richierich Samba Member
Posted: Sun Jul 31, 2016 4:34 am Post subject: Valve cover gaskets....UPDATED...more leaking! |
Hi all. I'm having the common problem of oil leaks from valve covers and the gasket dropping off the lip on the top section. I would like to use stock style covers where i could weld a small tab but i have high lift rockers so am stuck with the bolt up items. I have searched the subject and see that people glue the gaskets to the cover - my question is, can I use Hylomar Blue for this or should I use Permatex? If Permatex, which type as i will have to order it off Ebay. Thanks.
Bama Dave Samba Member
Posted: Sun Jul 31, 2016 4:45 am Post subject: Re: Valve cover gaskets |
My two cents: I use a thin layer of RTV to glue the seals to the valve covers themselves...to keep them in place. I use nothing whatsoever where the head touches the gasket. I have zero leaks. Now, the gaskets will need to be changed out at certain points, based on their age, how many times you remove the valve covers, etc. Mine have been on/off over a dozen times and I still have no leaks. I use the stock covers.
Dave _________________ David Richerson
1970 Beetle
1971 Super
1972 Baja
hellthorne wrote: |
First off, I know i made stupid decisions that led to my predicament, so while you are welcome to tell me that I am an idiot for doing the things I did, please know that I am already aware of this. |
kevinhosp Samba Member
Posted: Sun Jul 31, 2016 4:51 am Post subject: Re: Valve cover gaskets |
Permtex gasket eleminator with no gasket. Works great but covers are hard to take off |
Thanks guys. Can I basically use any 'non-hardening' gasket sealer then? |
Posted: Sun Jul 31, 2016 5:03 am Post subject: Re: Valve cover gaskets |
I use the cork gaskets. _________________ David Richerson
1970 Beetle
1971 Super
1972 Baja
hellthorne wrote: |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2769 Location: The World's Motor Capital
Posted: Sun Jul 31, 2016 5:04 am Post subject: Re: Valve cover gaskets |
Posted: Tue Mar 08, 2011 12:05 pm
(from an old post)
I've always used Gaskasinch gasket sealer between my valve covers and the gaskets. It does a good job of holding the gaskets in place, preventing them from creeping inward.
Sometimes, the gaskets need a little stretching to tightly conform to the shape of the outer lip of the valve cover.
A couple of years ago, I built a form from scrap plywood to hold the gasket in the right shape while it is installed. I took some photos of it today:
I normally do this the day before a valve adjustment so the covers are ready to go. I have three sets of covers, so between the two cars, there's always a set I can prep ahead of time.
This wood form has worked very well for me; make one...it's easy.
Good luck, Mondshine |
Posted: Sun Jul 31, 2016 5:21 am Post subject: Re: Valve cover gaskets |
richierich wrote: |
Yes. _________________ David Richerson
1970 Beetle
1971 Super
1972 Baja
hellthorne wrote: |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Jul 31, 2016 7:29 am Post subject: Re: Valve cover gaskets |
I have found that a non hardening gasket sealer will let gasket move.... I use weather stripping (contact) cement like 3M... Sure its a bear to clean off valve cover (none on head side) but carb cleaner and a little wire brush (tooth brush size) makes quick work of problem....
Ultimately I like SCAT valve covers with tabs to retain gaskets...
helowrench Samba Member
Joined: August 27, 2003 Posts: 567 Location: dallas texas
Posted: Sun Jul 31, 2016 7:40 am Post subject: Re: Valve cover gaskets |
On most engines, I use https://www.amazon.com/Hylomar-Aerograde-3-5-oz-Tu...omar+pl32.
prepped correctly you will have no leaks.
clean clean clean the valve covers, carb cleaner or acetone for the final wipe, then the hylomar, then lay the gasket on. Another light smear of hylomar on the head side, and wipe the head surface with a rag (carb cleaner on it) right before assembly.
no leaks whatsoever from that in over 10 years.
Hylomar comes off the head with the acetone, or carb cleaner quite well.
Rob _________________ Current VWs:
70 bug vert for wifey
73Thing bucket o rust
73 914 1.7
12 Passat 2.5 Highway cruiser |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1171 Location: San Angelo, Texas
Posted: Sun Jul 31, 2016 8:40 am Post subject: Re: Valve cover gaskets |
X10 on the 3M trim cement...........The gold standard for many years. You can find it at auto body shop supply companies. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
jason Samba Member
Posted: Sun Jul 31, 2016 5:06 pm Post subject: Re: Valve cover gaskets |
I've never had a leak or sucked gasket. I put a very thin coat of silicone on cover side, stick to cover which has been cleaned by brake clean. Dont use carb cleaner, it leaves a film which is probably lubricant for the moving parts. Oil the side that goes against head and clip on. Let it dry before starting. You can take covers on and off. I've used same gaskets for 10 years. I also have 1.4's using the stock covers, no need for bolt ons. |
Howard 111 Samba Member
Posted: Sun Jul 31, 2016 5:50 pm Post subject: Re: Valve cover gaskets |
jason wrote: |
I once heard of a guy so cheap he slept on his hands and knees to keep from wearing his underwear out. No shit. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
TheRustySuper Samba Member
Joined: June 24, 2009 Posts: 2076 Location: New Albany, IN
Posted: Mon Aug 01, 2016 8:23 am Post subject: Re: Valve cover gaskets |
I've used cork gaskets for years and have never had a problem with leaks. Just make sure to replace them when you do the valves or they probably will leak, they don't like to be reused. _________________ My '72 Super |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Mon Aug 01, 2016 9:28 am Post subject: Re: Valve cover gaskets |
Cork or rubber/cork composite gaskets, gasgacinch on the cover side, a LIGHT smear of grease on the head wide (wiped off so it feels almost dry and there are no gobs of grease anywhere). I can R&R them once or twice without leaks if I clean them well. Feel them and if they are stiff or have any impressions from the head, then they should be replaced. |
mark tucker Samba Member
Posted: Mon Aug 01, 2016 10:24 am Post subject: Re: Valve cover gaskets |
a sharp center punch and some divots in the head and or valve cover to hold the gasket is all I ever used. it gives it traction. or you can add an inner flange to hold it. I also trimed some of the big gaskets so when they expanded that would not force them selves out at the long run.(center) I dont like cleaning sealer off the serfaces Im lazy. |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
JohnnyRingo Samba Member
Joined: October 22, 2011 Posts: 415 Location: United States
Posted: Mon Aug 01, 2016 5:10 pm Post subject: Re: Valve cover gaskets |
Valvoline red European wheel bearing grease....lightly coated on both sides......never a leak so far. Taken from Rob and Dave's VW manual. |
KTPhil Samba Member
Posted: Mon Aug 01, 2016 9:55 pm Post subject: Re: Valve cover gaskets |
JohnnyRingo wrote: |
For decades I used to use a light grease smear on both sides and got very few leaks. It did tend to let them squirm, and for those valve covers without the "keeper ridge" this can allow them to drop at the top. Glue eliminates that chance. |
gt1953 Samba Member
Posted: Tue Aug 02, 2016 6:47 am Post subject: Re: Valve cover gaskets |
A large part of the problem is the week bales. Proper pressure on them is important. I use cork gaskets and soak them in water so they swell up. A small amount of long fiber grease. they do not leak. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
