Chevy432 Samba Member
Posted: Thu Aug 11, 2016 10:24 pm Post subject: New toy (1984 Rabbit Diesel) |
Picked up a previously stolen rabbit for $400, it's got 140,000kms on it and it's in good condition! It was hot wired and the ignition cylinder was drilled out, I swapped all those parts from my 1980 rabbit and plugged a battery in and everything worked except when I went to start the car and got nothing (no starting sound) so I opened up the hood and noticed an empty whole in the side of the motor...... Someone jacked the starter! I searched it up and apparently I can't use the starter that's on my gass rabbit because it won't have enough whatever to start the diesel. Is this true or can I swap mine onto the new rabbit? If not does anyone no who or where I could pick one up for relatively cheap (below $100)?
Thanks, Trevor! |
crsmp5 Samba Member
Posted: Fri Aug 12, 2016 5:24 am Post subject: Re: New toy (1984 Rabbit Diesel) |
correct... gas n diesel different... guess ya need 2nd job if $100 is too much... aking care of the car so it does not make ya walk will cost more... and if t belt breaks way more$ _________________ [url=http://cdn2.driiive.com/7037.jpg]Click to view image[/url] |
Joined: August 31, 2013 Posts: 12846 Location: North Carolina
Posted: Fri Aug 12, 2016 10:37 am Post subject: Re: New toy (1984 Rabbit Diesel) |
You can put the diesel starter in the gas car, but the gas starter doesn't have the torque to turn the diesel over. You can try it, but it may not last long. I always upgrade to a diesel starter whenever I have to replace a starter. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Aug 13, 2016 9:02 am Post subject: Re: New toy (1984 Rabbit Diesel) |
Thanks, I'm going to use the one from my gas car to see if it will actually run and if so then I'll cough out the money and get the right diesel one! |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Sat Aug 13, 2016 10:10 am Post subject: Re: New toy (1984 Rabbit Diesel) |
How long has it been sitting for? I would seriously consider a new timing belt before trying to start this motor, as almost any miss-timing will bend valves. |
Posted: Mon Aug 15, 2016 4:15 pm Post subject: Re: New toy (1984 Rabbit Diesel) |
Honestly have no idea, the guy I got it from got it from a tow truck company who found it on the side of the road a bunch of years back. So it probably hasn't ran in around 5-10 years?.. |
ps2375 Samba Member
Posted: Wed Aug 17, 2016 12:15 pm Post subject: Re: New toy (1984 Rabbit Diesel) |
If it has been sitting that long, first thing I'd do is a new timing belt before even trying to turn it over, no question, as not only does it turn the cam, it has to drive the injection pump. The T-belt on a diesel works much harder than its counterpart on a gas motor. That is why they are changed more frequently on them. |
