Spitty1974 Samba Member
Joined: September 30, 2011 Posts: 647 Location: California
Posted: Sat Jul 23, 2016 9:25 am Post subject: Spring Plate Torsion Tool |
I've done a search and couldn't seem to find information about a tool; many threads about removal in the split bus threads.
I would like to buy a spring plate tool for removal and installation. From what I've gathered, it makes the job safer, although some have mentioned other methods that work.
Can any one point me in the direction where to buy a tool that others have used?
Can I suspect, that any I find online that look the same, come from the same overseas manufacture?
Thank you for the help. |
Ace Samba Member
Stocknazi Samba Member
Posted: Sat Jul 23, 2016 10:31 am Post subject: Re: Spring Plate Torsion Tool |
I recently removed my spring plates and found a special tool was not really needed. The spring plates are not pre-loaded nearly as much as a bug/beetle/ghia. A floor jack to push up on the plate a small amount was all that was needed. Pick up a magnetic angle finder at you local hardware store; it makes the job easy.
I removed my torsion bars at the same time to inspect them for cracks or breaks and re-greased the splines. Also cleaned up the bushings and coated them with dry graphite powder; much better than the talc recommended in Bently. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10192 Location: Petaluma, CA
Posted: Sat Jul 23, 2016 10:34 am Post subject: Re: Spring Plate Torsion Tool |
I have the compression and press tools outlined in the workshop manual and never use them. The method Doug outlined above works fine. A rubber mallet will drive them home. The factory tools are a good way to turn a 5 minute job into an hour job. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sat Jul 23, 2016 10:46 am Post subject: Re: Spring Plate Torsion Tool |
campingbox wrote: |
Flat rate shop no doubt.
Ask bout the flat rate brothers of San Diego-- full service of vw beetle w ac- flat rate 4.00 done in 20 min.--- _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Posted: Sun Jul 24, 2016 8:48 am Post subject: Re: Spring Plate Torsion Tool |
Thank you to all who gave information. It appears the consensus is to forgo buying the tool. I will remove them using the jack method suggested. First I must take note of the location and angle, time to look for an angle measurement tool. |
