andy198712 Samba Member
Joined: December 05, 2010 Posts: 1209 Location: Cornwall - UK
Posted: Tue Aug 09, 2016 1:21 pm Post subject: Re: Crank trigger ignition |
there is a MASSIVE megasquirt forum.... _________________
Alstrup wrote: |
I like 5,5inchers in the rear at least. |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3462 Location: Paradise, Ca
Posted: Tue Aug 09, 2016 4:12 pm Post subject: Re: Crank trigger ignition |
Based upon the types of questions/comments that you have been stating, I would STRONGLY suggest getting the CB Crank trigger and NOT the mega jolt. (if you must get crank trigger)
Earlier, you mentioned your concern to find someone else to tune the CB setup. This tells me that your first thought is to not rely on yourself, when your first thought with crank trigger SHOULD be to rely on yourself and learn it.
Also, you mentioned "Weld the crank trigger wheel to the pulley" which says you are definitely at the beginning stages of your automotive learning.
If you had your heart is set on getting a crank trigger, simpler the better for the start.
Cb's combos are very user friendly, and they don't leave you in the dark.
_________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Der6VoltFahrers Samba Member
Joined: April 15, 2009 Posts: 84 Location: Hannover Germany
Posted: Thu Aug 11, 2016 1:50 pm Post subject: Re: Crank trigger ignition |
I´m using the crank trigger setup from vwspeedshop. Works and looks good
j-dub Samba Member
Joined: November 09, 2003 Posts: 865 Location: Phoenix, AZ
Posted: Thu Aug 11, 2016 7:06 pm Post subject: Re: Crank trigger ignition |
OP,
So three pages later did you ever replace your coil?
Der6Volt,
Got any more information on your vwspeedshop system? What are you using to control the spark? It was hard to tell but it looks like you are using a TPS sensor, alpha-N. Is that correct?
The website only shows the trigger not the ignition box. _________________ 1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on." |
advinnie Samba Member
Joined: November 18, 2011 Posts: 1389 Location: oxfordshire
Posted: Fri Aug 12, 2016 2:32 am Post subject: Re: Crank trigger ignition |
Hi I went crank trigger ignition from triggerwheels got everything I need from one shop it use a megajolt system.
Plus I may get the CB performance trigger wheel kit that way I don't have to do any machine work at all and sell the parts I don't need on.
I now have a SVDA distributor map witch I will use at first then slowly play around with it and if all goes wrong the is a dyno Tuning garage who specialise in DIY crank ignition using the megajolt or megasquirt units |
Posted: Fri Sep 23, 2016 6:41 am Post subject: Re: Crank trigger ignition |
Hi all I know it's been a long time but I'm all most ready to start my new engine with the megajolt system but have just one little job left and that's to wire up the pick-up sensor. Now I know witch wire is the postive and negative but witch pin on the pick-up is the postive and witch is the negative there is now marking on the sensor at all. |
Posted: Mon Sep 26, 2016 11:27 pm Post subject: Re: Crank trigger ignition |
Engine in and running and here's my first MAP what do you lot think off it?
Pinnacle Tuning Samba Member
Joined: July 12, 2016 Posts: 9 Location: Long Island, NY
Posted: Fri Oct 07, 2016 5:13 pm Post subject: Re: Crank trigger ignition |
I have a (megasquirt)coil on plug setup on my 36hp with webers. It works awesome. Plus it really cleaned up the engine bay I feel without the look of a dizzy on there.
This winter I plan on finishing my fuel system and just keeping my carbs to act as throttles body's.
If you want to use coil on plug then just do it. You will not regret it. |
Posted: Sat Oct 08, 2016 7:41 am Post subject: Re: Crank trigger ignition |
Yes I agree the engine bay looks so much cleaner with out the distributor and fuel pumpvinnicombe the way But I will never part with my weber 48 IDF's in just love the sound they make
Plus my timing is spot on all the time now with the smoothest idle I've ever had. |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sat Oct 08, 2016 3:20 pm Post subject: Re: Crank trigger ignition |
advinnie wrote: |
You should change your rpm bins so you go all the way to redline and remap accordingly. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Sat Oct 08, 2016 3:43 pm Post subject: Re: Crank trigger ignition |
Yes I will be changing the rpm bins I just wanted to get the idle to 3200rpm ignition right first. |
Posted: Wed Oct 19, 2016 12:31 am Post subject: Re: Crank trigger ignition |
Here's two datalogs now I do understand what they are saying but I was not expecting the Kpa line to be so erratic I was expecting a more contant straight line ?
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Wed Oct 19, 2016 3:35 am Post subject: Re: Crank trigger ignition |
Looks like my latest "cardiogram"
Nice Engine, give up on turboing it? _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Wed Oct 19, 2016 4:07 am Post subject: Re: Crank trigger ignition |
cardiogram nice one
Turbo is still on the card to do but for now it's had to take a back seat for now cause I need some welding done so if you know of anyone in the UK that can do it for me please let me know. |
Posted: Sat Oct 22, 2016 1:30 am Post subject: Re: Crank trigger ignition |
question for you lot, done a new map and datalogg and have noticed that the map and log don't match up. For example if you look at the photo below at 188 seconds you will noticed that the log is saying engine rpm is 1948, load is 68 and timing is 19 degrees but on the map table the ignition timing should be 28-29 degrees any ideas why there is a difference?
The log timing all ways seems to be lower than what the map table is set to.
