ago I was beetling down the road, and out of nowhere, the engine started all kinds of unacceptable tomfoolery: spluttering, loss of power, misfiring, hesitation, refusal to accelerate. I pulled over and fiddled with various things for an hour or so, and ended up with it running fine again.
Couple days later, same thing again. I checked vacuum lines and the needle valve especially. After a while, I started it up, and it was fine. Later, though, on the return trip, all the problems returned: sort of a mixture of what it's like when you're running out of gas and only running on 3 cylinders. Luckily, it was down hill all the way home, and I got it back home despite the ailment. But a new symptom cropped up: on top of the other stuff, it backfired a couple times.
I got out my manuals and fired up the Samba archives, and the internet in general, and read for a few hours. Basically, everything said this could either be a fuel system or electrical problem. My points, condenser, wires, and plugs are all less than two months old, so I attacked the carb: pulled it off and sprayed out every orifice and jet 20 times. Then I put it back together and went to sleep. Next morning, when I tried to start the car, all I got was a big backfire.
More reading. I ran into reports that brand new but crappy condensers sometimes fail after a very short time. On the remote off chance I might have bought the worst brand new condenser ever, I took it out and put the old one back in.
She started right up, and 30 miles later with no return of the problem, I think that was probably it: the new condenser.
I performed an autopsy on the brand new Autozone Duralast condenser that seems to have failed and found some damning badness inside. Here is some photographic documentation of the procedure:
I cut the rolled over "lip" off the can off with a hacksaw. That's the ring around the green wire. Once that's off, I pulled out the rubber plug which insulates one end of the condenser. That's the black thing the green wire goes into.
Pull the rubber plug all the way out, and out drops a little silver "soup can" looking type thing. That is the condenser plates, all rolled up. Notice they are not soldered to anything, or even mechanically connected in any way.
Here is a shot of the inside of the can and the end of the condenser plates. They are clean and shiny: no problems here.
Here is the other end of the plates and the steel contact that is what is on the inside end of the green wire. These don't look so good.
Close up of above elements. You can see this is where the condenser fried. There has been a lot of high voltage sparking between these two things.
This is how the steel contact plate is attached to the green wire (the abrasions on the wire are from the hacksaw slipping when I cut the can open. There are similar marks on my fingers. No pics of that, though.):
Starting to unroll the condenser plates. The plates are, as far as I can tell, common aluminum foil. I miked one and it is about .0003 thick. The clear plastic insulation between the foil is about .0005 thick. There are two layers of foil and two layers of plastic. The two layers of foil are offset from each other: one sticks out about 1mm on one side, the other about 1mm on the other side. Once they are rolled up, the excess that is offset is just crushed to the bottom on the can on one end of the roll, and to the steel contact on the other end of the roll.
Here's all the intestines unrolled. I didn't find any evidence of sparking or burning inside; no insulation breakdown between the plates.
The aluminum foil (one plate or layer) is about .670 wide and about 137 inches long. That's an area of 91.79 square inches. It would be a square measuring only about 9.5 inches on a side (though it seems like it'd be larger than that from the pile you see.)
So, what this autopsy reveals is that this is very old, uncomplicated technology. The basic design of these condensers prolly hasn't changed since the 1930's when the car was first designed. Now they use plastic to separate the plates. Back then they used wax paper. It ain't no kind a fancy.
Why did it fail? I don't know. Maybe it was just manufacturing procedure: the rubber insulator wasn't pressed in far enough, leaving a poor contact between the steel and aluminum, inviting a spark to jump and burn the metal. That's plausible, but really just speculation.
Anyway, this is what is going on inside an Autozone Duralast condenser. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
vamram Samba Member
Posted: Tue Jul 05, 2016 5:12 am Post subject: Re: Death of a Condenser (with Autopsy) |
Cool. Is German Bosch condenser the same inside, but w/the wax paper? _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Tue Jul 05, 2016 5:42 am Post subject: Re: Death of a Condenser (with Autopsy) |
1. Autozone did not manufacture that condenser.
2. My two German-made 009 distributors are still running their original condensers, 4 decades in !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Mojo07470 Samba Member
Joined: November 29, 2015 Posts: 66 Location: New jersey
Posted: Tue Jul 05, 2016 6:24 am Post subject: Re: Death of a Condenser (with Autopsy) |
The biggest reason VW,s are unreliable and performance is poor. All the parts today are junk I don't care where you buy them they're junk. Carbs distributers mufflers fuel pumps. None of these items work as they should. I went to electronic ignition. I figured if I could carry points and condenser well, I could just carry a spare module. Theres nothing wrong with points and condenser If you can get quality parts. |
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Tue Jul 05, 2016 6:34 am Post subject: Re: Death of a Condenser (with Autopsy) |
I've had 2 breakdowns with my Beetles and both times it was because the condensers took a crap, and both were relatively new Bosch condensers bought from reputable vendors, so I'm not convinced that Bosch condensers are any more reliable. Personally I would be willing to pay double the price for quality reliable parts but I don't know of anyone out there that sells them. I also had 2 new Bosch alternators that were junk as soon as I took them out of the box, so don't think that just because the name "Bosch" is on the part it's good.
And thanks for dissecting a condenser. Interesting.
A little tid bit on how a business works. The vendors do not make the parts. They buy the parts from a business that makes the parts. Chances are very good if you buy a part from any vendor that part was made by the same place. For instance, I bought a front tranny mount a few years ago but the studs for the front were to short and I couldn't use it. I checked with every vendor for the mount with the correct length studs but they were all short studs. One vendor finally admitted to me that there is only one company that makes these mounts so no matter where you buy them it will be the short studs. |
vamram Samba Member
Posted: Tue Jul 05, 2016 6:51 am Post subject: Re: Death of a Condenser (with Autopsy) |
Dwayne1m wrote: |
I've had 2 breakdowns with my Beetles and both times it was because the condensers took a crap, and both were relatively new Bosch condensers bought from reputable vendors, so I'm not convinced that Bosch condensers are any more reliable. Personally I would be willing to pay double the price for quality reliable parts but I don't know of anyone out there that sells them. I also had 2 new Bosch alternators that were junk as soon as I took them out of the box, so don't think that just because the name "Bosch" is on the part it's good.... |
Maybe Cusser will sell you one of his 40-y/o condensers!! _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3898 Location: Seattle, WA
adam78 Samba Member
Joined: November 11, 2013 Posts: 219 Location: Jersey Shore USA
Posted: Tue Jul 05, 2016 9:22 am Post subject: Re: Death of a Condenser (with Autopsy) |
hmmm Im having those exact symptoms, and I just got finished completely redoing my carb, changing vacuum lines, and replacing the vacuum plugs trying to figure out why...and I did replace the condenser as preventative maintenance a few months ago...Now I know if it's not broke dont fix it! I'll be throwing an electronic ignition in it and be done with it. It did wonders for my bus and runs great. _________________ 1975 Beetle 1600dp 4spd Daily Driver.
1972 Westy 1600 Type IV 4spd project/ soon to be driver. |
wcfvw69 Samba Purist
Posted: Tue Jul 05, 2016 10:31 am Post subject: Re: Death of a Condenser (with Autopsy) |
Autozone is the absolute worse FLAPS joint out there. I don't think they sell much of anything that's not made in China. They are the Wal-Mart of parts resellers. I don't shop at Autozone.
Napa still sells good parts and I don't mind paying more for them either. There are lots of reports of folks running original Bosch made condensers for decades w/no issues.
I bought a used original Bosch DVDA distributor and took it all apart to clean, inspect and re-lube it. It had clearly not been used in years though it was stored inside. It had original Bosch points and condenser in it that look to have been made in the 70's. The points block had lots of life on it still and the points only required a file. I put them both on the rebuilt distributor, greased the points cam and they work like new.
There have been lots of reports of brand new Bosch condensers shitting the bed right away. I think this is why many VW veterans are running old condensors.
Bosch parts use to be a quality name but now there parts for classic VW's should be looked at with suspicion. _________________ Contact me at [email protected]
The Samba member since 2004.
sb001 Samba Member
Posted: Tue Jul 05, 2016 11:14 am Post subject: Re: Death of a Condenser (with Autopsy) |
wcfvw69 wrote: |
I'm no autozone apologist, but just like any FLAPS store some of what they sell is decent quality and some of it is crap. I've been running an aautozone bought speedo cable and throttle cable for a couple years and neither has given me any trouble. Lots of folks on here have had good luck with a rebuilt autostick style duralast starter.
I have no problem with Napa except that a lot of their parts are significantly more expensive, and I've never seen any real proof that all their stuff is made in the USA or consistently better quality. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
davidw99 Samba Member
Joined: September 04, 2003 Posts: 696 Location: Boston, MA
Posted: Tue Jul 05, 2016 12:05 pm Post subject: Re: Death of a Condenser (with Autopsy) |
Cusser wrote: |
2. My two German-made 009 distributors are still running their original condensers, 4 decades in !!! |
Makes me mad for throwing out all of the condensers I have over the years because Muir said "change the condenser at the same time as the points. They go together like bread and butter" or words to that effect. _________________ Dave
'73 Saturn Yellow Sports Bug that has undergone a full pan off restoration. "Herbert IV."
'67 Sedan. "Bellamy." Currently being "refreshed" and recently repainted.
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3284 Location: Rapid City, SD
Posted: Tue Jul 05, 2016 12:34 pm Post subject: Re: Death of a Condenser (with Autopsy) |
I have lost a few new condensers in the last few years. Last one was a week ago with less then 400 miles. It was a genuine Mallory one too.
Here is a trick I learned from an old timer.
Next time you think you have a bad condenser, and have the symptoms listed above, grab a pair of pliers form your tool bag, and smash the condenser. Just pinch it tight. I have done this, and almost every time it will get you home. Also helps your trouble shooting.
Upon your return home, contact your favorite retailer and order a Pertronix module. Some people think they fail all the time, but these days, they seem to be failing way less then a brand new condenser.
Brian |
Old n' slow Samba Member
Joined: October 29, 2012 Posts: 619 Location: Western Maryland
Posted: Tue Jul 05, 2016 1:45 pm Post subject: Re: Death of a Condenser (with Autopsy) |
davidw99 wrote: |
Cusser wrote: |
Makes me mad for throwing out all of the condensers I have over the years because Muir said "change the condenser at the same time as the points. They to together like bread and butter" or words to that effect. |
45 years ago my Universty of Oklahoma auto mechanics instructor told us, you have more of a chance of getting a bad new condenser than the old one going bad.
I was never sure if I should believe him.....I guess he was right. _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
All my daily drivers gone but not forgotten;
1964(sunroof)1967 & (2)1968 Beetles , 1968 Squareback , 1963 (23 window )Deluxe Sunroof Bus , 1969 Westphalia camper, 1974 Dasher , 1985 Vanagon , (2) 1981 Rabbit Diesels & a 1991 Jetta Diesel . |
Posted: Tue Jul 05, 2016 2:17 pm Post subject: Re: Death of a Condenser (with Autopsy) |
Brian_e wrote: |
Brian |
Or... simply look on this site or ebay and buy the Bosch NOS condensers made in the 60's or 70's.. They are still plentiful and w/most of these old VW's being non-daily drivers, will last decades. _________________ Contact me at [email protected]
Posted: Tue Jul 05, 2016 2:40 pm Post subject: Re: Death of a Condenser (with Autopsy) |
Brian_e wrote: |
Next time you think you have a bad condenser, and have the symptoms listed above, grab a pair of pliers form your tool bag, and smash the condenser. Just pinch it tight. I have done this, and almost every time it will get you home. Also helps your trouble shooting. |
I was thinking if this ever happened to me again I would get a firm grip on the wire where it enters the rubber insulator and push it hard into the condenser. The idea is to make better contact between the wire and the aluminum cap plate.
This link posted by kreemoweet above pretty much echos my assessment that the problem seems to be a lack of reliable, solid contact between the condenser plates and the electrical leads in and out:
In other words, it's not the insulation between the plates breaking down under high voltage, it's simply that all these manufacturers, all of them, are getting sloppier and sloppier in connecting the condenser plates to the electrical leads.
The condensers in kreemoweet's link are for a completely different car, mind you, and attempt the connection in a somewhat different way, but the author of that link finds they are failing for the same reason my Beetle cap failed: the connections suck from the get go, and they start sparking and burning till eventually, current can no longer pass.
Cusser may be right that his 40-year condensers have a solid soldered or mechanical pinched contact. Or, they might have the same kind as the ones that fail, and it's just that a whole bunch of dimensions were kept in strict tolerance during manufacture and assembly. Can't say without opening one up, but that wouldn't be worth it.
When I was googling, I came a cross a forum for HVAC maintainence. Apparently, those guys have been getting called more and more often the past few years for problems that end up being failed capacitors. They were bitching about the general quality of caps lately, and no one had a good lead on which manufacturer was reliable anymore. So, that's an indication it's not just caps made for old cars that suck lately, but that the whole 'capacitor industry' is going down the tubes.
A capacitor is such a simple thing, there is no reason it should ever fail. |
Posted: Tue Jul 05, 2016 3:28 pm Post subject: Re: Death of a Condenser (with Autopsy) |
sb001 wrote: |
wcfvw69 wrote: |
I have no problem with Napa except that a lot of their parts are significantly more expensive, and I've never seen any real proof that all their stuff is made in the USA or consistently better quality. |
I just left Advance Auto after three years, it was amazing to see how China replaced Mexico etc. as the source of replacement parts in just those three short years. VERY SAD ALSO. _________________ Currently own : 1969 Beetle w/ 1600cc, Single Port, Solex 30 PICT 2, Dist. 113 905 205 T, stock exhaust.
Posted: Tue Jul 05, 2016 6:30 pm Post subject: Re: Death of a Condenser (with Autopsy) |
zoobyshoe wrote: |
I was thinking if this ever happened to me again I would get a firm grip on the wire where it enters the rubber insulator and push it hard into the condenser. The idea is to make better contact between the wire and the aluminum cap plate. |
Actually, on second thought, it would probably be a better idea to push the whole black rubber thing into can as far as possible.
I checked and it seem the rubber thing does not grip the wire at all. The wire slides through the hole pretty easily. The rubber thing, on the other hand, is a fairly tight fit in the can. If you can get the rubber thing any further into the can it will stay in place better than the wire alone will.
I'm thinking the secret of the "planned obsolescence" here is to not roll the lip of the can over far enough during manufacture to hold the rubber far enough down into the can. It's pushed in far enough when you first buy it, but then creeps back out once you install it due to heat and vibration until a gap opens up enough for sparking to occur.
If that's the case, the hack would be to rig up some kind of little bracket that puts permanent pressure on the rubber and prevents it from creeping back out. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Jul 05, 2016 7:18 pm Post subject: Re: Death of a Condenser (with Autopsy) |
If you were to stick the wire through a hole in the workbench or a plate and give the can a moderate whack to increase the crimp action it may temporarily improve the rubber to contact squish factor, just trying to think of a suitable anvil when doing this roadside. A wheelnut would work on a bus, but not so much on a bug, lug hole in the spare maybe? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
