3foldfolly Samba Member
Joined: March 08, 2009 Posts: 894 Location: Edwardsville, Il
Posted: Wed Jul 06, 2016 8:04 pm Post subject: Reman trans concerns |
I would like expert opinions on the trans I received from Rancho today. Perhaps these are non-issues. They found my original case had a hole in it and that nose cone housing had a crack. Pricing was reasonable for replacement case and nose cone. My original case had a clutch release arm that was curved toward the center of the case. The trans arrived with a straight arm that does not align with the bowden tube bracket. My concern here is that the clutch cable and bowden tube end may wear prematurely and the cable may drag due to misalignment. I was told the trans is a 12 volt and the old one was 6 volt and it was a non issue. The trans is certainly a 6 volt as the starter bushing hole is 5/8" and not 1/2". My other concern is the tail shaft housing has a crack starting at the hockey stick bushing area. Should I be concerned about these?
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Thu Jul 07, 2016 12:47 am Post subject: Re: Reman trans concerns |
call em up and ask for a different one _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Posted: Thu Jul 07, 2016 5:56 am Post subject: Re: Reman trans concerns |
I bought a Rancho trans and had similar problems- the (used) nosecone had a super sloppy bushing in it that certainly would have caused slop in the shifter. The packaging was substandard in my opinion, the cardboard box it was shipped in was worn through in several places allowing the trans to stick through.
Call them, they'll send you a new nosecone. You'll need to do something with the bracket or arm to get the cable to line up.
Once my minor issues were resolved my trans works great after several thousand miles.
Good Luck! _________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Thu Jul 07, 2016 6:44 am Post subject: Re: Reman trans concerns |
Bruce Amacker wrote: |
Call them, they'll send you a new nosecone. You'll need to do something with the bracket or arm to get the cable to line up. |
Sucks that type of low-hanging fruit stuff didn't get caught before it left the shop. Now to deal with from so far away + more work in your lap (that you paid them to do).
Let us know how it turns out. _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Thu Jul 07, 2016 9:57 am Post subject: Re: Reman trans concerns |
Call and ask them to send out a good nosecone, a clutch lever with the correct bend and a 6V case to 12V starter bushing. You could be ballsy and ask for a labor credit or start a dispute with you CC company. |
EmpiGT Samba Member
Posted: Thu Jul 07, 2016 10:10 am Post subject: Re: Reman trans concerns |
EverettB wrote: |
Is it just me or does that case look really pitted?
The side plates look corroded where they match up to the case too.
Maybe it doesn't matter as long as everything seals up?
I would definitely want a new nose cone at a minimum. |
I was thinking the same thing Ev, that case looks like a road salt area case or one sitting out in rain and mud if so the inside is just as bad if not worse. and He was charged the core fee for a case and nose cone. sounds almost like they just wanted to trade cases with him and get rid of this one. and charge him for it.
3foldfolly, did you ever see a hole in your transmission case you sent in?
In all trannies I've seen I've never seen just a hole??? cracks, busted in half, and corrosion yes, but to get a hole from corrosion it would be so obvious you would never send it in to get rebuilt.
At this point I think I would force them for a complete replacement. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Thu Jul 07, 2016 10:36 am Post subject: Re: Reman trans concerns |
3foldfolly wrote: |
...the clutch cable and bowden tube end may wear prematurely and the cable may drag due to misalignment. |
That combo is common although not correct. It will probably be ok and you will be able to get to the engine bolt/nut easier. It will wear a groove as it self-aligns.
3foldfolly wrote: |
The trans is certainly a 6 volt... |
If your flywheel is 6 volt then it's ok. If your flywheel is 12 volt then the bellhousing must be clearanced. The bushing will depend on which starter you pick.
3foldfolly wrote: |
...the tail shaft housing has a crack... |
They did that when they put in the seal/bushing new thing or the dogleg hit on something during delivery. Not good and not acceptable.
I am not an expert. |
Posted: Thu Jul 07, 2016 10:37 am Post subject: Re: Reman trans concerns |
EverettB wrote: |
Yes, Everett, we have this stuff called road salt that we use in the winter. Maybe you've never experienced this in Phoenix.....
My guess is that they send the rotted cases where they came from- he's in IL which also uses a lot of salt.
I've had tranny cases rot though on trucks, as well as diff housings, engine blocks, and of course frames. Nothing unusual around here. _________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Thu Jul 07, 2016 10:41 am Post subject: Re: Reman trans concerns |
New nose cone for sure, that is not good. The pitting on the case has no bearing on the inside, it may well be spotless inside. I've rebuilt a few that have looked way, way worse on the outside. As for the clutch arm, I do everything in my power to eliminate the evil curved shaft. It puts the cable directly in line with the upper engine bolt, and can be such a pain. To aim the Bowden all you need to do is spend a few minutes modifying the Bowden support with a die grinder. I open the back end of the hole up, in other words make it an oval, but just on the engine side. Then clean up the surface where the tube seats, so it sits square to the arm. Or there is a bolt on steel bracket..
I once spent about 30 minutes under my 65, with my wedding ring pinched tightly between the engine bolt and the clutch cable, because of that arm. I had been using a ratcheting box wrench to loosen the engine bolt, and when the bolt bottomed on the cable, the wrench was stuck. I was trying to loosen the arm when it slipped and caught my ring. After 20 or so minutes of trying, laying on my back the finger went numb. I ended up ripping the heat exchanger operating lever off, and using it to pry the arm away. Would've been the most stupid way to have lost a finger.. _________________ modok wrote:
60freak Samba Member
Joined: October 08, 2002 Posts: 861 Location: Indiana
Posted: Thu Jul 07, 2016 12:01 pm Post subject: Re: Reman trans concerns |
Unacceptable, and I would be talking to them about a replacement trans IMO. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Thu Jul 07, 2016 3:26 pm Post subject: Re: Reman trans concerns |
Get the right clutch cable arm or go thru broken cables about every 6,000 miles instead of 30,000+ miles.
New nose cone!
You are missing the steel bell shaped seat for the clutch return spring. #73 in the diagram below:
As for the corrosion pitting, as long as it seals up it is fine, but if that is clean magnesium would use a high zinc primer and paint over that to help keep future corrosion away for as long as possible. _________________ In Stereo, Where Available! |
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Thu Jul 07, 2016 4:24 pm Post subject: Re: Reman trans concerns |
EverettB wrote: |
being in the salt belt myself, the case looks pretty good. the nose cone however looks like a pitted mess, and the crack is a deal breaker for sure
you know, it's funny....so I sent a trans back for a core once...was very clean on the outside. the dinged me 100.00 for "excessive corrosion"
though to myself you f*ckers sent me a case worse than the one I sent you....
I understand they have to reuse some of this stuff, but don't piss on my foot and tell me it's raining... _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Thu Jul 07, 2016 4:56 pm Post subject: Re: Reman trans concerns |
EmpiGT wrote: |
EverettB wrote: |
To multiple people:
Ok, understood on the road salt.
To the tranny owner:
Is it cracked in the upper right where the engine bolt pass through the case too?
That may just be more surface corrosion. _________________ How to Post Photos
Posted: Thu Jul 07, 2016 6:13 pm Post subject: Re: Reman trans concerns |
I called today and spoke to Dave (the guy who has handled the whole deal for me). He said he would next day air me another nose cone, gasket and curved release arm per my request. I am somewhat disappointed in the whole transaction (no pun intended). I was initially told about a 3 week turn around and it was over 2 months. My original case was not corroded as the bus has been stored inside for 30 years and never driven in rain much less snow. It has always leaked from the side cover areas but I could never tell exactly from where because the previous owner smeared RTV over most everything in a failed attempt to abate the leak. Perhaps there was a hole there.Dave never said exactly where the hole was and I didn't press the issue. I agree with Barryl that the nose cone crack is probably the result of the bushing installation. The nose cone and main housing are more corroded than I would of preferred but I think its more cosmetic than functional. The gear carrier housing looks clean.The curved arm makes it a bitch to install or remove the upper left engine mounting bolt as I'm running a AH case single port 1600 but I think it's worth it to get some inline geometry on the cable routing. I will have to open up the bell housing as I did for the original case 30 years ago but the bushing will be a non issue as I am running an autostick starter. The clutch arm return spring cup is there, just hard to see to see in the photos. I asked them specifically to not paint the case as VW didn't paint them new from the factory. I intended to, and will satin clear coat the case to help prevent further corrosion. That is not another crack at the left upper bolt area, just a streak of discoloration. |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Thu Jul 07, 2016 8:30 pm Post subject: Re: Reman trans concerns |
The curved arm is a nightmare for a doghouse case. You can heat the straight arm up and put a little bend in it to move it closer but not enough to block access with a socket. |
easy e Samba Member
Posted: Thu Jul 07, 2016 9:30 pm Post subject: Re: Reman trans concerns |
campingbox wrote: |
Thanks for the advice Greg. For doghouse... have you ever heated a curved arm to bend it away a fuzz? _________________ aka: Evan
Posted: Thu Jul 07, 2016 11:07 pm Post subject: Re: Reman trans concerns |
easy e wrote: |
campingbox wrote: |
Thanks for the advice Greg. For doghouse... have you ever heated a curved arm to bend it away a fuzz? |
Absolutely. Remove it from the transmission first. You don't want to be catching that stuff on fire.
I have never noticed that cable alignment issue before on straight arms and have not had very many cables break before (knock on wood).
I have had nosecones crack in that same spot before while installing that style bushing. I don't think that crack would affect its performance at all although it's not pretty. |
EmpiGT Samba Member
Posted: Thu Jul 07, 2016 11:30 pm Post subject: Re: Reman trans concerns |
on another note are those non seamed axle boots or are they the seamed type with the seam pointed straight down. if so you need to relocate the seam, that's a leak waiting to happen. |
Posted: Fri Jul 08, 2016 3:35 am Post subject: Re: Reman trans concerns |
EmpiGT wrote: |
Non-seamed. |
