weswsimpson Samba Member
Joined: September 29, 2015 Posts: 191 Location: Chicago
Posted: Sun Jul 24, 2016 5:15 am Post subject: Re: After Market Cruise Control: What's available in 2016 |
I had a fiat 124 spider that had a cable actuated hand throttle. When you reached a cruising speed on the highway, you pulled the cable out, give a quarter turn and it locked in place. Not high tech... but it worked driving in Ohio. |
OddN Samba Member
Joined: August 19, 2010 Posts: 690 Location: Northern Norway
Posted: Sun Jul 24, 2016 5:17 am Post subject: Re: After Market Cruise Control: What's available in 2016 |
djkeev wrote: |
Here are Rostra's online instructions, they cover how to hook up various VSS systems quite effectively.
http://www.rostra.com/manuals/250-1223Form4565G.pdf
One thing that I miss about living in NJ are old time junk yards! They just simply do not exist in my area.
I make do.......
Dave |
Excellent instructions. The vss input range is very much adjustable through a series of switches.
Come to think about it, I don't actually know if the original vss delivers one or more pulses per revolution...
And on a 2wd the wire turns only half as fast as on a syncro. Hope it is still within the range of this unit. _________________ 1991 VW Multivan syncro 1,9 TD |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
jimf909 Samba Member
Posted: Sun Jul 24, 2016 6:42 am Post subject: Re: After Market Cruise Control: What's available in 2016 |
weswsimpson wrote: |
I used to have a garden tractor with that same feature. _________________ - Jim
Abscate wrote: |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Sun Jul 24, 2016 7:45 am Post subject: Re: After Market Cruise Control: What's available in 2016 |
djkeev wrote: |
Now, for those of you with either the Rostra Electonic unit or GoWesty's kit,
A question.......
Rostra clearly states in their literature that the unit makes noise while operating, for this reason they suggest that it NOT be mounted in the passenger cabin.
BUT this is exactly what GoWesty has apparently done.
Do you hear the unit operating while driving?
Dave |
Dave
Oh yea it makes noise, especially when it disengages. It sounds like a big magnet letting go of something held under tension by a spring. CLAK .
Once adjusted it works well, But if in an under powered vehicle I would stick to using it on the flat grounds.
I put one in a 1.9 A/T Westy, when it reaches a hill it goes CLAK and shuts off.
I found the unit to be well thought out and generally straight forward to install if your skill set is above average.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Posted: Sun Jul 24, 2016 8:47 am Post subject: Re: After Market Cruise Control: What's available in 2016 |
^^^ Good point on the CLAK. I can hear My Rostra and it's in the engine bay (unlike the GW Rostra). Now I'm in the habit of putting my foot on the accelerator pedal when releasing the CC which minimizes the CLAK.
Regardless, adding the CC has been one of my favorite mods. I use it often, both for setting speed on stretches of 25 mph road or on the highway. It works consistently and holds the speed well. Just don't expect it to take the throttle from say, 35% to 85% as your foot would do when climbing a hill. It'll either slow down or release completely and ask the human to take over. _________________ - Jim
Abscate wrote: |
minnisp Samba Member
Posted: Sun Jul 24, 2016 10:05 am Post subject: Re: After Market Cruise Control: What's available in 2016 |
I was working on a list of rostra parts actually needed. The base unit is $167 but that doesn't include a switch. add the switch and the vss mag kit, and the clutch disengagement kit and it's $292.00 for manual (amazon). I think to install rostra (for later vans) it's more labor intensive, but without the gowesty install instructions i'm still not sure. I will ask gowesty for the install doc and see if they will send them. if i get them i'll try to post them.. _________________ 1989 GL 2.1 WBX Manual |
Posted: Sun Jul 24, 2016 10:15 am Post subject: Re: After Market Cruise Control: What's available in 2016 |
minnisp wrote: |
I was working on a list of rostra parts actually needed. The base unit is $167 but that doesn't include a switch. add the switch and the vss mag kit, and the clutch disengagement kit and it's $292.00 for manual (amazon). I think to install rostra (for later vans) it's more labor intensive, but without the gowesty install instructions i'm still not sure. I will ask gowesty for the install doc and see if they will send them. if i get them i'll try to post them.. |
My thought is this,
If you look at your self honestly and honestly answer that you don't have the skills/experience to fabricate and improvise mechanics and fasteners.....
OR
You don't have the time or you don't have the desire to do so,
The extra $150 for the GoWesty kit is money wisely spent.
Ghia
Vanagon
Beetle
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Sun Jul 24, 2016 11:33 am Post subject: Re: After Market Cruise Control: What's available in 2016 |
minnisp wrote: |
So GoWesty does the work to engineer an installation for your van and then puts together a kit with all of the needed components and includes detailed instructions plus telephone support if needed, and you want to obtain a copy of the instructions (minus the kit) and then reprint them.
Wow. Good catch moderators...... _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
Fuzzyip Samba Member
Posted: Sun Jul 24, 2016 12:18 pm Post subject: Re: After Market Cruise Control: What's available in 2016 |
I bought the gowesty cruise control and westy werks is installing it this week. I will let you all know how it is. |
oldskewlsk8ter Samba Member
Posted: Sun Jul 24, 2016 1:50 pm Post subject: Re: After Market Cruise Control: What's available in 2016 |
Im using a vss that Jeff (jrobewesty) supplied with my suby harness. I'm currently in the middle of hooking up the rostra universal unit, and while it isn't a stock wbx, there's no reason you couldn't use the same vss found in this thread http://www.thesamba.com/vw/forum/viewtopic.php?t=613930&highlight=vss _________________ 1986 Hightop w/EJ25 DOHC & 4EAT auto
1965 Kombi project |
Posted: Sun Jul 24, 2016 1:51 pm Post subject: Re: After Market Cruise Control: What's available in 2016 |
Placeholder for a pic of how I have the vss mounted...I'm about to run some wires from the dash to the rear for the controls and I'll snap a pic when I do. _________________ 1986 Hightop w/EJ25 DOHC & 4EAT auto
Posted: Sun Jul 24, 2016 2:17 pm Post subject: Re: After Market Cruise Control: What's available in 2016 |
T3Pilot, I always do everything i can to avoid having to return a product. Product returns cost both parties. it's a lose-lose. the Gowesty kit costs $400 (for manual). There's no better way to know if that cruise kit is what i want then to look at the instructions. The instructions are useless without the kit. If i like the installation design, i'll buy it, and possibly pay a lot more for the kit than a kit with crappy instructions, or a vendor that refuses to send the instructions. Otherwise, if the gowesty design isn't one i like or i don't think it will work very well, I'll buy something else. I've never had a vendor say no you can't have the instructions. They don't want people to return products either. If they have the instructions available where the sales staff can send them without too much trouble they will gladly provide them. I have found gowesty to be a very good, very cooperative vendor. I'll post here if the instructions are available (prior to purchase). That might be helpful to someone considering the gowesty kit.
Pierre _________________ 1989 GL 2.1 WBX Manual |
Posted: Mon Jul 25, 2016 8:17 pm Post subject: Re: After Market Cruise Control: What's available in 2016 |
Gowesty sent me the installation instructions. The answer was "Hi Pierre,
Here are the instructions "
If you're interested the gowesty option, and in how the install works, just ask them for a copy. Or you can ask me. I'll send you a copy. _________________ 1989 GL 2.1 WBX Manual |
Posted: Tue Jul 26, 2016 2:14 am Post subject: Re: After Market Cruise Control: What's available in 2016 |
Ok, I've decided to forge head with installing a cruise control. I Will also be hooking it up to the gas pedal linkage in the front. Doing this gives me full auto trans kick down function, plus it's easier ......... I think. No linkage hookups on the engine itself.
Once I get my components I will create a separate build thread that I will link to this thread.
Keep this thread as a "what's available?" And an idea thread, not a "how to" thread.
As a bonus, The gas pedal hookup should work for any Van with ANY engine and any transmission in it.
My list provides Amazon links but that's to show you my product choices, Some of this I'm getting locally at my FLAPS.
So...... I've ordered the Rostra Cruise Control universal kit. 250-1223
https://www.amazon.com/gp/product/B007ZCQD9S/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I ordered the dash mounted control switch 250-3593
https://www.amazon.com/gp/product/B001YAI778/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
The dash mount switch was a personal choice but I've read very good things about the wireless RF control switch that you can mount on the steering wheel or on the steering column. 250-1483
https://www.amazon.com/Rostra-Wireless-Cruise-Cont...NH0N4ZTX22
I also ordered the magnetic axle signal pickup kit. There are other options that I believe to be better but this was my choice given my time frame, availability and budget right now. 250-4165
https://www.amazon.com/250-4165-Magnetic-Generator...Y7N73H0FAG
To connect power to the fuse panel I'm going stupid simple. I've added wires to the fuse panel for other accessories already so I'm just going to tap into an extra unused fuse right now with this Bussman (or Littlefuse) ATC Fuse Tap. Again, no cutting of, or tapping into factory wires.
https://www.amazon.com/Circuit-ATC-Piggy-Standard-Holder/dp/B009K6U582
To deactivate the system, Rostra asks that you tap into the brake lights. Disliking hacking into factory wires as I do, I'm going to add a brake light/ cruise control switch mounted at the brake pedal. This way I can also gently tap the pedal and disengage the cruise without illuminating the brake lights.
This is the switch I will use.....
ACDelco 22712549 GM Original Equipment Brake Light and Cruise Control Release Switch
https://www.amazon.com/s/ref=nb_sb_noss?url=search...__________
Ghia
Vanagon
Beetle
Posted: Tue Jul 26, 2016 5:15 am Post subject: Re: After Market Cruise Control: What's available in 2016 |
a couple of other notes. Gowesty sells a lot of their components separately so you can use them with stock or other cruise installations. The VSS sensor is $29.00, which is a lot cheaper than the Rostra mag setup (if you have a later van) and a lot easier to install. Their brake and clutch pedal disengagement switches are also for sale as separate items. _________________ 1989 GL 2.1 WBX Manual |
Abscate Samba Member
Posted: Tue Jul 26, 2016 8:27 am Post subject: Re: After Market Cruise Control: What's available in 2016 |
Im going to push you, Dave - but maybe in a way you won't like.
Trash this idea.
Alter your driving habits to take a break every 60-90 minutes, get out, stretch, breathe in the air, pull over somewhere with a view.
I do this when I accidentally rent a cheap car on business in the Midwest and have to drive from IND to IOWA CITY in a SmartCar. I find having to control the speed much less annoying in 1-2 hour legs.
FWIW (meant to help, seriously) _________________ .ssS! |
