Brendel20 Samba Member
Joined: October 21, 2010 Posts: 300 Location: Troy, IL
Posted: Thu Oct 20, 2016 6:07 pm Post subject: Re: Brendel20's 1954 Beetle Build |
Slowly plugging along...literally. Lots of plug welds on the pans. Used a pneumatic punch to create the plugs every inch. One side down and seam sealed.
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Sat Oct 22, 2016 11:32 am Post subject: Re: Brendel20's 1954 Beetle Build |
Go... go... GO Andy! Cool Oval, several months earlier than my "Martha" (June 1955). You running "Hearts" or "Egg" style taillights? Sounds like Hearts? Stay stock!
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Posted: Sat Oct 22, 2016 9:06 pm Post subject: Re: Brendel20's 1954 Beetle Build |
Thanks Bill. Yep, hearts and 100% stock for sure. |
3foldfolly Samba Member
Joined: March 08, 2009 Posts: 894 Location: Edwardsville, Il
Posted: Sun Oct 23, 2016 8:03 am Post subject: Re: Brendel20's 1954 Beetle Build |
Any excuse to play with fire. |
Posted: Thu Nov 10, 2016 8:27 pm Post subject: Re: Brendel20's 1954 Beetle Build |
Yes, Mike I love fire for sure . So man.. Slow going but that may be for the best. It's really allowed me make things as perfect as possible. I get like 30-60 minutes a day max to stare at things and plan. And sometimes actually do something. I have a 2 year old that Must be with daddy when I'm in the garage and I'm not willing to weld or grid if he's anywhere close. I knew and wanted this to be a slow and correct project. I love it. Here's where I'm at. Left pan welded but no grinding yet. ~AB
Also been cleaning up my splitcase. New seals, some paint, etc.... Ready to build up on each end now. This is a nice change of pace when the pan work gets old. It's been good to be able to mix up the work. |
rlmartinez Samba Member
Joined: December 09, 2005 Posts: 233 Location: Whittier, CA
Posted: Sat Nov 12, 2016 9:13 am Post subject: Re: Brendel20's 1954 Beetle Build |
Great project and good luck! I am working on my 54 as well. _________________ 54 Bug
56 convertible |
Posted: Mon Nov 14, 2016 7:53 pm Post subject: Re: Brendel20's 1954 Beetle Build |
Pans are officially done so I decided to get the seat rails welded. Seemed like an easy task but took way longer to plan and get correct.
I have these correct -55 beauties to install eventually but since the tracks were rusted either off or beyond recognition, I opted to use my later seats as an aide to ensure the spacing was perfect.
Luckiky 3foldfoly is only a call or text away to get measurements. He was able to get me exact measurements off his 54 to get my inner rail perfect. Thanks man. I then aligned my seat so the tracks and rails were spaced correctly. Still haven't welded the outer passenger rail yet but its all ready to go.
Posted: Mon Nov 14, 2016 7:59 pm Post subject: Re: Brendel20's 1954 Beetle Build |
Thanks rlmartinez....saw your seat thread. I may need some assistance from you when I get to restoring my seat frames. Nice work on yours |
Posted: Mon Nov 14, 2016 8:58 pm Post subject: Re: Brendel20's 1954 Beetle Build |
You have to make sure the rails are far enough apart to make the seat frame/rails hold tight enough against the tracks. When I start my seats onto the rails I have to hook the seat frame/track over the inner rail and then pull the outer seat frame/track outward somewhat to get it to line up and start on the outer rail. |
Posted: Sat Dec 31, 2016 2:55 pm Post subject: Re: Brendel20's 1954 Beetle Build |
Finished up the pan. Striped it to bare metal, 3 coats of POR15 gray, 3 coats of black top coat.
Then was able to get the spring plates set with new bushings and front beam installed.
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Sat Dec 31, 2016 5:53 pm Post subject: Re: Brendel20's 1954 Beetle Build |
Very nice work, it looks great! _________________ Brandon |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Sat Dec 31, 2016 10:22 pm Post subject: Re: Brendel20's 1954 Beetle Build |
Great work!! You went with the '56 and up style pans? Also, I don't see the floor mat buttons on the pans, did you forget them or are you not putting rubber mats in? _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Posted: Sun Jan 01, 2017 7:40 am Post subject: Re: Brendel20's 1954 Beetle Build |
Thanks guys. The pans are WW -55 pans. As for the floor mat tabs....I plan to put carpet in. |
Posted: Sat Feb 25, 2017 7:57 pm Post subject: Re: Brendel20's 1954 Beetle Build |
Lots of chassis work completed. I still have a couple brake lines to run and the axle boots to clamp. Other than that...it's time to roll the body in and start work on it. I'll also be building up my 36hp 1954 block that I've finally found all the needed parts for. Here's a few picture updates:
Posted: Wed Mar 01, 2017 10:14 am Post subject: Re: Brendel20's 1954 Beetle Build |
Nice! When can we come over to your garage and play (and check it out!)? Beautiful work!
Bill _________________ I'm looking for these license plate frames for my fleet:
Posted: Thu Mar 02, 2017 6:34 pm Post subject: Re: Brendel20's 1954 Beetle Build |
Thanks Bill. Absolutely, would love to host a VW get together. Let's plan it! |
Posted: Thu Mar 02, 2017 7:04 pm Post subject: Re: Brendel20's 1954 Beetle Build |
I'll bring the concrete cleaner for the day after. |
icekoffee Samba Member
Joined: March 14, 2005 Posts: 1239 Location: DeSoto, Missouri
Posted: Mon Mar 13, 2017 12:11 pm Post subject: Re: Brendel20's 1954 Beetle Build |
Looking great! I can't wait to see it rolling around this summer _________________ 1952 Zwitter
1959 23 Window
1963 Doubleturd
1958 Patina Beetle EJ25
1984 Vanagon Westfalia EJ25
1964 Lifted Mouse Grey Standard
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
favguy Samba Member
Joined: January 25, 2012 Posts: 235 Location: England
Posted: Mon Mar 13, 2017 12:19 pm Post subject: Re: Brendel20's 1954 Beetle Build |
Chassis is looking great, Noticed no jacking points, are you not having any? |
Posted: Mon Mar 13, 2017 12:42 pm Post subject: Re: Brendel20's 1954 Beetle Build |
3foldfolly wrote: |
Ha! yep....for sure will need some of that Mike!
Thanks Andrew....no chance it will be seen this summer! Lot's of metal work ahead of me.
Favguy.....I went back and forth on jack points and decided to not weld them on. I may regret it down the road but I don't ever plan on using them. They would be on for aesthetic purposes only. Nice eye! |
