Mrfun2fly Samba Member
Joined: November 29, 2015 Posts: 548 Location: New Mexico
Posted: Sun Jul 24, 2016 4:12 pm Post subject: How do I know if my Electronic ignition works? |
1600 wont start, night and day, started one day then the next didn't.
If I keep the key turning and the gas peddle down all the way it runs till I turn the key off.
I have spark coming from all plugs to the distributor but the engine work start. I think the electronic ignition may of gone out, how do I test the ignition?
Thanks:) |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16754 Location: State College, PA
Posted: Sun Jul 24, 2016 4:33 pm Post subject: Re: How do I know if my Electronic ignition works? |
If it wont start, how does it keep running with the pedal down the whole way? If you have spark and it runs, then I doubt your ignition module is bad. Anytime I had them fail, I had no spark at all. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Jul 24, 2016 4:37 pm Post subject: Re: How do I know if my Electronic ignition works? |
andk5591 wrote: |
If it wont start, how does it keep running with the pedal down the whole way? If you have spark and it runs, then I doubt your ignition module is bad. Anytime I had them fail, I had no spark at all. |
It only runs if I have the key turning. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5986 Location: Brooklyn
Posted: Sun Jul 24, 2016 4:43 pm Post subject: Re: How do I know if my Electronic ignition works? |
Mrfun2fly wrote: |
Then it doesn't run. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Sun Jul 24, 2016 4:44 pm Post subject: Re: How do I know if my Electronic ignition works? |
Mrfun2fly wrote: |
andk5591 wrote: |
I would look for a faulty key switch contact _________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
Posted: Sun Jul 24, 2016 4:46 pm Post subject: Re: How do I know if my Electronic ignition works? |
sjbartnik wrote: |
Mrfun2fly wrote: |
Then it doesn't run. |
True, it was hard to explain what was happening. Anyone know how I can test the ignition? All the plugs have spark, just won't turn over |
Posted: Sun Jul 24, 2016 5:01 pm Post subject: Re: How do I know if my Electronic ignition works? |
Now stop a second.....Runs means that the cylinders are firing....Cranking means that the starter is turning the engine, but there is no combustion happening.
If it only runs with the starter engaged, then yeah - you have a problem with your switch or related. Easy to test if you have a test light or a volt meter. Disconnect your red wire to your ignition module. Turn on the ignition switch - dont crank just turn it on.
Do you have 12V according to your meter or can you light up a light bulb if you connect to the + side of the coil (where your red wire went)?
If no, then your switch or a connection is bad. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Jul 24, 2016 5:48 pm Post subject: Re: How do I know if my Electronic ignition works? |
andk5591 wrote: |
If no, then your switch or a connection is bad. |
Awesome explanation thank you!
Just tested it, and in the process discovered the key is not stay on causing power to turn off to the coil.
What part in the key switch do I replace? |
Posted: Sun Jul 24, 2016 5:53 pm Post subject: Re: How do I know if my Electronic ignition works? |
Just follow your ignition/accessory/starter wires on your stealing column. They will take you right to the part that you need to replace. _________________ Jesse
71 Ghia
Posted: Sun Jul 24, 2016 5:57 pm Post subject: Re: How do I know if my Electronic ignition works? |
What year is the car http://www2.cip1.com/SearchResults.asp?search=ignition+switch&Submit= _________________ D-Dubya Manx clone - 63 Short pan,1914.
SoCalJes wrote: |
Just follow your ignition/accessory/starter wires on your stealing column. They will take you right to the part that you need to replace. |
I'm inside now but thinking it's this part (I have a new one in the box)
Look at this on eBay http://www.ebay.com/itm/360483648962 |
Posted: Sun Jul 24, 2016 5:59 pm Post subject: Re: How do I know if my Electronic ignition works? |
70 ghia
I think it's this part and I have one in the box. Look at this on eBay http://www.ebay.com/itm/360483648962 |
Posted: Sun Jul 24, 2016 6:29 pm Post subject: Re: How do I know if my Electronic ignition works? |
1970.
I just jumped the battery to the positive side of the coil and she runs now. |
