oebgronin Samba Member
Joined: June 01, 2016 Posts: 10 Location: Aguascalientes, Mexico
Posted: Tue Aug 16, 2016 12:38 pm Post subject: Balljoint |
So I was driving home when I hear a very loud noise and the front of the bug dropped, I get down to inspect and find that the lower ball joint snapped and get out of position, lucky me I was carrying a chain of about 60 cm, go to the nearest hardware store and buy a bolt, nut and some shims, using the car jack get the balljoint back in position and using the chain and the bolt I pull the arms together until the balljoint assembles again, pull the arms even more so the balljoint didn't snap again and get back home.
When replaced the balljoints the mechanic told me that this is often used by the taxi drivers in Mexico (where there are still VW bugs as cabs) in a permanent way to prolong the life of the ball joints.
What do you think?
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2912 Location: San Antonio, Nuevo Mexico
Posted: Tue Aug 16, 2016 1:20 pm Post subject: Re: Balljoint |
if your insurance company is not based in Mexico City, I would venture it is not a good idea. your lawyer will not like you if you do this. _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
enjoyther1de Samba Member
Joined: December 19, 2010 Posts: 1279 Location: chino,ca
Posted: Tue Aug 16, 2016 2:08 pm Post subject: Re: Balljoint |
Bueno! I had to do that a few months back with a ratchet strap to get home.
The idea of leaving it full time is not a good one as it will limit your wheel travel and eventually break the chain. _________________ HBB took me to BBV. |
Posted: Wed Aug 17, 2016 10:03 am Post subject: Re: Balljoint |
I don't have insurance, is not mandatory in Mexico, also this was only to get home, as soon as the balljoints were replaced the chain was removed and is ready for another emergency |
dustymojave Samba Member
Posted: Sat Aug 20, 2016 12:54 am Post subject: Re: Balljoint |
Good fix to get home.
But it is one reason why it can be dangerous to ride a Taxi in Mexico. _________________ Richard
SoCalBajas Member
Posted: Sat Aug 20, 2016 7:24 am Post subject: Re: Balljoint |
In Turkey they operate on the theory that the taxicab would not be in that spot at that time if you had not told the driver to go where you need to be when you got in. therefore, it is your fault that the taxicab ran over that chicken.
you owe the farmer for that chicken, every egg it would have laid, every chick it would have produced, and all the eggs they would have laid, for 5 generations
every chicken hit by a taxicab in Turkey is the grand champion chicken of all Turkey. on a busy day two dozen grand champion chickens of all Turkey get run over.
when you take a cab in Turkey:
no identification on the luggage you may need to abandon.
you negotiate the price in advance. you count out the cash and put it on the seat under your palm. if you get into an accident, leave the fare on the seat and run. dodge, weave, serpentine, run down alleys, run through buildings.
makes a Tijuana Taxi ride look tame. _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
