dentfreeimage Samba Member
Joined: September 21, 2013 Posts: 292 Location: San Antonio, TX
Posted: Tue Aug 16, 2016 5:26 pm Post subject: 1971 Camper Parked for 24 Years Rust on Floors! |
Hello everyone, I just got this 71 camper from a friend in exchange for some Paintless Dent Repair on his 65 Guia. He got it from someone else a year ago and did not touch it. The body is very solid but it looks like it sat outside all these years and water ran down the floor causing some rust, which I will need to take care.
The front floors look very solid with some light rust and pin holes. The rear floor, specially the space between the front seats going back to the rear have some heavier rust with some larger holes. My question is, would it better to cut the rusted rear floor areas and replace with complete panels or does it look like something that can be patched and conserve the current floor? I think the front floor is repairable without needing to be replaced. Are those access plates underneath each side welded to the frame?
This is my 1st bay window and I want to turn it into a nice driver.
Thank you for the advice!
ateneo Samba Member
Joined: June 12, 2008 Posts: 403 Location: Orange County, California
Posted: Thu Aug 18, 2016 10:40 am Post subject: Re: 1971 Camper Parked for 24 Years Rust on Floors! |
You have a Westfalia bus with a nice exterior patina. It would be nice to preserve the patina and just restore the interior of your bus.
I would suggest that you remove all the interior cabinets, bed & seats so that you can see the whole floor area. Then do your probing on the extent of the rust. Check the rear wheel wells if there is rust holes in them because water can get into your floor through those when you are driving on a rainy day. Hang a bright light on the roof of the bus and then go underneath the bus. If your view of the floor looks like a star-filled sky on a clear evening, then you know you it is time to replace the floor.
The front floor seemed to still be in good shape with a few small spots that you can patch up with fresh metal.
Be careful when you pull out the cabinets because the bottom section might have weakened due to water damage. Good luck. _________________ 1966 Riviera camper Bus
1967 EZ camper bus
1971 Westfalia bus
1971 Deluxe bus
1969 Bus
1962 Bug
1963 Bug
"Rust free" means Rust is FREE. The rest is junk. |
Posted: Thu Aug 18, 2016 1:56 pm Post subject: Re: 1971 Camper Parked for 24 Years Rust on Floors! |
Thanks for the great advice, it defenetly gives me a starting point on how to tackle the repairs. As far as the wheel opening goes they are rock solid, I believe they only have surface rust.
Are the floor belly covers welded to the floor? Just trying to figure out how to access the bottom of the floors. I am not a patina guy, even do it looks pretty cool. My plans are to strip it down to bare metal, which should not be hard since it has never been painted and it is now sitting on the factory primer since the paint has faded away and paint it the original color.
ateneo Samba Member
Posted: Fri Aug 19, 2016 8:57 am Post subject: Re: 1971 Camper Parked for 24 Years Rust on Floors! |
The belly pans are not welded to the floor. The above picture Is the area above the belly pan of my 1971 Westy. _________________ 1966 Riviera camper Bus
1967 EZ camper bus
1971 Westfalia bus
1971 Deluxe bus
1969 Bus
1962 Bug
1963 Bug
Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Sat Aug 20, 2016 6:11 pm Post subject: Re: 1971 Camper Parked for 24 Years Rust on Floors! |
but how do they come off? lol
Glad you started this thread. I'm starting my 68 too. Pulled out the cabinets and the floor to see where I'm at. My rear cargo hatch seal was bad, so I have a lot of rust in the back. The spare tire bucket has large holes.
Bright side is my battery trays are rock solid.
I'll be following your progress. _________________ ~Kevin
My 1968 Campmobile |
ateneo Samba Member
Posted: Sun Aug 21, 2016 2:52 pm Post subject: Re: 1971 Camper Parked for 24 Years Rust on Floors! |
As you can see in the picture, one end of the belly pan is welded to the chassis & the other end to the bottom tip of the outer rocker. The front & back end of the belly pan are welded to the outriggers.
You have to drill out the weld spots of the pan for you to take them out. _________________ 1966 Riviera camper Bus
1967 EZ camper bus
1971 Westfalia bus
1971 Deluxe bus
1969 Bus
1962 Bug
1963 Bug
Posted: Sun Aug 21, 2016 7:05 pm Post subject: Re: 1971 Camper Parked for 24 Years Rust on Floors! |
Wow. Really?
What were those Germans thinking? lol
hmmmm... if I take them off, they will BOLT back on. _________________ ~Kevin
