herb0021 Samba Member
Joined: August 14, 2015 Posts: 11 Location: Hudson, WI
Posted: Tue Jul 26, 2016 1:32 pm Post subject: Mounting Engine to Bench Stand |
Hello all,
I am trying to attach my 1600 engine case from a 1979 Super Beetle to a bench stand. I have this bench stand:
http://www.jbugs.com/product/5001.html
I was planning on using the engine mount bolts to bolt the engine to the stand....but I am having some problems.
First, the bolts are not threaded all the way up. Do I need to get a spacer to account for the non-threaded space....or would it be better just to buy a bolt that is threaded the whole way.
Second, with respect to the second spot to attach the case to the stand, the hole in the case is threaded, so its like screwing the bolt into the case rather than pushing the bolt threw and screwing on a nut. Is this right? It seems very difficult to screw in the bolt....and I'm wondering if I'm doing something wrong.
I'm fairly new to all of this, so if I'm missing some vital info or if you have any questions, just let me know. Thanks!
-Ben |
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Tue Jul 26, 2016 2:23 pm Post subject: Re: Mounting Engine to Bench Stand |
That engine support is fine if your going to assemble the two halves with the rods just sticking out. The bench will have to be a steel or a heavy duty wood to hold the weight of the pistons and heads from tipping the bench over.
The lower case stud will just sit in the lower portion while the top hole needs a long enough bolt with a nut. I used the same bolt as used when installing a starter. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31360 Location: Hot Arizona
Posted: Tue Jul 26, 2016 4:00 pm Post subject: Re: Mounting Engine to Bench Stand |
My engine stand looks like that, and is from 4 decades ago. Use whatever works, spacers, washers, etc; you may not readily find large long bolts that are threaded the entire length.
Bolt the one part to the bench. Then bolt the other part of it to the engine, then lift up to the bench and stick it in the hole !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Zundfolge1432 Samba Member
Posted: Tue Jul 26, 2016 4:04 pm Post subject: Re: Mounting Engine to Bench Stand |
Ace hardware sells metric all thread |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76897 Location: Sneaking up behind you
Posted: Tue Jul 26, 2016 4:44 pm Post subject: Re: Mounting Engine to Bench Stand |
Get a 1.5" nipple for a spacer _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Jul 26, 2016 4:48 pm Post subject: Re: Mounting Engine to Bench Stand |
Glenn wrote: |
Get a 1.5" nipple for a spacer |
Nipples? Yes |
Posted: Wed Jul 27, 2016 8:52 am Post subject: Re: Mounting Engine to Bench Stand |
Awesome! Thanks to everyone that responded!
-Ben |
Glenn Mr. 010
Cusser Samba Member
