Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Mon Jul 11, 2016 6:40 pm Post subject: Blaupunkt AM dual voltage radio |
So a friend of mine was nice enough to set me up with a Blaupunkt AM dual voltage radio for my '64.
I bench tested it and it works, lights up, dials & buttons work, and pulls in radio signals fine. From what I could find, this was originally for a 67/68 Type 1?!
(Mods - If it's a '68 & up please move this thread) Can anyone in the know confirm this? Thanks.
I plan to swap dial knobs with grey ones to match the other dash controls and connect it to a DIN to 1/8" jack converter and have more options than just AM stations. |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Mon Jul 11, 2016 11:47 pm Post subject: Re: Blaupunkt AM dual voltage radio |
Mark: your radio looks like an "all transistor" radio, OK for 68..up. Knobs are similar to window regulator knobs of 68.. beetle.
The ones posted by flyboy161 are "tube" radio, the chassis (not shown in brochure) is tall to contain vertical tubes.
To answer to your question: no, this radio is not correct if you assume that a car should have a radio available in the age of its construction.
But a lot of radios were mounted aftermarket and after some years from the car purchase so the choice is up to you.
My hint: for a US beetle a Motorola, sapphire, etc. radio is the one you should find into a '64, because in the sixties German radios where too expehnsive for the US market (beetle is a 'poor' car) and FM was not popular in US until the 70's. |
Mark Samba Member
Posted: Tue Jul 12, 2016 7:40 am Post subject: Re: Blaupunkt AM dual voltage radio |
I don't have it in front of me at work, but the white decal on the side reads Y 7 637 150, with a serial number below that. It also reads Blaupunkt with some other German writing on it. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Tue Jul 12, 2016 7:44 am Post subject: Re: Blaupunkt AM dual voltage radio |
Those look like '67 Bug knobs.
I think the Conelrad dial markings continued after '63 on many radios that used older model dials for a few more years.
There are websites dedicated to old car radios. Googling model numbers might also give hits. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Tue Jul 12, 2016 7:50 am Post subject: Re: Blaupunkt AM dual voltage radio |
there should be a tag on the side, with the model name and serial number. thet will tell you the age
as for Porsche / VW - no. These were aftermarket and/or dealer sold. You just bought what you wanted and was in your budget. Quite often right after making your last payment _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Mark Samba Member
Posted: Tue Jul 12, 2016 7:54 am Post subject: Re: Blaupunkt AM dual voltage radio |
Thanks for the replies.
Phil, that's what I found after a few minutes Googling. Best guess indicates it's from a '67. It might as well be, to go with the '67 only generator in there
*edit* Erik, there is no model name on the decal, only a series of numbers and where it was made. I know what you mean, as I've had Blaupunkt radios that had the name on the decal, (Hamburg, Frankfurt, etc).
Posted: Wed Jul 13, 2016 12:14 am Post subject: Re: Blaupunkt AM dual voltage radio |
CONELRAD... very interesting. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Wed Jul 13, 2016 12:28 am Post subject: Re: Blaupunkt AM dual voltage radio |
I had a loaner 1968 Beetle some years ago that had that radio in it. You're in the correct ball park here. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
fly2kads Samba Member
Joined: July 09, 2012 Posts: 148 Location: Roanoke, TX
Posted: Wed Jul 13, 2016 1:26 pm Post subject: Re: Blaupunkt AM dual voltage radio |
For future reference, Everett compiled this list of Blaupunkt date codes some time back:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279505
I found it very helpful recently...perhaps it will be to others, as well. |
camfella04 Samba Member
Joined: November 07, 2016 Posts: 85 Location: Ottawa Canada
Posted: Tue Jan 17, 2017 11:40 am Post subject: Re: Blaupunkt AM dual voltage radio |
I recently got myself one of these radios. How do I connect it up to test it?
My knowledge is pretty limited...I looked at the original picture and see a yellow wire (I have a yellow wire) attached to what I would believe to be a power source, no?
I also recently got an Automatic Radio of Canada Ltd. (Model WP-2289 Series P) that I am trying to test.
All help is greatly appreciated! |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2506 Location: Santa Cruz, CA
Posted: Tue Jan 17, 2017 1:57 pm Post subject: Re: Blaupunkt AM dual voltage radio |
camfella04 wrote: |
I recently got myself one of these radios. How do I connect it up to test it? |
That radio probably only has three connections on the rear...one wire for power, one output for the speaker (which could be either a twin-lead wire or a plug-in jack) and a jack for the antenna. The yellow wire is most likely the power connection. To bench-test it, just hook up a speaker, an antenna, and a power source to match how the radio is set up (either 6V or 12V).
Here's a website for info on Blaupunkt radios:
http://derwhites356literature.com/DerWhitesBlaupunktRadios.html
If you need to have your radio repaired, check out Radioman in San Diego CA, or Electro-Tech in Blaine MN. You should be aware that fixing a non-working vintage car radio isn't cheap. Expect to pay around $250 to put yours right again if you find that it doesn't play. Sometimes it's more cost effective to just buy another radio that already works.
http://www.radiomanrepair.com/
http://www.turnswitch.com/radio1.htm _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
Posted: Wed Jan 18, 2017 9:45 am Post subject: Re: Blaupunkt AM dual voltage radio |
Thanks rcooled, greatly appreciated. |
