wyobuggy Samba Member
Joined: October 11, 2005 Posts: 68 Location: Hawk Springs , Wyoming
Posted: Wed Aug 17, 2016 11:15 pm Post subject: 002 in tunnel trans swap nightmare! |
So I'm helping a friend put a 68 002 trans in his 72 Baja. Because he has turning brkes, he wanted it in the tunnel.
Bought the empi solid mount swap kit, and the dreaded aluminum shift adaptor. Had to cut out the mount hole to the frame horns, Miss punched!
So the trans is in, but we spent hours beating our heads against a wall trying to hook up the shift rod.
First question. Is this adaptor supposed to be straight, or drilled at an angle? Ours is at an angle.
And for some reason we lack about 1/4 inch of shift rod length it seems.
I've used the mounts 2-3 times before but it's my first adapter experience...
Any ideas???? |
Posted: Thu Aug 18, 2016 3:13 pm Post subject: Re: 002 in tunnel trans swap nightmare! |
Wow. No one even has a sarcastic comment???? |
joemama Samba Member
Joined: February 09, 2006 Posts: 1636 Location: La Crescenta, California
Posted: Thu Aug 18, 2016 3:40 pm Post subject: Re: 002 in tunnel trans swap nightmare! |
you might post pictures so we can see what your dealing with. |
dustymojave Samba Member
Posted: Sat Aug 20, 2016 11:31 am Post subject: Re: 002 in tunnel trans swap nightmare! |
I hate those adapters. They're a mickey mouse crappy concept.
I would MUCH rather work on getting the trans lower in the pan. Using a mid mount allows that. The mid mount is available over the counter. Or it could be made of 3/16 x 1.5" strap wrapped around the case at the front bearing carrier, with a clamp bolt and ears welded to the sides to mount it to the yokes. Or clamp around the yokes like an EMPI Type 1 mid-mount support strap.
Then connect the shift rod like normal. _________________ Richard
SoCalBajas Member
