olspeed Samba Member
Joined: May 01, 2008 Posts: 489 Location: In the shadow of Denali, I still don't give a damn how they do it outside
Posted: Wed Jul 20, 2016 9:41 pm Post subject: Water in the gas |
Ok If it was carbs it would be running again. Some back round, it's a 91 Jetta 1.8 gas that my son got from his Grandmother and it is the epitome of the little old lady car. 68000 miles up until last week it ran fine, my son stopped by one of the cheapie gas stations that we have up here and put 5 gallons in, well it did make it the 35 miles to the house but died and wouldn't start not even a pop. We changed the fuel filter thinking that because he had run it so low that it was plugged but when we pulled the old filter and dumped the remaining fuel in a metal drain pan it didn't have a gas smell and when we tried to light it, it would put out the paper towel even a propane torch would not set it on fire. When we drained the tank we got about 2 gallons of water out of it. So far we have drained the fuel pump and lines and the fuel rail and per the recommendation of the local VW service center up here(it's 75 miles away) we changed the injectors and now it will fire and run momentarily but dies after two to three seconds... so what am I missing on this thing, is it something simple or should I take it out to the back 40 and give it the colonel potter treatment. :2gunfire: _________________ 66- Ghia
76-Beetle |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Thu Jul 21, 2016 7:24 am Post subject: Re: Water in the gas |
You might try flushing it again. The FI cars recirculate the fuel, so you could still have water in it. Pretty sure the 91's have a pre-pump and then a pump, are both working? |
Posted: Thu Jul 28, 2016 6:57 am Post subject: Re: Water in the gas |
So Finally got my son back to work on his car.. He is busy, EMT and working a second job so I can't give him too much grief. We had drained the fuel return line when we were doing the tank as I had thought of that and yes this thing does have a pre-pump in the tank that we removed yesterday and nope it doesn't work so he's hoping to get one today and we will give that a try as he's running the wheels off of my plow truck. I'll give everyone an update when and if he finds a pump, thanks for the help. _________________ 66- Ghia
76-Beetle |
Posted: Sun Aug 07, 2016 3:40 pm Post subject: Re: Water in the gas |
HI all, I'm olspeed's kid. so we got the pre pump in and it stared up and ran for a few moments. I killed it and went in for the night but came out the next morning to start it and now it wont start again or even fire. checked both pumps and they are working. Not quite sure were to go next. It is getting fuel up to the log on the injectors. Could water have taken something else out? _________________ 66- Ghia
76-Beetle |
ps2375 Samba Member
Posted: Sun Aug 07, 2016 4:43 pm Post subject: Re: Water in the gas |
Spark? |
Posted: Sun Aug 07, 2016 4:53 pm Post subject: Re: Water in the gas |
yes it has spark. and if you spin it over for 15 to 20 seconds (kinda hard on my starter) it will fire one or two cylinders but will not start. _________________ 66- Ghia
76-Beetle |
ps2375 Samba Member
Posted: Sun Aug 07, 2016 5:21 pm Post subject: Re: Water in the gas |
Pull a plug and see if it's wet. |
Posted: Wed Aug 10, 2016 12:40 pm Post subject: Re: Water in the gas |
Hi all. Pulled all plugs,they all were carbon'd but the last two were a little wet. I just did a fuel pressure test at the log and found its at 40-45 Psi. From what I found online that's within spec. I have also noticed that my battery is draining. All lights and anything else is off but if we let it sit a few days the battery doesn't have enough juice to even turn the starter. I don't know if this might be part of my fuel problem. at this point I don't know where to go other than to let my dad take it out back and give it the colonel Potter Treatment. _________________ 66- Ghia
76-Beetle |
ps2375 Samba Member
Posted: Wed Aug 10, 2016 12:45 pm Post subject: Re: Water in the gas |
Charge the battery.....a low battery won't recharge from sitting, it'll just get lower. And while you are buying tools, get a Bently manual for the car and follow the troubleshooting procedures within it. |
Posted: Wed Aug 10, 2016 9:15 pm Post subject: Re: Water in the gas |
Battery is on the charger and he's looking for a book but it looks like we are going to have to order one as there doesn't seem to be one available up here, I've called around and I haven't even been able to a Haynes manual let alone a Bentley. _________________ 66- Ghia
76-Beetle |
ps2375 Samba Member
Posted: Thu Aug 11, 2016 7:38 pm Post subject: Re: Water in the gas |
TKS
Ordered, should be here next week. I still can't believe no one carries a book for this thing up here as there are still a ton of them running around. _________________ 66- Ghia
76-Beetle |
Posted: Wed Aug 17, 2016 1:14 pm Post subject: Re: Water in the gas |
So yesterday my son came in telling me that he had found a book at one of the local FLAPS it's a Haynes and looks like it was used... dirty finger prints and all. Well we at least got the vacuum diagram from it and that helped as it runs and will accelerate now but the idle is way to low, it will drop back down to 400-500 hundred and just barely run oil light flickers and such. Anyway the Bentley manual hit today and with a quick comparison we might as well throw the Haynes in the trash or take it back. So now to figure out what the idle problem is, I'll be reading that section here shortly and I just might get my truck back! thanks for the help. _________________ 66- Ghia
76-Beetle |
ps2375 Samba Member
Posted: Wed Aug 17, 2016 1:31 pm Post subject: Re: Water in the gas |
Check out the procedure for setting the timing, you have to disconnect and plug the idle air lines and a CTS to tell ecu it is in a timing setting mode. And check for vacuum leaks, as usual. |
