49vwsplit Samba Member
Posted: Fri Jul 22, 2016 5:56 pm Post subject: Fine Coating of Oil All Over Motor and Tins |
I have a '55 with a period correct engine.
There is fine film all over the engine and engine bay. Is it from the case vent hose that passes thru the right side of the engine tin leading from the oil filler stand? I'm suspecting it is and being an air cooled engine the air turbulence is blowing the oil all over the place. Anyone else have this issue?
My main concern is that I drip oil when the car is at rest and when I visit friend's homes I feel bad leaving an oil stain behind. If this fine oil residue is due to that case vent tube has anyone routed it thru a Puke Bottle set up? _________________ Officer: License and registration please.
Driver: What's the problem officer?
Officer: It indicates here you require glasses to operate a motor vehicle.
Driver: It's OK officer, I don't wear glasses..I have contacts.
Officer: I don't care WHO you know!! |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1293 Location: south san francisco
Posted: Fri Jul 22, 2016 8:31 pm Post subject: Re: Fine Coating of Oil All Over Motor and Tins |
you probably have a lot of blow by.you need to do a leak down test. .i suspect you need a ring job at least. no good running motor needs a puke can unless you dont want to fix it and still drive. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
Posted: Fri Jul 22, 2016 10:20 pm Post subject: Re: Fine Coating of Oil All Over Motor and Tins |
49vwsplit wrote: |
There is fine film all over the engine and engine bay. Is it from the case vent hose that passes thru the right side of the engine tin leading from the oil filler stand? I'm suspecting it is and being an air cooled engine the air turbulence is blowing the oil all over the place. Anyone else have this issue? |
Maybe I am reading this wrong but the tube you describe exits under the engine so I'm not sure how oil mist from that location would get back into the engine compartment.
I have had that breather tube drip some oil when stopped on my old '55 with a well-used engine but it's minimal.
It could be the seal under your oil filler/breather leaking a little, depending on how much oil is covering everything. _________________ How to Post Photos
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Sun Aug 07, 2016 4:29 pm Post subject: Re: Fine Coating of Oil All Over Motor and Tins |
Is the top of the generator stand open to inside of the case? if the generator clamp was loose it would leak.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
mark tucker Samba Member
Posted: Tue Aug 09, 2016 2:19 pm Post subject: Re: Fine Coating of Oil All Over Motor and Tins |
find the leek, start with a through cleaning. the clean it again real good. then use some paper towels to see how clean you got it sand clean it again everywhere. then use the papertowels again and find the leek or mist or seep. |
jason Samba Member
Posted: Sun Aug 14, 2016 10:12 am Post subject: Re: Fine Coating of Oil All Over Motor and Tins |
Is it a hose or tube. Original is a tube. If it is a hose you may be missing something. A straight hose will leak if there isnt some type of catch. The 36er has baffles in stand, picture? |
Posted: Sun Aug 14, 2016 10:07 pm Post subject: Re: Fine Coating of Oil All Over Motor and Tins |
earthquake wrote: |
Is the top of the generator stand open to inside of the case? if the generator clamp was loose it would leak. |
Yes, it is on a 36hp.
It is possible for oil to come up from the stand under the generator if it's not sealed.
jason wrote: |
I think the baffle was only an option, not stock on all 36ers. _________________ How to Post Photos
