SOLiiD Samba Member
Joined: June 01, 2016 Posts: 141 Location: in the hot
Posted: Thu Aug 04, 2016 10:18 pm Post subject: cleaning up oil stains and spills |
What are some methods or tricks of the trade? My beetle made a mess and so did my diesel truck a few months back. I tried the coke-a-cola and baking soda trick... it stained. _________________ 72 Super RIP
70 Baja |
retterath Samba Member
Joined: July 19, 2004 Posts: 661 Location: SW Washington state
Posted: Thu Aug 04, 2016 10:23 pm Post subject: Re: cleaning up oil stains and spills |
On concrete I use degreaser, like Castrol super clean, or if it's somewhere the dog might walk, laundry detergent.
If you have asphalt, I'm not aware of anything that will not also destroy the surface. |
awreed Samba Member
Joined: January 14, 2010 Posts: 1268 Location: Kirkland, WA
Posted: Thu Aug 04, 2016 10:41 pm Post subject: Re: cleaning up oil stains and spills |
I've used brake cleaner and a toothbrush on porous cement. Got the job done.... eventually. |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Fri Aug 05, 2016 4:39 am Post subject: Re: cleaning up oil stains and spills |
Soak spot with brake clean & cover with quick dry/kitty litter, stand on it & do the twist. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3198 Location: Downingtown, PA
Posted: Fri Aug 05, 2016 5:11 am Post subject: Re: cleaning up oil stains and spills |
Straight Simple Green. Lay an old towel over the stain, pour SG on the towel until it's soaked and let stand for a few hours. Pull the towel, pour some water on the wet spot and scrub with a brush. Hose the residue off. Repeat as needed. On concrete you'll still have a residual stain though. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Fri Aug 05, 2016 5:32 am Post subject: Re: cleaning up oil stains and spills |
oil dry/cat litter and a brick. put a little a little down and use the brick to spread it around. It absorbs the oil.
I also know a person who swears by bagged cement but I've never tried it. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Fri Aug 05, 2016 7:29 am Post subject: Re: cleaning up oil stains and spills |
Don't waste your time with kitty litter. Spend $2 more and get the real oil-dri from an auto parts store. For concrete after the oil-dri I pour bleach on the stain and let it sit a couple hours then hose off. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Jon Schmid Samba Member
Joined: May 29, 2012 Posts: 2038 Location: Southern California
Posted: Fri Aug 05, 2016 10:45 am Post subject: Re: cleaning up oil stains and spills |
TDCTDI wrote: |
Soak spot with brake clean & cover with quick dry/kitty litter, stand on it & do the twist. |
X2 but I'm too lazy to use brake cleaner. I sweep up the excess litter and would hose the driveway down but with the drought out here that's rather frowned upon. |
SOLiiD Samba Member
Posted: Fri Aug 05, 2016 12:35 pm Post subject: Re: cleaning up oil stains and spills |
Any advice for old diesel oil stains? _________________ 72 Super RIP
70 Baja |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sat Aug 06, 2016 9:13 am Post subject: Re: cleaning up oil stains and spills |
Baking soda works well for active wet spots.
Sprinkle, sweep, and dispose.
I use Dawn and heavy duty degreaser and a coarse brush for most floor shop cleaning. ..
Diluted Muriatic Acid for serious stains..
Dont use it on polished or sealed concrete. or/unless you will be repolishing and resealing.
Use all precautions.
http://www.naturalhandyman.com/iip/infxtra/infmur.html
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
GB2S Samba Member
Posted: Sat Aug 20, 2016 7:16 am Post subject: Re: cleaning up oil stains and spills |
Learned this from an old model T builder. Goes to your local Home Depot, Lowes type store. Purchase there torn open portland cement bags. I've paid as little as .25 cents. Pour the cement on the spill. WAIT Not only does it clean up the yucky stuff, but the concrete fills small cracks.
I also just buy a CHEAP box detergent. Pour it on, maybe grind it in a little with the end of an 2x4. WAIT. Next time I wash the car I rinse it off. The only problem with this is sometimes you end up with a clean spot to look at
Geoff _________________ 1963 Ragtop |
