TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sat Jul 30, 2016 2:00 pm Post subject: '71 ground strap from battery |
Howdy, I just broke off the bolt that holds the battery ground strap to the body on my '71 Westy. My question is, is the nut that it goes into a captive nut? I'm wondering if I need to drill and EZ out the broken bolt or if the nut is just corrode to the body and I can just whack it until it loosens. It's tough to see in to that stiffener bracket where it resides. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Jul 30, 2016 2:09 pm Post subject: Re: '71 ground strap from battery |
The nut is welded to the body IIRC. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Jul 30, 2016 2:12 pm Post subject: Re: '71 ground strap from battery |
Damn! You're fast! I was afraid of that.....Thanks! _________________ If you haven't bled on them, you haven't worked on them.
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Sat Jul 30, 2016 2:34 pm Post subject: Re: '71 ground strap from battery |
don't overthink this. The body is ground. Drill a hole and bolt the ground strap to the body.( I'm guessing if the nut rusted off your vehicle is a driver,not a concourse show vehicle) _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Sat Jul 30, 2016 5:08 pm Post subject: Re: '71 ground strap from battery |
Definitely not a show rig.... I do however like to do things properly where possible. After attempts to drill and extract using penetrant, extractor, heat and my biggest 10R square jaw vise grips, I gave up and drilled/tapped the captive nut and put a new bolt in. The real pisser is that the brand new ground strap I bought is 1/2 " too short! I guess I should measure stuff more carefully, not the supliers fault. Now to research who I bought it from.... It's been a few months and I bought parts from multiple sources. Thanks all. _________________ If you haven't bled on them, you haven't worked on them.
