agon.parts Samba Member
Joined: August 21, 2010 Posts: 273 Location: Central Coast, CA
VWinVT Samba Member
Joined: April 21, 2013 Posts: 1541 Location: North East Kingdom
Posted: Sun Jul 10, 2016 12:53 pm Post subject: Re: In-line AC System | In Progress |
How does this work? _________________ 1981 Westfalia with a 2001 Cabrio ABA
Small wheel turns by the firing rod,
Big wheel turns by the grace of God.
Every time that wheel turns 'round,
You're bound to cover just a little more ground. |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1890 Location: Montreal
Posted: Sun Jul 10, 2016 12:58 pm Post subject: Re: In-line AC System | In Progress |
Peltier cooler???
Good luck with that. Couldn't even cool a cooler let alone a van interior. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Sun Jul 10, 2016 1:58 pm Post subject: Re: In-line AC System | In Progress |
Quote: |
How does this work? |
As mentioned above by Wellington:
Yes, it does consist of Peltier or solid state coolers.
Thanks for the luck. These types of coolers are used in many different applications, i.e., large-scale commercial equipment cooling, military vehicle/equipment cooling, etc.
The main concern in any application where solid state coolers are used is heat. Since these devices function based on a temperature differential, i.e., the 'cold' side's temperature is relative to the 'hot' side's temperature.
I have designed it in such a way that the maximum amount of heat is transferred to the larger heat-sinks. The inlet of the in-line AC system is equipped with small vents that blow air onto the larger heat-sinks, reducing the temperature further, thus reducing the temperature of the 'cold' heat-sinks on the interior of the device. Since solid state coolers function as either ON or OFF, the small vents that blow air use the stock front blower's speed as a method of designating the temperature, i.e.:
Fan speed: 1, lower air-flow, lower cooling
Fan speed: 2, medium air-flow, medium cooling
Fan speed: 3, higher air-flow, higher cooling.
I will be documenting the performance of the device as I go.
As of now, without the unit installed, the interior heat-sinks get to approximately 60 degrees Fahrenheit / 15 degrees Celsius. _________________ Forrest Walker Whitmore
AGON
FREEBIES: https://1drv.ms/u/s!AkqzgREEtE9Aj7poRLxLuW-oGORuiQ?e=eSKThT |
Forthwithtx Samba Member
Joined: July 14, 2014 Posts: 717 Location: Fort Worth
Posted: Mon Jul 11, 2016 4:52 am Post subject: Re: In-line AC System | In Progress |
This is a new one on me. I have never heard of this technology.
Seems to me you could get one more module in there if you went to a square cross section instead of round, and transition to round on the ends. But, you're the inventor.
I'm gonna have to put a watch on this topic. Looks very interesting!
Cheers,
Karl _________________ Cheers!
-Karl
'84 GL with 2001/2004 Subaru 2.5L |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Mon Jul 11, 2016 6:24 am Post subject: Re: In-line AC System | In Progress |
Also curious about current draw...??? _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Syncro Jael Samba Member
Posted: Mon Jul 11, 2016 6:38 am Post subject: Re: In-line AC System | In Progress |
This technology is not new and people have tried to adapt it to automobiles. It works in some applications mainly in electronic devices.
Here is some reading:
http://electronics.stackexchange.com/questions/167168/car-a-c-using-peltier-devices-is-it-feasable
Good luck with your project it is fun technology. _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
Abscate Samba Member
Posted: Mon Jul 11, 2016 6:56 am Post subject: Re: In-line AC System | In Progress |
A rough swag of an auto cooling system capacity is 5000 Watts
Thermo tells us it to move energy from the typical ambient to car comfort temperature takes about 1/3 of the cooling capacity or about 1500 Watts.
Thermo also tells us it doesn't matter how we do this - with compressors, Peltier, Bose Einstein condensation, Quantum mechanical tunneling....pick your Poisson.
Once you figure out how to power an auto accessory with 1500 watts power, or 100 Amps at 12 Volts, you are all set. _________________ .ssS! |
Zeitgeist 13 Samba Member
Posted: Mon Jul 11, 2016 9:20 am Post subject: In like Flint |
If you can rotate that thing backwards, then I'll believe it _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Mon Jul 11, 2016 11:09 am Post subject: Re: In-line AC System | In Progress |
dhaavers wrote: |
Also curious about current draw...??? |
With the units wired in series they are pulling ~6 Amps.
The technology is definitely not new. It has been around for almost 200 years now! Interesting that there are only a few companies who dedicate themselves to developing efficient uses of this technology.
Abscate wrote: |
Thermo tells us it to move energy from the typical ambient to car comfort temperature takes about 1/3 of the cooling capacity or about 1500 Watts. |
Car comfort temperature is relative to the end-user.
This method focuses on the application of fluid dynamics as a method of increasing the efficiency of the system without the need to draw hundreds of amps.
Zeitgeist 13 wrote: |
If you can rotate that thing backwards, then I'll believe it |
I'm not sure I understand what you mean... _________________ Forrest Walker Whitmore
AGON
Posted: Mon Jul 11, 2016 11:15 am Post subject: Re: In-line AC System | In Progress |
That was a little inside joke for the longtimers around here. It essentially references the skepticism one can face when taking an unconventional pathway toward achieving a project goal. Carry on. _________________ Casey--
y u rune klassik? |
Posted: Mon Jul 11, 2016 11:30 am Post subject: Re: In-line AC System | In Progress |
That was a little inside joke for the longtimers around here. It essentially references the skepticism one can face when taking an unconventional pathway toward achieving a project goal. Carry on. |
Haha skepticism is definitely present. It's nothing but motivation _________________ Forrest Walker Whitmore
AGON
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Mon Jul 11, 2016 11:40 am Post subject: Re: In-line AC System | In Progress |
I have been doing head scratching on this for a while too. It makes sense if you figure out a way to use a large solar array. At the time I looked at it, it would take the entire top of my Westy, and some ingenuity on some panels on the sides as well. Moisture issues were plaguing my ideas tho. Another side of this, although it is optimized for cooling, it can also be used to heat.
I am "in" on this project, way to go on the design, looking good. If I am guessing right, there may be a need for a handful of these around the cabin of my Westy. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Mon Jul 11, 2016 1:14 pm Post subject: Re: In-line AC System | In Progress |
Cooling a Vanagon interior with..
6 watts * 14 Volts = 84 Watt draw.
You can just catch the APS Division of Fluid Dynamics deadline for a paper of AUG 1 if you hurry. Ill be there, so that will be cool to see. It does help to Reynolds wrap your Fan Shroud, or Froude, as they call it. _________________ .ssS! |
Posted: Mon Jul 11, 2016 2:17 pm Post subject: Re: In-line AC System | In Progress |
bobbyblack wrote: |
I am "in" on this project, way to go on the design, looking good. If I am guessing right, there may be a need for a handful of these around the cabin of my Westy. |
Awesome! Do you have any prototypes/sketches that you have made? If so, it would be great to see.
Yes, the device could be used to heat as well. It would most likely be an easier device to develop. I have tested my prototype by simply inversing the polarity and it heats up quickly. However, you'd still run in to the issue of the temperature differential; one side's temperature is always relative to the opposite's.
Yes, there may be a need to install multiple devices throughout a van.
Abscate wrote: |
I think you mean 6 Amps *14V = 84 Watt draw, but yes, the draw is very low in comparison to other systems. _________________ Forrest Walker Whitmore
AGON
90Doka_Guy Samba Member
Joined: April 08, 2007 Posts: 548 Location: South Jersey
Posted: Mon Jul 11, 2016 4:00 pm Post subject: Re: In-line AC System | In Progress |
Maybe I missed it, but how will the hot side air be removed from the interior? and what about condensate? If you have the ability, temperature delta and airflow numbers across the cold side would be very telling. Not to be a naysayer, but even at 100% efficiency, 84 watts inst a whole lot of heat being removed.
I have one of those on my desk, a small ~40watt unit with a big heat sink and fan on it that I bought just to screw around with. I thought about making some sort of single beer chiller with it but never got around to it. This post just made me fire it back up.
I like the packaging though, 3D printed? _________________ -'87 Westy
-'90 Tintop
-'90 DOKA |
Posted: Mon Jul 11, 2016 4:26 pm Post subject: Re: In-line AC System | In Progress |
Keane wrote: |
I like the packaging though, 3D printed? |
In regards to the hot-side air being removed from the interior, it technically isn't being removed from the vehicle, but rather cooled within the vehicle.
In regards to condensation, I plan on having the outlet portion of the device fitted with a small weep hole. I designed the device in three parts: inlet, middle, outlet. This will give me the opportunity of testing different options as I go without the need to replicate the entire object (Yes, it was 3D-printed). _________________ Forrest Walker Whitmore
AGON
?Waldo? Samba Member
Posted: Mon Jul 11, 2016 4:43 pm Post subject: Re: In-line AC System | In Progress |
forrest.whitmore wrote: |
In regards to the hot-side air being removed from the interior, it technically isn't being removed from the vehicle, but rather cooled within the vehicle. |
?? If you are not moving the heat from the interior of the vehicle to the exterior of the vehicle you will not be doing any cooling of the interior air. It sounds a lot like you're trying to plug an extension cord into itself with a Y adapter so you can plug a second device into the loop. |
Posted: Mon Jul 11, 2016 4:49 pm Post subject: Re: In-line AC System | In Progress |
You can couple the heat back into the electrons and then dissipate the energy climbing back up the potential gradient of the negative terminal of the battery - thus recharging it while you cool.
Is there IP or, even better, an IPA on this? _________________ .ssS! |
