Dake Samba Member
Joined: September 02, 2014 Posts: 481 Location: Georgia
Posted: Thu Aug 11, 2016 1:43 pm Post subject: Oil bypass benefits? |
I was looking at put one on my engine or should i just use it as a breather? |
Dake Samba Member
Posted: Sat Aug 13, 2016 8:30 pm Post subject: Re: Oil bypass benefits? |
No one has an answer for this |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13955 Location: Southampton U.K.
ibilisi Samba Member
Joined: August 12, 2011 Posts: 45 Location: United States
Posted: Mon Aug 15, 2016 11:28 am Post subject: Re: Oil bypass benefits? |
One of the funniest responses to the discussion I've read was mark's :
mark tucker wrote: |
just hide the spin on filter and use the other for a bypass filter for fine filtering a portion of the oil, or just make it look like it is doing it's job but keep some extra sparking bolts&some rags,tools in the canaster.could also run a coil of tubing in it to heat up some soup for lunch&dinner when your on the road with the oil temp.or even a tiny cornish hen. |
This thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=584365 |
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Fri Nov 11, 2016 8:41 am Post subject: Re: Oil bypass benefits? |
Hi. Agreed on the other peoples comments. But please recognize the documented importance the by-pass oil filters perform on the diesel big rig trucks. This is one reason those engines obtain such high mileage engine life. Take aa small amount of oil and filter it finer.
On my '71 bus, 1600, I run a popular setup with the 1 1/2qt sump and full flow filter. BUT, I added a by-pass Baldwin B164 filter. The outlet from this filter is about 1/32" diameter.
Hope this helps. Bill. |
